Question about Oster OGZB1101 1.1-cu ft Microwave, Black
My ogzb1101 starts, than after a few seconds, shuts itself off
    Top Expert:
  • 14,553 Answers
A question: when it starts and if it has a turntable does that move or not?
Posted on Nov 08, 2012
My oster microwave ogb81005 want heat up
I prefer the Oster OGZB1101 microwave , it has more features, definitely worth checking out.
Jan 18, 2013 | Oster Microwave Ovens
I have a Panasonic NN-SD277S Microwave Oven Initially, it shut itself off after about 3 secs - this continued time after time - then I held the start button down and it shut down completely, almost as if...
I have an Amana Radar range and it did things similar to that. I finally figured it was the circuit board of the buttons and was lucky enough to find another one and replace it..
Jan 26, 2018 | Microwave Ovens
GE microwave (JVM1650wh01) shuts off after running just a few seconds
MOST times this is because of a poor air circulation around the unit, especially those built into cupboards.
Make sure the vents are clear of the back wall and that there is a good airflow. The sensor detects temperature rise in about 20 secs and will turn it off.
If the air vents are OK then I would suspect a fault with the sensor itself. It has possibly shifted away from where it should be positioned( vibration). You may have to remove the outer shell casing and see if its in its cradle.
Please rate my help++++ThaNks for using FIXYA
May 16, 2010 | GE JVM1860 Microwave Oven
I have a sharp microwave mod.#r-1870 you can set it for 5 mins.it will run 59 sec.then shut down you start it right back and it will run 59 sec. and shut down again.
i think there are some problem occured with the autocut n timer....its a genuine prob go to any electrician...thnx
Feb 26, 2010 | Microwave Ovens
No heat and turns itself off after 4 secs
1)Turning itself off can be as a result of the sensor getting feedback of not enough ventilation.Ensure unit is able to breathe by bringing it away from the wall to allow airflow. If that doesn't fix it THEN>>>>>
2) The Magnatron which is the heart of the unit is damaged and so the sensor reads overload and shuts down as a protection against fire.
Repair of the magnatron often exceeds the value of the machine and in your case is not worth repairing. You can buy used ones and refurbished trade ins cheaper than your repair costs will be
Please rate our help to keep the FREE service online++++Thanks for using FIXYA
Sep 13, 2009 | Panasonic Microwave Ovens
GE Spacemaker XL 1800 Micro - " Turns itself off after 2 sec. "
It looks like a component is short-circuited and then it acts to protect. Call a service.
Sep 21, 2017 | GE XL1800 1100 Watts Microwave Oven
Shuts off
change your electrical wall plug to a diffferent one, do not use extention wire pls, there is insufficient to drive your microwave, thats why it resets and restarts again
cheers
Nov 25, 2008 | GE JVM2070 Microwave Oven
Neff Microwave H5470SOGB
if appliance runs for approx twenty seconds this is nearly always a magnetron fault usually a cracked magnet or burnt out anode the electronics are detecting an unusual power fluctuation and shutting appliance down for safety you will need service tech to sort.
Jan 05, 2008 | Neff H5470 Microwave Oven
Panasonic NN-T694SF smoke, shuts itself off
In most cases, this is a problem with the inverter or a bad transfotmer.
Due to the lethal voltages used and produced, I do not recommend that an inexperienced person work on these.
I would recommend that you contact your nearest Panasonic-authorized servicer. You can find one here:
http://www2.panasonic.com/webapp/wcs/stores/servlet/vServiceLocator?storeId=15001
Oct 20, 2007 | Panasonic NN-T694SF Microwave Oven
Oster OGZB1101 1.1-cu ft Microwave, Black Logo
29 people viewed this question
Top Oster Microwave Ovens Experts
William Miller
William Miller
Oloyede Monsuru
ray gallant
Are you an Oster Microwave Oven Expert? Answer questions, earn points and help others
