Question about Kenmore 50522 / 50524 Side by Side Refrigerator
Refrigerator not getting any air, (it is warm), freezer seems ok
The refrigerator is not getting any air - there is no air blowing from the vents. The freezer seems to be fine, it is cold. the unit is about 13 years old. Is there any filters or coils to clean in the back of the unit? I cleaned underneath the unit last night (LOTS of dust etc...)
  • chriscooper Jan 05, 2009
    I did not test with the door switch closed. I'll do that when I get home. I'm assuming the fan is accessible if I pull the refrigerator out from the wall?
    The fan for the freezer is working like a champ. I can hear and feel air when I open the freezer section. Thanks - I'll check it out this evening.
    Sergeant:
  • 311 Answers
So you mean the vents in the refer/frezer sections? yes ok there is a fan in the frezer section that moves the air thru out the box.its called the evaporator fan.you should hear a vissssss sound when you open the doors.some boxes you have to push the door switch closed with finger because fan goes off win door open.test fan with volt meter,should get 110 volts[may have to push that door switch in when testing]if voltage and not turning get new fan.hope that helps God bless ,tom
Posted on Jan 05, 2009
  • Thomas Malailua
    Thomas Malailua Jan 05, 2009
    ok the fan in the back bottem is call the condenser fan.the door switch has no efect on it.if that fan motor is getting voltage and not turning[very common problem]then replace that motor.or if can spin and it takes off then also replace.please dont forget to help with my rateing .thanks tom
Only the freezer side is working
I don't think the darkness is related to the fridge not being cool. The fridge gets its cold air from the freezer through a vent(damper) between the freezer and fridge.The fan in the freezer blows air through it. There is a flap you adjust with the fridge temp. control. Make sure it's opening and closing when you adjust the fridge temp
OR
If the evaporator coils behind the back panel of the freezer are icing up because of auto defrost failure that will stop the circulation of cold air and eventually affect the freezer too.
check defrost timer, defrost heater, defrost thermostat. In most newer models the timer has been replaced by an electronic control board. If the heater and thermostat are ok it’ll be the control.
How to check everything
http://www.acmehowto.com/howto/appliance/refrigerator/refrigerator.php
Aug 17, 2009 | Whirlpool 25.6 cu. ft. Side-by-Side...
FREEZER WORKS BUT REFRIGERATOR SIDE IS WARM
check if fan that blows air to the refridge is working or vent clogged
Jul 24, 2009 | Magic Chef CTB1821AR Top Freezer...
Refrigerator isn't getting cold, but freezer part & ice maker seem to be working OK
The fridge gets its cold air from the freezer through a vent(damper) between the freezer and fridge.The fan in the freezer blows air through it. There is a flap you adjust with the fridge temp. control. Make sure it's opening and closing when you adjust the fridge temp ..
How to check stuff>
Jul 13, 2009 | Refrigerators
Jenn-air JCD2289ATW Freezer perfect but refrigerator is warm
Jul 12, 2009 | Jenn-Air JSD2789GES Side by Side...
Refrigerator is warm @ 60 degrees and the freezer is still freezing happens every so oftern
The fridge gets its cold air from the freezer through a vent between the freezer and fridge.The fan in the freezer blows air through it. There is a flap you adjust with the fridge temp. control. Make sure it's opening and closing when you adjust the fridge temp ..
Jul 08, 2009 | Amana ABB1927DE Bottom Freezer...
Hi, We have a whirlpool eb22dkxfw01 bottom-freezer refrigerator. The freezer part is working OK, compressor is running, but the refrigerator part is getting rather close to room temperature, and...
need to check for ice build up in air vent. if not make sure you hear your evap fan blowing in the freezer section. this blows your cold air into the fresh food side. do you have ice build up on rear wall of freezer section?
Jun 21, 2009 | Refrigerators
Roper refrigerator 2002year
Things to check
Check freezer...
for Frost build up and if Fan is blowing,
Check condenser...
To make sure clean, and the fan is blowing by compressor,
Check Recirclating Vents in refrigerator... to make sure theres no blockage,
CONTROLS ...should be in the middle setting,
Oct 12, 2007 | Roper RT18DKXKQ / RT18DKXKT Top Freezer...
Kenmore 50522 / 50524 Side by Side Refrigerator Logo
156 people viewed this question
Top Kenmore Refrigerators Experts
John Tripp
John Tripp
minguy15
Level 1 Expert
mike cooper
Are you a Kenmore Refrigerator Expert? Answer questions, earn points and help others
