Question about Dunkirk PWB-4D Electronic Ignition, Gas Fired, Hot Water Boiler, NG, Taco Pum
BOILER WONT IGNITE - Dunkirk PWB-4D Electronic Ignition, Gas Fired, Hot Water Boiler, NG, Taco Pum
  • CRAIG BLYMILLER Nov 08, 2012
    Could it be the thermalcoupler?
Boiler won't ignite for hot water unless heating is on.
If this is in a RV the propane monitoring valve may require more gas flow to turn on than the water heater requires. A central heating system requires substantial gas flow so when the monitoring valve opens to fire the central heating, there is enough gas flow to also fire the water heater.
Jan 26, 2016 | Water Water Heaters
Boiler pilot light wont ignite
Try cleaning the end with a brass brush.
Aug 15, 2014 | Water Heaters
I have a halstead finest gold combi when I turn the boiler on the boiler goes into its ignition sequence when it comes to ignite the boiler fires but after the igniter stops the boiler cuts out completely...
Difficult to get too specific without knowing if you have gas or oil. Also, I am going under the assumption you mean the burner shuts down, not the whole heating system. That being said, all heating appliances have whats called a safety curcuit. Each control has the ability to shut down if certain critera are not met. There is a sensor that senses light down the blast tube. If no light is sensed in a predetermined time period, then the sensor cuts power to the burner. This stops delivery of fuel so if it does ignite you wont blow up.
(I suspect that the ignitor and burner shut down simultainously.)
It may be the sensor (cad cell eye) is doing its job, however why is the question. Could be a number of things including the fuel delivery, ignition, improper air adjustment, etc.
No qualified professional should diagnose a problem unless they are in front of the appliance. I recommend you find a licensed qualified heating techician. Hope this helps.
Feb 04, 2013 | Water Heaters
Bosch 25e water heater wont ignite
combi or standard if combi pressure too high and will be blowing off your high pressure release valve which would stop your boiler from igniting best of luck
Oct 27, 2009 | Bosch Water Heaters
Hot water boiler will not ignite
Check all your limit switches on this unit. One of them is either tripped or bad.
Apr 07, 2009 | Water Heaters
Pilot light on boiler
The plumbers repair should be guaranteed, give him a call back.
It sounds to me that the pilot flame needs to be adjusted or the thermocouple is not aligned properly or there is a draft that is blowing out the pilot.
Good luck...
Feb 22, 2009 | Water Heaters
The hot water and central heating wont work together
what size of gas line is going into boiler and water heater? is it black iron ? natural gas or propane? have you checked gas pressure at water heater and furnace ? if they work fine individually then you have a problem with incoming gas pressure. Call gas company and ask them if they would come out and check gas pressure.
Feb 03, 2009 | Water Heaters
Boiler light wont ignite
more likely the thermal coupling is u/s get new one fitted
Dec 02, 2008 | Water Heaters
Lw 50 ci boiler wont fire up
Found out there was a short on the ignation thanks
Nov 19, 2008 | Water Heaters
Dunkirk PWB-4D Electronic Ignition, Gas Fired, Hot Water Boiler, NG, Taco Pum Logo
51 people viewed this question
Top Dunkirk Water Heaters Experts
Donni Steen
Gil Shultz
Are you a Dunkirk Water Heater Expert? Answer questions, earn points and help others
