Rolling Horizontal lines
Hitachi 60" rear projection tv
  • don64nie
    don64nie Nov 08, 2012
    Could be the converter going bad.It sounds like a tracking issue. What do you have hooked up when this happens?
  • danak3460
    danak3460 Nov 08, 2012
    stereo receiver, playstation and dish receiver are always hooked up and the roll is always there no matter what we're watching or how.
  • 1,238 Answers
OK that is the clear indication of bad signal board..
Try to search that in ebay or shopjimmy.com
Posted on Nov 08, 2012
SOURCE: Hitachi 60 in. 60V715 Yellow Haze
A friend suggested I use windex and clean the mirror,lens, and screen. Would that help?
Posted on Jan 03, 2008
ctf1800
  • 4402 Answers
SOURCE: cleaning tv screen of hitachi rear projection tv
http://serviceman.site88.net/index.htm
Posted on Jul 07, 2008
daniel719
  • 240 Answers
SOURCE: 53 Hitachi Ultravison TV : Getting Horizontal lines rolling up
ok
this is called viedo noise
you will need to replace capisitor Cc10 its Value is 1000uf @ 16v the cap is a filter On Sw +9v Line , on pin 20 of Ic01, ( or corma Jungle IC)
Posted on Jan 12, 2009
SD Tech
  • 14553 Answers
SOURCE: the picture is rolling up horizontally from the
Ok, I own the exact same set--it uses a Vertical output IC located near the front of the main board number on it is LA7638--cheap part.
if you pull off the front speaker grill and remove the inspection plate you will see it almost dead center and a little to the left screwed into a small metal plate with fins--that is a heat sink--lots of these sets had or developed bad solder connections on the pins of this ic---the way I found mine was to remove the speaker grill and inspection plate and with a non metal plastic handle from a screwdriver tapped on the heatsink when the set acted up--if it clears up when you tap on it you have bad solder connections on the IC---if I remember it has 13 pins---with the trouble to get the board out to solder it up I just replaced it with a new one--the part can be purchased for less then 5 dollars at most electronics parts dealers or on the internet---My other Hitachi is a 1991 60 inch model and it has never given me any problems--by the way the 50 in the model number means it is a 50 inch set.
If this helps you give me a vote here--I do this for free--good luck.
Posted on Aug 18, 2009
Testimonial: "Thanks - I beleive I've found the part - diff part#,16 pins, but exact description. Thank you so much - greatly appreciate the EXPERT free advice!"
johnnydiode
  • 647 Answers
SOURCE: Broken screens on 53'' Hitachi rear-projection TV
I think it would likely work if you trimmed it evenly around the sides in order to maintain the central position. Focus may have to be adjusted but thats all.
Posted on Oct 25, 2009
Testimonial: "Thanks."
Why do I have rolling horizontal lines on my hitachi big screen t.v.?
Need the model number of the Hitachi which should be listed n the rear cover. I should be able to assist but will need the Model Number to determine which chassis design you have.
Apr 02, 2013 | Hitachi Televison & Video
My Hitachi 60v500 will not turn on. The lamp light remains "on", does that mean the lamp light is out? I tried turn on the TV several times and even disconnected the TV and all I get are the...
Your TV is at protection mode. It mean there's problem on it. The indicator provide your information that he detected short circuit or fault circuit. Your power supply and the regulator are working normal. Since you have problem on the other circuit Like Horizontal out the one producing high voltage. Or in the Vertical section This the IC type can have problem on it too. If you know this section you can now assume where will you begin troubleshooting. Occasional problem in the H- out transistor had a defect probably shorted or open or leak. While in Vertical Your problem will one horizontal line if the IC short circuit a call for protection circuit. And Also The Convergence circuit will make power interruption also. If you know this section then you can do it.
Aug 14, 2011 | Hitachi 60V500 60" Rear Projection...
Tv comes on and then after a while the picture goes down to this scrunched up color lines in the middle of the set and sound goes off also. It is a Hitachi 60 inch big screen 1997 model
Sounds like you have broken solde joints on the vertical/horizontal board. I have a tip at http://www.fixya.com/support/r4751428-fix_no_vertica_drive_problem which explains the problem and how to fix it. Let me know if you need more help.
Thanks for using FixYa and for the generous rating.
hardrocko
May 12, 2010 | Hitachi 60V500 60" Rear Projection...
Horizontal lines across middle of screen sometimes
Vertical problem coming from bad solder, or vertical circuit problems!!!
Check for bad solder and capacitors problems in vertical circuit.
Aug 30, 2009 | Hitachi 60SBX78B 60" Rear Projection...
ok
Dec 30, 2008 | Hitachi 53UDX10B 53" Rear Projection...
Vertical rolling on Hitachi 60SBX78B
It ended up being the Verizon Fios box. We recycled it and the picture stopped rolling. Thank you for being here to help. If I have any future questions, I'll definitely use your site.
Mar 07, 2008 | Hitachi 60SBX78B 60" Rear Projection...
Hitachi 60 in rear projection tv
If the picture is jumping from top to bottom this is a vertical issue. The common cause on older Hitacjis is loose connections on the vertical output IC.
Jan 28, 2007 | Hitachi 60EX01B 60" Rear Projection...
Televison & Video Logo
Top Televison & Video Experts
Electro Med Services...
