Question about Sewing Machines
I have a macro hoop (ma) for my Janome 11000...how do I split larger designs and put this hoop to work
  • 185 Answers
SOURCE: 180E Hoop problem
Joan, there are 3 micrositches on your embroidery unit arm. these switches are depressed when you attach the hoops, it appears from your comments that one switch is not functioning. This could be simple, it is out of alignment or more complex it is broken. Either way you need to take it to a professional for repair.
Posted on Feb 25, 2008
  • 185 Answers
SOURCE: bernina deco 600
Sorry to inform you but your machine only sews 4" x 4" . The arm on the machine can only move 4 inches up and down and 4 inches left and right.
The size of the hoop does not affect this. If you have a multi position hoop you can sew multi 4 x 4 areas without re hooping.
Posted on Feb 28, 2008
bargainbox
  • 1388 Answers
SOURCE: I'm looking for a
Ask at your local Janome dealer, or find your local dealer at the janome.com Store Locator in your home region.
Posted on Sep 08, 2009
SOURCE: strange noise from the lever that connects the hoop to carriage
Is this where the belt would be also, because my arm bumped the wall because it did not have enough clearance and it jumps and clicks when returning to home.
withtlc@mchsi.com debbie
Posted on Jun 21, 2010
  • 161 Answers
SOURCE: Hi, I have Janome m.c.
i think you'd have to connect the patterns manually, such as using a clothe setter as i don't think this machine has the reach of other machine
Posted on Sep 13, 2010
Exceeding embroidery area design is smaller than 200x140
Not sure if understanding your question. Guessing your design does not fit within the hoop. Generally, the size of the hoop needs to be slightly larger than the size of a design because the hoop needs to allow space for the presser foot to manipulate within the space. You may need to use a larger hoop or shrink the design.
Nov 29, 2017 | Sewing Machines
My bobbin thread is part of my embroidery on my memory craft 11000
you may have the fabric not tight enough in the hoop or try using the same colour thread in the bobbin
Nov 02, 2014 | Janome 11000 Memory Craft Special Edition...
My 9700 shows hoops a and b but I have a gigahoop and do not know how to program my machine to reconize it
Your machine will only recognize the 5x7 hoop. The giga hoop is two 5x7 hoops next to each other. When you pull up the design on the screen it will show 2 hoops. Each hoop will be one half of the design. One design will be upside down from the other. That's the way it should be. After stitching out one side of the design, turn the hoop, and stitch the upside down part.
Dec 30, 2010 | Janome Memorycraft 9700 Computerized...
Strange noise from the lever that connects the hoop to carriage
Sounds like you may have a belt problem or possibly an object in the carriage system. Underneath the free arm there is a cover that can be removed so you may inspect the area. I would remove it and take a look, maybe you will be lucky and find an object there that is causing the noise.
May 31, 2010 | Janome Memory Craft 10000
Does this machine have a low shank --- or high shank?
High Shank Machines are all the Janome Embroidery models MC 8000, MC 9000, 10000, 10001, 11000, 200E, 300E, 350E....etc
If yours is not an embroidery machine, it has a LOW SHANK .....the higher shank allows for easier access for the embroidery hoop
Bargain Box
Apr 19, 2010 | Janome Memory Craft 9000 Computerized...
Is this machine a high or low shank? I'm trying to buy a 1/4" quilting foot or seam foot and not sure which foot to buy.
If yours is not an embroidery machine, it has a LOW SHANK .....the higher shank allows for easier access for the embroidery hoop.
Nov 12, 2009 | Janome 8080 Computerized Sewing Machine
I'm looking for a "sw" hoop for a Janome 11000. I can't seem to find them on-line. Do you know a site where I could find one?
Sep 07, 2009 | Sewing Machines
Formating memory
You need to format the usb stick in the machine itself, don't use a high memory one or one that has a partitioned area. 1 gigabyte or lower. You need to use the set icon on the machine and arrow through the pages to find the Format screen. Select the tab for USB device. Then click yes to the prompts, that installs the correct folder system. Now the software end,open easy design and select machine from the top toolbar, set machine type to 11000. Open a design and use the file drop down menu and select Save As, choose JEF in the file type bar, you will see a button below Save , Delete, called options, click on it, you'll find a list of machines, set it for the 11000. It is that selection that saves the design in the correct format. There are 2 jef formats, the old Jef for the previous machines and the enhanced Jef for the 11000. Now rename the design, open the flash memory menu and in the right hand pane you should see your usb flash drive, if it's the only one you have connected all well and good, if not click on each flash drive to find the correct one.You'll know which one it is,because in the window below you will see an Embf folder, open it, you must always open the Embf folder before writing a design, now some have child files inside, emb, if so open that as well , don't create a new folder it wont be read by the machine. Now write the design to the usb flash drive. Do you have a copy of the PCtools software? if so you need to download the update as it's that software that allows 2 way communication between the machine and the computer. Keep an eye on how many designs you insert into the internal memory, it isnt very big. You shouldnt need to reformat the internal memory,
Jan 08, 2008 | Janome Memory Craft 10000
Sewing Machines Logo
81 people viewed this question
Top Sewing Machines Experts
Tally Girl
Tally Girl
Chris Wetmore
Are you a Sewing Machine Expert? Answer questions, earn points and help others
