Question about Karcher 2500 PSI Pressure Washer
Washer wasnt use in over a year when i started using it it work ok not to much power though and then it increased power and then starting blowing alot of black smoke from exhaust. when i tried to start it again after putting new gas it starting back firing and then would shut off.
  • Thomas F. Schneider May 11, 2010
    Black smoke is a sign of "excess fuel".
     Backfire is usually a sign of "out of time"
    I woudl check to see if the flywheel woodriff key is broken or sheared.
    Just a hunch.
  • 18 Answers
SOURCE: Karcher 2400R
You have a poor signal to the spark plug usually caused by a rusty fly wheel found underneath the pullcord casing. clean it with releasing ajent such as wd 40. common when not in use for a while.
Posted on Sep 19, 2008
  • 174 Answers
SOURCE: gas tank leaks, raw gas out the exhaust
Get the leak fixed
Posted on Jul 19, 2009
jmgldsmth
  • 1906 Answers
SOURCE: new Karcher pressure washer won't start
replace the fuel carburetor filter and, or, your fuel tank filter
Posted on Aug 31, 2009
SOURCE: Once the trigger is released it won't starting spraying again.
I have the same problem. This is the responce for Karcher......
The unloader valve may be sticking, or is dirty. It probably needs to be cleaned and may need to be replaced, it is inexpensive. It gets a lot of use, but extends the life of the pump. The function of the unloader is to allow the machine to run in a bypass mode while the trigger of the gun is closed. First, a lack of high pressure can be caused by: 1. Insufficient water feeding to the unit, so check that the water is turned on all the way and that there are no kinks in the hose. 2. The inlet filter may be clogged. (it will need to be removed and thoroughly cleaned). 3. An internal water leak. 4.Also, low pressure can be caused by worn spray tips. If you have checked the first three with no resolution, the problem is internal and could be as simple as a sticking unloader valve. If you are mechanically inclined, you can clean this valve yourself and greasing the o-rings (use lithium based grease), or take it to a local service center. You do not need to take the pump apar
t. The unloader valve is located under the cover, and is secured with 2 bolts. (Use needle nose pliers to remove the valve) For those units with pressure and volume controls, the unloader is located under the pressure and volume control knobs themselves. Do not take any other bolts off or you will open the pump and lose the pump's oil.
Note: Lithium based grease will prevent future failure of the unloader valve.
Also, check websites such as fixya.com for tips and how-to info particularly on cleaning the unloader valve. Be sure to use lithium grease if you reassemble it.
I am going to check the manuel to see where it's at
Posted on Sep 24, 2009
wireguy212
  • 1627 Answers
SOURCE: I have a Husky 2600 PSI power washer with the
You can eliminate the motor by unbolting the pump from it and then if it will start the problem is with the pump or the unloading valve.If it does not start with the pump removed then you check for spark and get the carb cleaned or have a kit put in it.If it does start then check to see if the pump turns freely,if so disassemble the unloader valve and clean and lube it so that the pump and motor can relieve the pressure it needs to when the trigger is not engaged,if the pump can't be easily turned by hand then then pump needs to come apart,dealership should do this.
Posted on Apr 13, 2010
Both the front and back wipers of my 2007 Saturn Vue work, but no fluid comes out, even though it's full, and no sound is heard like it does when out of fluid.
Many possibilities.
Check to see if the electric motor that pumps the washer fluid is working by detaching the hose at the bottom of the washer tank and starting the car & dashboard washing switch ( the multi-switch that controls the washer.)
If you get no fluid squirting out, either the fuse or the washer pump motor is bad.
If it is pumping fluid out there, try hooking a hose to the fluid line and blowing on it to see if fluid will pass through the line, or if it is plugged up ( usually at the nozzle).
If that is clear, perhaps the whole system has lost it's "prime".
Try charging the whole system with water by blowing water from your mouth into the washer lines.
Many cars can lose their "prime" with months or years of dis-use.
God bless your efforts.
Dec 22, 2015 | Saturn Cars & Trucks
Blows fuses, will not run. not used much, 2 years old
Wild guess rust Does it have a tank? does it have a condensate drain? Are you sure the starting condenser is ok? It sounds almost as if the piston is frozen. Sometimes this kind of thing happens to Airconditioning compressors. You might try a "slow blow fuse" and increase fuse capacity. There is a "hard start" kit which is an extra starting electrical condenser so if none of the above helps and no warranty and mine I'd spray a tiny bit of wd-40 into the intake let it sit overnight. try again.
Mar 05, 2015 | central pneumatic 1/3 HP, 3 Gallon, 100...
Generac 15000 watt generator blows 15 amp fuse when it try to exercise
a weak battery will cause the 15 amp system fuse to blow, even though the battery can still actually start the generator.
Nov 29, 2013 | Generac Electrical Supplies
Blower not working
Check all of the wiring connections from your fan motor. If 1 was OK before, there shouldn't be any reason its not now. Closely check the connections going to the capacitor. If they are back to front, the fan wont start, it will sit there humming. If you give it a flick and the fan starts up, it will be that connection.
Nov 25, 2013 | Goodman Heating & Cooling
Whirlpool Microwave MH6700xW-0 Blows internal fuses regulary
Assuming your power line voltage is okay, it would not surprise me that after 27 years, your high voltage capacitor is drying out and increasing its capacitance. This will cause variance in the high voltage output, which can stress the magnetron and increase current consumption.
You can order Whirlpool parts my model number here.
http://tinyurl.com/gv383
For more free DIY and other help & advice, feel free to contact me via my site.
William E. Miller, AS-EET
http://www.microwavecontrol.com
Microwave Oven Control Panel Repair Nationwide
"Recycling by repairing since 1982"
Mar 16, 2017 | Whirlpool Microwave Ovens
I have been using presario CQ50 compaq laptop, it was working fine but as time went on the laptop felt as though it was starting to overheat and would randomly turn off, i wasnt sure if maybe it was the...
are you going to spend hard cash on this junk
its old and worth Zero
now
try a new battery, oops those are expensive.
i see working
presario CQ50
for $30 working
not working worth nothing
its worth at best the cost of potted plant.
why fool with it>? or spend cash on any COMPAQ.?
got to "GOODwill" fine a 10 year or newer system.
best advice of all that. one that works too.
Mar 28, 2017 | HP Compaq Presario 730US Notebook
Ive been putting the cheapest gas for six years and last week i put the 92 gas and last nite i was at a light and it died on me it turns but wont start
it wasnt the gas. they were made to run on the regular. thats not to say there wasnt any water in the gas though
Mar 26, 2010 | Kia Rio Cars & Trucks
Screen washer problem
you can always try to remove the jet and try to blow through it or use a low pressure air line to blow rubbish out of the jet
Jan 24, 2009 | 2000 Jaguar S-Type
Karcher 2500 PSI Pressure Washer Logo
76 people viewed this question
Top Karcher Garden Experts
John Trevino
Harold Baxter
Level 1 Expert
Are you a Karcher Garden Expert? Answer questions, earn points and help others
