Question about Canon PIXMA iP1800 InkJet Photo Printer
Clean the ink absorber
I get a message that the ink absorber is full-how do I clean/empty it?
  • 1,031 Answers
The waste Ink absorber is a small, deep sponge, located where the cartridges rest when the printer is idle. Although you can technically reset the counter on the amount of ink held in the absorber, if you overfill it, over time you will start to have color staining on your cartridges, since your carts clean up on it after every cycle, at the extreme, you can have ink residue build up under your printer. Online printer supply shops can sell you a replacement absorber cheap.
. You will need some rubber gloves, rubbing alcohol, and a small prying tool.
1) Locate the absorber at the bottom right of the cartridge path
2) With gloves on, pry up the absorber (if you have the almost full warning, be prepared for some good splatter.)
3) In a small dish with a small amount of rubbing alcohol, shake the absorber around for a short while to moisten the outer ink.
4) Rinse the absorber in a metal sink (porcelain can stain) with more alcohol, then leave it to dry.
5) Replace and make sure the absorber is seated the same as when you took it out.
Then you want to reset the counter for the absorber.
1) Enter the Service Menu by keying = Menu,Scan,Copy,Scan.
2) Use the arrows to navigate to Service Menu Counter Access. then press OK.
3) Use the arrows to navigate to ABS-M Dot Count, press Copy.
4) Use the arrows until the count is zero, press OK then Reset.
5) For good measure, turn the printer off and on.
hope this helps
Posted on Jan 05, 2009
Message about ink asorber full keeps appearing
When the printer is not being used, the print-heads slide to their "resting" position,
in order to keep the ink-jets moist, i.e., to NOT dry-out.
Some ink is absorbed into that INK-ABSORBER.
Now, after a few years of usage, that ink-absorber is "full".
Like taking-out the garbage from your kitchen waste-basket when it gets full, and replacing the full waste-basket with an empty waste-basket, it's time to get your printer serviced -- replace the "full" ink-absorber with an "empty" ink-absorber.
Note that CANON printers do not actually "measure" the fullness -- they electronically estimate the fullness, given information about how much you print, and how often you print, and the "density" of the pages that you do print (text is much less dense than colour-photos).
Mar 09, 2011 | Canon PIXMA iP1600 Printer
Tip
"The waste ink absorber is almost full" message?
This applies to the CANON PIXMA MP130 and other ink-jets made by Canon/Pixma.
According to the user's manual, "Ink used to clean the print head is absorbed by the waste ink tank. When this message is displayed, the waste ink tank needs to be replaced, or the machine requires maintenance". There is no information about how to replace or empty the waste ink tank.
In any case, you can try the following to clear up the error, but eventually you'll need the waste tank to be emptied or replaced. And as far as I know, you can't find the replacement parts to buy, nor the instructions to empty the waste tank.
Turn on your MP130.
1) After that press: Menu - Scan - Copy - Scan or Menu-Copy-Scan-Copy-Copy in some models, it depends on the date it was produced)
2) Select TEST MODE.
3) Enter NVRAM ACCESS
4) Select SET ABS-M LEVEL TO 0
5) Select OK
6) Keep selecting OK untill you leave the TEST MODE
Then turn it OFF and again ON. Check if the error message is still there.
The following is taken from the Canon website, regarding this specific error:
"Canon recommends having the printer serviced before the absorber becomes full. We are aware that there are many "do-it-yourself" Web sites that offer instructions for making this repair. Replacing the ink absorber is a complicated and potentially messy procedure. Even if the ink absorber is successfully changed, the ink absorber counter must be reset. Be aware that if you attempt this procedure, it is at your own risk."
As I mentioned before, I have not found any way or procedure to empty or replace the waste ink absorber nor the necesary replacement part.
on Apr 02, 2010 | Office Equipment & Supplies
Canon pixma ip8500, on third print head in about 4 years. will not print yellow despite repeated head cleaning cycles, now waste ink absorber is full. need instructions for emptying/replacing said...
the waste ink absorber cannot be replaced mate. you have to buy new printer.the waste ink absorber is the sponge part where head cleans all its ink. its a common problem in cannon.
Oct 01, 2010 | Canon PIXMA iP8500 InkJet Photo Printer
How to fix my printer? it has message that the ink absorber is almost full
Not all the ink that leaves the ink-cartridges gets sprayed onto the paper. Some of the ink is "wasted", and ends-up in the absorber (a small sponge inside a small garbage-can).
