Question about Polaroid TLA-01511C 15 in. LCD Television
Back lighting invertor repair - Polaroid TLA-01511C 15 in. LCD Television
  • 1,238 Answers
Duplicate question
Posted on Nov 08, 2012
I have sam 51on lcd moniter with dim display problem
The screen displays is dark/ dim because there is no backlight.
There are two parts responsible for lighting the display. First is the CCFL (Cold Cathode Florecent Lamp), which is the back light and the second is the Inverter board, which provides high voltage to the CCFL. Either of the parts can be faulty or in some rare cases both.
In most of such cases that I received for repair, it was Invertor. Inspect the Invertor for any apparant physical damages (burnt coil or circuit components etc). Inverter can be checked by disconnecting the present CCFL and connecting a fresh/ working CCFL (Backlight) before actually removing the CCFL as it is difficult and unnecessary to take it out if its not the fault.
I SUGGEST THAT YOU SEEK PROFESSIONAL ASSISTANCE FROM AUTHORISED SERVICE/ REPAIR CENTER FOR REPLACEMENT OF CCFL OR INVERTER.
Hope it helps! Good Luck!
CreativeTECH
Apr 12, 2011 | Samsung SyncMaster 510N (Silver) 15 inch...
Screen does not show picture just very dim
is this a flat panel monitor? If so it is likely to be eithe rthe back light or the invertor. Invertors are relativly cheap if you can find one - try bitsnpcs.co.uk but if it is a screen gicve up as uneconomical usually.
Good luck
Jul 11, 2010 | HP Pavilion a1610n (882780664463) PC...
Viewsonic N3250W I replaced the power supply board but when I turn on, the screen flashes real quick and there is no picture.
it was not the power supply its the invertor board that controls the back lighting/switch on screen flashes lights go off/shine torch into screen ull see picture/get new invertor board 7 or 8 little plugs go into it
part or repairs in uk ohm supplies
Jan 08, 2010 | ViewSonic N3250W Television
No picture just sound
its the invertor board/open back ull see about 10 little plugs going into invertor get number on board or get repaired only takes one to fail for no picture
Nov 17, 2009 | Westinghouse LTV-46w1 HD 46 in. LCD...
Acer AL1706 A monitor powers up green light is on but screen blinks out
you have a bad power supply, it maybe fixed. you have bad back lights in the screen, usally too expensive to replace with the cost of labor. you have a bad invertor, this will start the back lights. you need to open the rear cover and look at the power supply to see if you can find a burned componet or exploded componet. if you see a bad , burned componet a local electronics repair shop usually can fix it.
Oct 27, 2009 | Acer AL1706AB LCD Monitor
My microwave panasonic starts and then switches off automatically in 15 secs, why does it do that?
if your unit has inverter on it then your magnatron or possibly the invertor PCB is faulty, to determine which you will need to replace either the magnatron or the invertor, or both, which is an expensive repair either way, a DIY repair on either part can be dangerous without the correct tools and training to remove. if you feel competent then post back to me, but you will need a supplier for these parts.
Oct 13, 2009 | Panasonic Microwave Ovens
The monitor i have no longer works the on/off button still lite up but no video.its a gateway model 2100 can it be a fuse?
you probably have a bad back light or the invertor is burned up. you will have to crack open the case and test the lamps from the display ona working monitor, you will have to open that one also. if the lamps light on the other monitor you need to repaur the invertor
Oct 11, 2009 | Computers & Internet
I have audio but no video,after 5 minutes the video comes on. After it is on it will blink off and on for a while.
if its an LCD or plasma tv, it sounds like an invertor problem. (the invertors run the backlights to light up the screen). I would advise getting this repaired sooner rather than later, because if the invertor fails completely, it may damage the backlights and render the TV useless. if it is a CRT (tube) TV, then its possibly a bad solder joint near the HT area of the main board.
Sep 20, 2009 | Sony FD Trinitron KD-34XBR960 34" TV
Light on the screen suddenly disappers
there is a invertor (fluresan invertor) in the LCD. invertor makes your lcd white, bright , lightly.  i think your invertor is breaking down. take the laptop to service.  sorry for my english.
May 27, 2009 | Sony VAIO Notebook
Monitor on a 400 vtx gateway
Check the output voltage of the invertor board , if its 150 volt (point of cold fusion lamp connection) then the drive electronics of the invertor board from the motherboard is damaging the new invertor boards which you are trying to replace. Check input to the invertor board it should be 5 Volts and 12 volts .
Apr 29, 2008 | Computers & Internet
Polaroid TLA-01511C 15 in. LCD Television Logo
12 people viewed this question
Top Polaroid Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Polaroid Televison and Video Expert? Answer questions, earn points and help others
