Question about Kenmore HE2 Plus Front Load Washer
Tested water temp with an ohm meter and connection
    Top Expert:
  • Kenmore Master
  • 9,472 Answers
The "F24" error code is an indication of a water temperature sensor error. The temperature sensor is located at the rear bottom of the tub. Here is the part to order.
The part comes with a 365 day, any part, any reason return policy.
Posted on Nov 09, 2012
Have a hayward hp21001 heat pump set temp for 89 degrees but say water temp is 38 degrees when pool thermostat reads 76
Try replacing the temp sensor. You can test the temp sensor if you have an ohms meter that can read k-ohms. If the sensor is good then the board is probably not reading the sensor properly.
Jun 12, 2017 | Hayward Pool & Spa
Electrolux fridge EI11bf25ls just beeping compressor not starting no power going there
Fridge keeps beeping or buzzing: The following is for Frigidaire models but others can be addressed similarly.
Several Frigidaire refrigerator models have an electronic control panel on the freezer door the owner can use to adjust the internal temperature, dispense ice and water and receive notification about issues such as the need to replace a water filter. The refrigerators also emit a beep for various actions and as an occasional alarm. Determining what causes the beeps necessitates some troubleshooting.
Temperature Controls ·A Frigidaire refrigerator's display panel blinks when the control panel is touched to set temperature controls. After pressing "Freezer Temp" or "Refrigerator Temp" on the keypad, press the arrow buttons within five seconds to increase or decrease the desired temperature. If you do not press the arrow buttons within five seconds after pressing "Freezer Temp" or "Refrigerator Temp" on the keypad, the refrigerator beeps to indicate the current setting will stay in place.
Door Open ·When you leave the refrigerator or freezer door open, the refrigerator beeps. Also, the "Door Ajar" indicator illuminates on the appliance's display panel. Shutting the door and pressing "Alarm Reset" stops the beeping and turns off the "Door Ajar" indicator light.
·The Frigidaire refrigerator has a control lock feature that prevents use of its control panel or dispensers when the unit is locked. When the control lock is active, a beep sounds when a keypad or dispenser is pressed. Release the control lock by pressing the "Control Lock" icon for three seconds. A beep will sound, and the icon's light will go out.
Power Reset ·A power reset is occasionally necessary if the Frigidaire refrigerator's control panel does not work normally or a reset function on the keypad does not work. A power reset involves disconnecting power to the refrigerator by unplugging its power cord from the electrical outlet, waiting 30 seconds and plugging the power cord back into the electrical outlet. When the control panel resets, a beep sounds. If the refrigerator beeps even after a power reset and the beeps' source is not known, contact Frigidaire.
Read more :http://www.ehow.com/info_12148688_cause-beeping-noise-frigidaire-refrigerator.html
Fridge not starting? CLICKING? FIRST ALWAYSCHECK FORpower at the outlet,checkfor 120 volts. I think God os good that's why I give free advice?
MAY HAVE A BAD START RELAY OR CAPACITOR ON THE COMPRESSOR , CAN BUY A INEXSPENSIVE 3 IN 1 HARDSTART KIT AND BY PASS THEM , NOT THAT HARD TO DO, COMES WITH INSTRUCTIONS> BY THE WAY DO U HEAR ANY CLICKING SOUNDS FROM COMPRESSOR? BUT U MAY ALSO WANT TO CHECK UR COLD CONTROL THERMOSTAT IF IT GOES BAD U MAY GET A NON START ALSO HAVE IT CHECKED FOR PROPER VOLTAGE AND OHMS RESISTANCE WHEN IN THE ON POSITION
A BAD DEFROST TIMER CAN SHUT DOWN COMPRESSOR HAVE IT CHECKED WITH MULTI METER.
to check the defrost timer, u can get by and test manually by placing a small screw driver into the tiny slot or hole underneath the timer and turn slowly clockwise till u hear 1 click. this will engage ur defrost cycle in about 15 minutes u should be able to come back and feel the heat in freezer as it melts the ice providing ur terminator is not bad?
Another way to test it is with a multi meter. Remove timer it from fridge and you will see 4 prongs numbered 2,1,4,3 in that order. Place ur meter prong on prong 1 & 3 (if your fridge has a capacitor wired in series with the windings, then u check for micro fares rather than OHMS) If u cannot confirm this test, still try the next.
Take ur meter prong and connect to prong 1 & 4, it should read resistance or ohms ( closed) now remove prongs and place on prong 1 & 2, this should now read infinity or open (no ohms) now take a small screwdriver place it in the tiny hole or slot under the timer. Turn it clockwise slowly till u hear 1 click. Now ur 1& 2 should read closed ( showing ohms or resistance) now place meter prongs on 1 & 4 and you it should now show open ( or no resistance - no ohms) this is how u know ur timer is good, Remember when testing for ohms ADJUST meter to use a high ohms rating in the thousands as the resistance is very high in OHMS. And adjusting to low ohms rating may give a false reading or not show the proper resistance..