A computer-technician can empty the absorber (or replace it), and reset the "counters" inside the printer, to tell the printer that the new absorber now is only 0% "full".
Sep 12, 2010 | Canon Office Equipment & Supplies
I keep getting this error message come up, 'The waste ink absorber is almost full - see manual'.what do I need to do as the manual doesnt give details.
In any case, you can try the following to clear upo the error, but eventually you'll need the waste tank to be emptied or replaced.
Turn on your MP130.
5) Select OK
As I mentioned before, I have not found any way or procedure to replace the waste ink absorber nor the necesary replacement part
Mar 22, 2010 | Canon PIXMA MP130 All-In-One InkJet...
Ink waste absorber
Waste absorber is full. Where is the waste ink absorber and how do I empty it?
Apr 08, 2009 | Canon PIXMA iP1600 Printer
The ink absorber is full and printer won't print.
Normally when you get the "ink absorber is full" message, you would take machine to a Canon service center. They will either clean the ink absorbers or more than likely they will replace the ink absorbers. After replacement, the ink absorber full message will have to be reset which is done in the service mode.
Inkworks
866-381-0541
Nov 21, 2008 | Canon PIXMA iP1600 Printer
Waste ink absorber
You'll always find the wast ink absorber under the printer head after printer head prints and rest, there is a rubber type clip which cleans the head and the ink drips down on the cushion absorber. Disassemble the printer and remove the cushion than dip in the bucket of water until ink dissolves out of the cushion and wash under running tap until clean then dry and finish, put back the item and assemble the printer.
Nov 06, 2008 | Canon Pixma MP450 All-In-One InkJet...
Printer message is: used ink tank is full. Q. where is it...and how do I empty it?
The waste ink tank on Canon printers is the ink absorber which holds the ink used during Print Head Cleaning process. When the error message indicates that it is nearly full, Canon indicates that the printer should be taken to the nearest Canon service center to replace the absorber. There is no supported "do it yourself" replacement for this piece of the printer. As per Canon:
This printer has an ink absorber that takes in ink during the printing and print head cleaning processes. The cleaning process is necessary in order to keep the print head nozzles from becoming clogged. Over the life of the printer, the amount of ink that the ink absorber has absorbed is calculated by the printer. Eventually, after substantial use, the printer will enter an error condition when the ink absorber is nearly full. At this point, printing is still possible. Press the <OK> button to cancel the error. You will still be able to print for a short period. To protect the printer from damage, you will not be able to print at all once the ink absorber is full.
If you feel your product might require service, Canon has excellent service options, and we are eager to provide any assistance you may need. Click the link below to locate an authorized service facility and obtain further instructions.
So, to answer your direct question directly, if the message said "nearly full", you can press OK and continue to print for a short time. If it indicated it is full the printer will not function until Canon services the machine and resets the printer.
If this information assists you in resolving the problem, please take a moment to rate the solution at a "FixYa" level. If you do not feel that you can rate at a "FixYa", please post back with more information regarding what has occurred subsequently and/or more details regarding the situation, and I will gladly help you until we have reached a definitive solution. Thank you for using and rating FixYa!
Sep 30, 2008 | Canon Office Equipment & Supplies
Help with absorber
Someone else asked same question on this site and got answer:
http://www.fixya.com/support/t198707-ink_waste
I also had that message. This seemed to work to clear the message and let you carry on printing.
Also, I may be wrong, but the actual ink absorber is the sponge part by the rollers underneath when it prints. I dont know if it has sorted the actual problem, but I took the sponge part out (I have an MP130 and the sponge part lifts straight out if you carefully put your finger underneath it on the left hand side) and let it soak in water, sqeezing it to get the ink out (It was full of ink so careful not to get it everywhere as it can be a little messy). When it had dried, I carefully put it back in (make sure you put it in the right way around).
Hopefully that now means the ink absorber is again empty AND the error message has gone.
Not sure about the whole cleaning the sponge idea, but I did it and according to the manual that sponge is labelled as the ink absorber so technically I have emptied it?
I haven't seen any posts about actually cleaning the sponge so take that part as you will.
Dec 18, 2007 | Canon PIXMA MP130 All-In-One InkJet...
Canon PIXMA  iP1800 InkJet Photo Printer Logo
152 people viewed this question
old marine
old marine
