Question about Kenmore 62602 Electric Dryer
110.66752501 dryer won't heat
hunter19_46m
  • 7482 Answers
SOURCE: electric dryer won,t heat/replaced heating element
Hi galepezz...
Here are a few things to check:
ALWAYS UNPLUG YOUR DRYER BEFORE ATTEMPTING TO DO ANY WORK ON IT.
Check to make sure you are getting full 220 Volt power to the dryer, if you are then:
Check your Wiring
Often the main wiring connection from the house, at the dryer, burns and the connection breaks. If this has happened to your dryer, you need to replace the power cord and the terminal block inside the dryer to which the wire is attached.
Check the Door Switch
If the door switch or the door-switch actuator is defective, the dryer won't work and you need to replace the failed component. The switch is inside the dryer main housing near the door frame. Sometimes you need to raise or open the top or front of the dryer to reach the switch. Check for continuity you should have none with door open, and should have a reading when closed. If not replace the door switch.
Check to make sure you heating problem is not a lint build up in the discharge hose or the dryer,as this condition can cause heater/thermistor problems such as overheating of the heating coil leading to failure of the coil and burnout of the thermostat/thermistor due to overheat.
Remove the back/or front just under the door of the machine and try to locate the air duct going from the blower to the drum. Normally inside/outside the air duct you will find the heating coil and the thermostats/thermistors. Once you have located the heating coil, remove the two wires from it and check the coil with an ohm meter across the two terminals of the coil.
You should read continuity across the terminals, if not you will need to replace the coil as it is faulty.
If the heating coil is ok, then:
You can check the thermostat/thermistor one at a time by removing the two wires and taping them together with electrical tape.
If the coil heats up then replace the thermostat/thermistor/thermal fuse as it is faulty.
If you have an ohm meter then you can test the thermostat/thermistor/thermal fuse,
then you do not have to tape the wires together as described above.
To test your thermostat/thermistor/thermal fuseremove the wires from the thermostat/thermistor/thermal fuse and check for continuity, if you DO NOT have continuity then replace the thermostat/thermistor/thermal fuse.
DO NOT LEAVE THE WIRES TAPED TOGETHER AFTER THE TEST AS THIS COULD CAUSE A FIRE BECAUSE YOU HAVE REMOVED THE SAFETY.
Check your blower wheel to make sure it is secure to the shaft and not plugged with lint,socks,etc.
If the thermal fuse overheats the dryer will not operate. It's located on the blower housing. It cannot be reset. A vent clogged with lint can cause it to overheat. You can test it with an Ohm meter or continuity checker, if no continuity, replace it.
Right after replacing a dryer element, always run the dryer on 'air fluff' / 'no heat', and go outside to verify there's plenty of air coming out your vent system.
If the vent's clogged, that new element can burn out very quickly.
Please take time to rate me
Posted on Jul 26, 2011
hunter19_46m
  • 7482 Answers
Hi galepezz...
Check your Wiring
heatman101
  • 43501 Answers
SOURCE: dryer won't heat I've replaced the heater element
Hi, If you are having problems with your gas dryer not heatingthe most common problem is that the ignitor goes bad. Even though it glowssometimes it is still not working properly. if you dryer is gas check out this gas no heat tip.... If you have an electric dryer, you can have many differentthings that can go wrong causing the dryer not to heat. check outthis electric no heat tip...
heatman101
Posted on Sep 12, 2011
Testimonial: "Thanks alot for the info and diagram. All other diagrams I could find online said the thermal fuse was the thermal cutoff so I changed the wrong part."
SOURCE: 86870100 Kenmore dryer won't heat but goes through cycle
Dear Diane Bassett,
I recently had a problem of the exact nature. The answer to your second question is yes, these are awkwardly located at the rear of the machine, so you will have to pull the dryer out from its recess. isolate the dryer from the mains for an hour or so, press the reset button in for a few seconds and you should be fine.
If that doesnt solve the issue, then your thermostat is up dawsons' creek without a paddle.
Anway I hope this is the fixya for you and I look forward to hearing how you get on with this.
Yours sincerely
Ouszen
Posted on Feb 07, 2012
  • 3 Answers
SOURCE: My dryer won't heat up
You can try the heating elements. First unplug the dryer and you will have to take back panel off. You need a Volt Ohm meter to do a resistance measurement. Place the leading one each end of the elements and the reading should be close to "0". I'm thinking if the dryer is old the heating elements has burned out.
Posted on May 18, 2012
My Maytag gas dryer won't heat
Hello Todd,
Their are several things that could cause the dryer to not heat, i have posted a tip i wrote what to check whena gas dryer doesn't heat
http://www.fixya.com/support/r10293028-gas_dryer_not_heating
GENE
Nov 12, 2011 | Maytag Dryers
Whirlpool supreme lhi 5801 won't heat. The coil turns red but won't ignite anything. I'm pretty sure the gas is on. I don't know what else it could be...
heatman101
Sep 03, 2011 | Dryers
Won't heat up
If it won't heat it will be either the heating element or the thermostat or the control board.
Aug 28, 2011 | Whirlpool GEW9250 Electric Dryer
The dryer runs but won't heat up
heatman101'
Aug 02, 2011 | Whirlpool WED5300S Electric Dryer
Kenmore dryer won't heat up/
heatman101][\[]\--='
Jul 24, 2011 | Dryers
2005 Whirlpool Gas Dryer. It won't heat. The coils won't glow. Had the fuses, ignitor, and coils checked and are ok. Could it be the timer? How do I check it?o
heatman101-
Jul 22, 2011 | Whirlpool LGQ9858P Gas Dryer
I have A kenmore elite gas dryer model # 110.75062501 it won't heat please help
heatman101;'
Jul 18, 2011 | Kenmore Dryers
Had this dryer for a year just not heating dryer is turning but won't get hot
heatman101';
Jun 23, 2011 | Crosley CDE6000 Electric Dryer
Maytag MDG8057 dryer won't heat. I unplugged the dryer to use the outlet for something else, plugged it back in, and now it won't heat. Any connection to unplugging it? If not, potential...
Did yall move the dryer? The ignitor is very brittle. Moving a gas dryer sometimes breaks an ignitor with a little age on it.themobilian_2344.jpg
If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
May 11, 2011 | Maytag Dryers
Kenmore 62602 Electric Dryer Logo
94 people viewed this question
Top Kenmore Dryers Experts
Sal De
Tim Whalen
Are you a Kenmore Dryer Expert? Answer questions, earn points and help others
