Question about Compaq Presario Computers & Internet
My compaq presario cq62 wont turn on i bought a new power chord but it still does nothing
  • Compaq Master
  • 5,660 Answers
Shane, new power cord? Does this mean the old one was bad?
Do I assume you used a multimeter;
1) To test the voltage output of the AC adapter (Charger),
2) And had an assistant gently wiggle the cable TO laptop, and power cord TO AC adapter; to see if there was an intermittent reading on the multimeter?
[The Center Hole on the plug end of the AC adapter cable TO laptop, is the Positive connection. The outer cylindrical metal shell of the plug, is the Negative connection.
You should be reading 18.5 Volts DC.
An economical multimeter can be purchased for as little as $5 to $12. Available in a multitude of stores. An auto parts store is but one example. I have seen them on the checkout aisle racks, of large discount stores.
The Positive (Red) probe lead is inserted into the multimeter, in the Red hole that has DC Voltage next to it. (DCV)
The Negative (Black) probe lead is inserted into the Black hole ( - )
The Function knob is set to DC Voltage. If just a symbol, the symbol is a dotted line over a solid line.
IF there is more than one DC Voltage scale, the Function knob is set to the 0 - 50 Volt scale. { 0 to 50 ]
AC adapter checks OK?
Then check the DC Power Jack.
The DC Power Jack is the jack on the laptop, that the cable from the AC adapter is plugged into. (DC_IN)
AC adapter removed, ('Natch), and Battery.
Use a No.2 pencil, and it's eraser, to see if you can gently move the Center Pin, in the DC Power Jack.
ANY perceptible movement means replacing the DC Power Jack.
However good news. The DC Power Jack is NOT soldered directly to the motherboard.
It is a DC Power Jack that has wires coming from it, and the wires end in a small white plug.
This assembly is called a DC Power Harness,
All you have to do is partially disassemble the laptop, unplug the DC Power Harness plug from the motherboard, and replace,
http://www.amazon.com/Harness-COMPAQ-Presario-Pavilion-Series/dp/B004SFQA7U
USE AN ESD wrist strap, and connect it's alligator clip to a good ground source.
I connect to an unpainted surface, of the metal frame of an open, empty desktop computer case.
You can also set a large metal serving plate (Unpainted), on the table you are working on, and connect to it.
Or a large metal knicknack. (Unpainted)
Use a mutli-compartment container for the various screws you will remove.
Label each compartment for the area the screw/s come out of.
SOME screws look VERY similar to other screws.
Advise do NOT mix them up.
http://www.insidemylaptop.com/hp-g62-compaq-presario-cq62-disassembly/
(Just so you have it in case you need it for the future,
http://www.insidemylaptop.com/replace-lcd-screen-hp-g62-compaq-presario-cq62-laptop/ )
HP Support > Compaq Presario CQ62 series of Notebook PC's > Manuals > Service Manual, (Free),
http://h10025.www1.hp.com/ewfrf/wc/manualCategory?cc=us&dlc=en&lang=en&lc=en&product=4188484&
Click on the first file listed -
Compaq Presario CQ62 Notebook PC and HP G62 Notebook PC -
Maintenance and Service Guide
This is a PDF file. The computer you are using now has Adobe Reader on it, which uses PDF files.
After you click on the above file name it may take up to 30 seconds, before the first page comes up.
(The file is downloading in the background)
AC adapter checks out, DC Power Jack checks out?
Check the Power On switch.
The Power On switch is pressed with the Power On Button.
The Power On switch is part of the Power Board,
http://www.ebay.com/itm/HP-G62-Compaq-CQ62-G56-Power-Button-Board-4EAX1PB0000-DA0AX1PB6E0-595204-001-/120845794823?pt=LH_DefaultDomain_0&hash=item1c22f87e07
This part separates the user from the tech. There are 6 wires in that flat cable. (I believe 6) There are 6 contact pins in the motherboard connector, for those 6 wires. TWO of those contact pins turn the laptop on. A tiny flat tipped Jewelers screwdriver, is used to MOMENTARILY touch the two contact pins.
{The Power On switch is a Momentary Contact Switch }
Laptop comes on you have a bad Power Board.
Laptop does not come on;
One or more Power MOSFETs may be bad, and may include bad Ceramic Capacitors (MLCC) for the Power MOSFETs.
Information using HP Pavilion dv6000 series, and Pavilion dv9000 series Notebook PC's as an example,
http://mayohardware.blogspot.com/2010/04/important-parts-on-dv6000-and-dv9000.html
Yes, motherboard replacement
For additional questions, or to have me clarify anything I have stated, please post in a Comment.
Regards,
joecoolvette
Posted on Nov 08, 2012
  • 11800 Answers
SOURCE: This is a Compaq Presario
Simple test to determine if it's a hardware or software problem : try to boot in the BIOS. If you can't then it's hardware you should just return it, it's still in the warranty. If you can then Windows is totally corrupted so just reinstall it.