AT TIMES YOU MAY HEAR THE COMPRESSOR CLICK OFF AND ON OVER AND OVER. Signs of a bad start relay or capacitor. Check with an OHMS meter for continuity (ohms) and voltage, capacitor can be checked for Microfares. ( if in series with the windings)
To check ur compressor with multi meter:
Disconnect and remove the relay and capacitor from compressor, somes located next to compressor in a casing.
You wills see 3 prongs coming out of compressor. 1 goes to ur start winding, 1 goes to ur run winding and the center goes to ur ground or COM
Place ur meter connector or prong on the start prong and the other on the ground (center prong) take note of the reading in OHMS for example 5 ohms.
Next place meter prong on run prong and the center ground prong agin. Take note of the reading in OHMS. Example 4 ohms
Next place meter prong on the start prong and the other on the run prong, now take note of the reading example 9 ohms. Now match the total of this ohms test with the total of ur two separate test. 9 ohms, if they match ur ok give or take 5 percent plus or minus. One more test to make to test of there is a short in compressor attach meter prong to ground prong and rub the other end of meter prong to metal ( scrape the metal clean of paint and test on metal surface not painted surface. If it shows continuity or ohms , u have a short in ur compressor. It should show infinity
God is so good: so this is why I give free advice so please thank him not me.
May 14, 2015 | Electrolux Refrigerators
Magic Chef mini fridge HMBR445WE, turns on gets to temp but that's it,compressor does not turn on unless I turn the temp control off and on again. it does not get the signal to turn on by itself.
You wills see 3 prongs coming out of compressor. 1 goes to ur srtart winding, 1 goes to ur run winding and the center goes to ur ground.
Apr 27, 2015 | Magic Chef Refrigerators
Water will not come into the washer but moter is running.I have checked all hoses
shut taps and disconnect hose and place in bucket then make sure water comes out of hose by slowly opening taps.
If ok check if the electric valves open by setting first cold then hot on temp button. if hot water only then cold valve is faulty. you should hear a click sound from valves usually situated under control panel. if not then unplug machine, remove control panel and measure resistance on electrical connections of cold and hot valves with ohm meter at around 15 ohm if they are marked 12 v
meaning they operate on 12 volts from the control panel computer.
if no ohm reading or in the mega ohms replace valve. you can swap the wires between cold and hot if cold valve is faulty and use the hot valve for cold wash only then you wont have hot water.
If both valves ohms around 15 ohm then plug in and measure voltage at valve when machine starts you should get 12 volts on valves.( be careful for mains high voltage from mains wire entering panel when measuring keep hands clear of mains voltage and any water from panel.
If no voltage may then be computer panel faulty. check connections from valve connectors to panel and connectors on panel may be loose if not check voltage on panel where wires connect to computer panel if no voltage then make sure the water level valve is not stuck in closed position that will tell the computer the machine is full of water. just remove one or two wires from the level control valve (the level valve is a round plastic valve about the size of a small cup and has wires and a thin plastic pipe connected to it )and start machine if water enters then replace level valve if not maybe its computer board fault, replace. (you can test level valve with ohm meter and blow into the place where the pipe is connected by removing pipe it should click and ohm meter should show around 0.2 ohms when blowing and high ohms when not blowing.) some click twice as they have two levels.
Sep 05, 2014 | Fisher Paykel EcoSmart GWL15
Trouble shooting Samsung REF. Model RS267LBSH
when the defrost terminator has gone out and u get ice build up? u can check the terminator with a multi meter for continuity but do not check at room temperature. stick the terminator in cup of ice water for 20 minutes then check it for continuity, should be closed when cold and open at room temperature.
May also need to check the defrost timer, u can get by and test manually by placing a small screw driver into the tiny slot or hole underneath the timer and turn slowly clockwise till u hear 1 click. this will engage ur defrost cycle in about 15 minutes u should be able to come back and feel the heat in freezer as it melts the ice providing ur terminator is not bad?
Another item to check with a meter is the heating element itself. Located under the evaporator coils. It should show continuity or resistance OHMS WHEN TESTED AT BOTH ENDS OF THE PRONGS .
Lastly check the cold control thermostat with a meter for both OHMS and volts ( VOLTS is a live test with fridge plugged in so be careful) It must show 110 volts. An open or thermostat that reads infinity will not allow the proper cooling and defrosting cycles to operate and may in fact stop anything from happening as if there is no power to the unit?
