W4200hd vertical lines no picture - Televison & Video
  • 1,238 Answers
Pagawa m n s tech
Posted on Nov 08, 2012
TV has blue vertical lines and no picture
I have a 42" Electrograph plasma and it has a 2" black vertical line on the left side of the screen.
Aug 02, 2010 | Electrograph Systems DTS4230 42 in. Plasma...
Tv goes to straight line in center of picture then
It happens when Vertical deflection stops as Vertical Out IC becomes hot or does not get vertical signal.
Please check electrolytic capacitors and dry solder joints in vertical out section in TV.
Aug 12, 2009 | Sanyo Televison & Video
Vertical lines showing in picture, especially noticable on black
in these issue you can see vertical lines due to filter capacitors bad in the secondary power supply. 100micfarad/j35volts, 220microfarad/25volts.
Jun 09, 2009 | Mitsubishi WD-52725 52". Rear Projection...
Vertical line in the middle
not the picture tube; vertical failure. Vertical IC and probably capacitor that caused it to faill. In some cases just resoldering veritical IC pin connections
Jun 28, 2008 | Televison & Video
Is Dell W4200HD Y-Main board and Dell W4201C HD Y-Main board compatible
The port locations do not seem to line up the same so I'm pretty sure they are not interchangeable
http://support.dell.com/support/edocs/systems/w4201c/om/OM.pdf
http://support.dell.com/support/edocs/systems/W4200/W4200UG.pdf
It can be worked on by a local TV repair, then TV was made for Dell by Philips
Jun 12, 2008 | Dell W4201C 42 in. Plasma HDTV
Vertical size of picture
You have a number of bad capacitors in the vertical circuit. If you can solder, you should be able to repair this yourself. I'll look up your model to get the parts needed.
Dan
Jun 02, 2008 | Toshiba 36A50 36" TV
Insignia LCD 27" w/vertical lines for picture
Happens with mine also usually happens when you change channels alot all you need to do is shut tv off and turn it back on.
Mar 09, 2008 | Insignia LCDTV26 26 in. Television
42" LG Plasma with 4" vertical lines at each end
LG service is non- existent . The only solution that I can suggest is "Give a wide berh to LG products. Dont ever touch any"
Mar 07, 2008 | LG 42PX5D 42 in. Plasma HDTV
Lines on tv screen
Picture displaced vertically, picture too high or low
This problem was cured by entering the service mode (menu then 4,7,2,5), then pressing the green fastext button to access geometry settings, selecting VP1 (vertical position) and adjusting as necessary
Vertical line at the left of the picture
Replace L506 on A board, replacement part number 1-407-366-00
Nov 26, 2007 | Televison & Video
Televison & Video Logo
16 people viewed this question
Top Televison & Video Experts
Electro Med Services...