Posted on Dec 19, 2010
  • 1087 Answers
SOURCE: Compaq presario c700 laptop- unable to turn on laptop
U may have a dead board. They average $285 plus labor. A shop should be able to test it on a volt meter see if the power grid is burnt for around $35. then u will know what ur in for. If its a bad board just replace the laptop I wouldnt repair that problem on an older laptop.
Posted on Jun 24, 2010
  • 214 Answers
SOURCE: I bought new laptop Compaq
Is it Booted perfectly and giving the error after login? Please try to update the CD/DVD Driver. You can use chipset CD which comes with your laptop.
Posted on Sep 23, 2010
  • 18 Answers
SOURCE: How do I hook up
Put the HDMI cable into laptop and tv.
Posted on Dec 26, 2010
ashlocked
  • 1140 Answers
SOURCE: needs the display driver for
Try this buddy :
CLICK ME
KEY : JCCQ-MAKC-KACK-6TSE-BN35
Driver Robot updates:
* Sound card drivers
* Printer drivers
* Video card drivers
* Motherboard drivers
* Webcam drivers
* Wireless drivers
* Bluetooth drivers
* FireWire drivers
* Ethernet drivers
* Windows XP drivers
* Windows Vista drivers
* USB drivers
* Chipset drivers
* AC97 drivers
* DVD drivers
* Router drivers
just install it,scan and download... enjoy...
Posted on Jun 10, 2011
How can I make my Compaq Presario CQ62-112TU laptop a wifi hotspot?
Possibly not compatible witht the software you are trying to run.
Aug 01, 2014 | Compaq Presario CQ62-112TU
Myi phone4 wont charge or sync music on my compaq presario cq62
Are you using iTunes? Are you using the Apple Cord to charge? It may be slow to charge on a computer due to low voltage at USB? Take a look at this : http://www.macworld.com/article/1150356/ipadcharging.html AND this: http://www.pcworld.com/article/260525/how_to_recharge_your_usb_gear_faster.html
Jan 31, 2013 | Compaq Presario CQ62-112TU
Will an optical drive from cq62 fit mine?
NO.
I sort of see your reasoning, but NO.
HP Compaq DC7700 Ultra-Slim Desktop PC, and Compaq Presario CQ62 series of Notebook PC DVD burner drive?
http://www.ebay.com/itm/New-For-Compaq-Presario-CQ62-TS-L633-SATA-CD-RW-DVD-RW-Multi-Burner-Laptop-Drive-/300725349252?pt=US_CD_DVD_Blu_Ray_Drives&hash=item4604a0ab84
Until I compared both units I would have stated NO.
Now that I have THANK YOU. I just learned something,
http://www.amazon.com/HP-Compaq-DC7700-DC7800-DVD-ROM/dp/B004574PEG
Referring back to the photo view, of the Compaq Presario CQ62 series of Notebook PC's DVD burner drive shown, the REAR view shows the connectors for the SATA power cable, and SATA data cable.
The connectors use the same L-shape design, and size that a SATA unit for a desktop computer, would use.
Case design looks to be similar also.
I believe you are Correct.
For additional questions please post in a Comment.
Make all checks out to; The joecoolvette Fund for Having a Good Time
Regards,
joecoolvette
Oct 08, 2012 | HP Compaq Dc7700 Ultra-slim Desktop Core 2...
How to turn my compaq presario CQ62 on if you dont see the icon anywhere
well turning it on is a power switch on the notebook that powers up screen which should either auto start or jump to user panel
restart computer with power button
Jun 02, 2012 | Compaq Presario CQ60-220US PC Laptop
Presario cq62 keyboard not working
Hook a external keyboard to make sure it is working, if yes! the laptop keyboard will need to be replaced.
Mar 17, 2012 | Compaq Presario CQ62-112TU
My compaq presario CQ62 is stuck in logging off mode. I can't turn it on or off. How do I get out of this?
Hi, One thing you can try is disconnect all power soures. Battery and power adapter for 10 minutes.
Then reconnect power and battery. This will reset it to normal. Good luck
Jul 20, 2011 | HEWLETT-PACKARD Hewlett Packard Compaq...
Laptop won't turn on, battery won't charge
I had a similar issue with the Armada M700 from Compaq. Never did figure it out exactly. But I do know this. When you unplug the power chord and take out the battery and plug the power chord back in while the battery is out usually for some reason it turned on allowing me to replace the battery which would then begin charging. Your problem interests me because I can really relate!
Jan 14, 2009 | Compaq Presario 1200 Notebook
Computers & Internet Logo
1,559 people viewed this question
Top Compaq Computers & Internet Experts
Alun Cox
Lee Durbin
Lee Durbin
Are you a Compaq Computer and Internet Expert? Answer questions, earn points and help others