Aug 19, 2014 | Samsung Refrigerators
Engine temp sensor bypass or test
WHAT SIZE ENGINE???? ? 4L 2.5L????
ive seen this post many times now.and can not figure it out.
double posted.
what are you trying to do, say that first. or just ask a question
first off,what does bypass mean???? <<very confusing to me...????
This is THE ECT, the ENGINE. Coolant Temperature" sensor.
what do you wish to do with this very critical EFI sensor.???????
just test it.>
Ill guess, you have not read the FSM , as it covers that 2 ways.
the ECT can be tested 3 ways.
ill show 2
1: on car and off car.
1: on car. (is more easy. if strong back)
DMM set to RESISTANCE , aka. ohms. ohmega symbol
the DMM meter is $20 at walfart.
cold car, say at about 50f.
you unplug the ECT connector (2 pin conn)
cold engine it might read, 5000 ohm, this is good,
get engine fully hot. i use a IR pyro gun, it hit 180F or more.
and kill engine.
pull back off the ECT sensor. conn.
and it reads (2 pins 2 meter leads) about 300 ohms.
is this what you want.
first google hit on sensor , but FSM shows truth....
1st hit shows....... its a NTC thermistor with these rules.
212 farenheit 185 ohms
160 farenheit 450 ohms
100 farenheit 1600 ohms
70 farenheit 3400 ohms
40 farenheit 7500 ohms
20 farenheit 13,500 ohms
0 farenheit 25,000 ohms
-40 farenheit 100,700 ohms
the FSM is here
the 93 will be close.
http://www.jeep4x4center.com/knowledge-base/index.htm?utm_source=cj#service
click fuse system there.
click on pdf page number. 46/66 BINGO ECT TESTS>
off car tests are easy, in a pan of room temp water then hot the in
ice water.
i do 3 tests. 32F(ice) 79F (room) and 200F (near boiling)
super easy test. ask how. if any step seems confusing.
Jan 04, 2014 | 1991 Jeep Cherokee Limited
Fridge is freezing everything on lowest temp
I believe your Thermostat is bad if you remove it it can be tested with a ohm meter and a glass of ice water. But first when you turn it all the way down it should have an audible click. turn off the electricity/unplug the frig take the plastic housing off to exspose the temp switch take off the elect wires should only be two. put an ohm/volt meter on the two terminals and ck for continuity. at its lowest setting(warmest) it should shut off no continuity as you turn it up it should click and have continuity. let me know if you need further. good luck
Aug 11, 2010 | Frigidaire FRS3R5EMB Side by Side...
I have a 1982 yamaha vision 550 and it over heats iv tested the fan by giving it curent and the fan works fine is there a sensor or fuse that might be the problem
There should be a sensor in the bottom of the radiator that senses the water temperature and turns the fan on when it reaches a certain temperature. There is a sensor somewhere and I'm guessing it's in the bottom of the radiator. Jumper across it and see if the fan runs. To test it, you'll have to connect an ohm meter to it and put it in a pan of water. Slowly heat the water until the sensor changes state. Notice the water temp when this happens.
Jul 20, 2010 | 1982 Yamaha XZ 550
OVERHEATING, ALREADY REPLACED THERMOSTAT,FAN TEMP SENSOR.BUT STILL OVERHEATS. COULD IT BE MY RADIATOR IS CLOGGED? MYB WATER PUMP IN FAIRLY NEW ABOUT 10,000MLS. THE WATER SEEMS LIKE IT GOES AROUND, BUT...
It's possible the relay is at fault if the rediator is not plugged up and the fans are ok. Assumeing you disconnected the fans from the electrical circuits and hooked then direct to the battery to test them. To test the relay i will show you if you have an ohm meter. Connect one side of meter to terminal 30 and the other side to 87 there should be no continuity. Then using 2 jumper wires connect 86 to positive post on battery and connect wire from 85 to negative post. At that point you should feel a click from relay. With the ohm meter still connected to terminals 30 and 87 there should be continuity. Make sure you are still connected to the battery. If any of the test i showed you failed then replace the relay. Hope this will help you.
May 17, 2010 | 2000 Dodge Caravan
How do I test the Pitco Frialator 35CS high limit switch
remove connections from hi-limit switch, and put an ohm-meter across connections then heat it with a match or heat source of that temp range,heat the face and watch your meter it will show open when hi limit reaches cutoff limit/if you need exact cutout temp,you will need to have one of those digital read-out temp gun
Jul 20, 2009 | Imperial IFS40 Deep Fryer
Kenmore HE2 Plus Front Load Washer Logo
50 people viewed this question
Sal DeAngelo
fordexpert
Ed Mac
