I have made all connections re 'phone line up to connecting to tower - I can't connect as cable too short - what am I doing wrong? Should I be connecting via the back of the tower? I only have one connection/port to modem.
  • Dan rogers
    Dan rogers May 11, 2010
    It sounds like your phone cable is too short. Is this the problem or do you just want to know where to plug it in?
  • Stephen Scheneman
    Stephen Scheneman May 11, 2010
    I don't understand what you are trying to do...Please give a more detailed description of your situation.
  • 31 Answers
You should have a modem installed in the tower portion of the system. It will have phone jacks. One is marked LINE the other is usually Phone. The Line or Wall jack plugs into the phone jack on the wall. if there is a phone plugged already, unplug it and plug it into the modem jack marked phone. Cord lengths are chosen to suit need. Radio Shack or the like have long cords if needed
Posted on Jan 07, 2009
Need help! Cannot access YAHOO and FACEBOOK,Thru tp link wired router (TL-R402M). Hope you can help me with my problem. Thanks! Jun Santos
try power cycle by removing the power of the router for one minute then plug it again. check the cable if all of it tightly connected to the specified port if it is a modem router it should have a 3 cable connected to it Phone line, Ethernet cable and the power adapter. the Ethernet cable should be connect to the back of your tower( computer). check you phone for a dial tone. check the light in the router like dsl , ethernet ,internet and activity. all of these must have a light.
Apr 14, 2011 | TP-LINK TPLink 4port ADSL2 Wired Route...
When a call comes in it rings one time then stops
This is often caused by a partial short on the phone line. I would first test the line at the incoming interface. If this is a standard phone line(not from a cable company or broadband provider), there is usually an outside interface box where the phone line connects to the building wiring. Open the right side of the box with a screwdriver. In this box there is typically a short line cord plugged into a modular jack(test jack), if you unplug this line cord and connect a standard phone, you will be connected to the phone line but isolated from the building wiring. Make a test call to your number with the standard phone connected to the test jack and if the problem continues then the trouble is on the phone service provider's side and you will need to report the trouble to your service provider. If the trouble does not occur with the phone connected to the test jack, then the trouble is on the building side. To find where the trouble is on the building side you will need to use a process of elimination to test each of the outlets, line cords, telephones and cabling to determine where the short is. This process can often take a lot of time and patience to find the trouble. It may be best to call a telephone tech at this point. If your service is from a cable company or broadband provider, then you will need to test the line at the equipment that converts the cable or broadband into dialtone to determine if the trouble is on the service provider side or the building wiring side. Send a comment if you need more information on finding the trouble in your building wiring, outlets or telephones.
Mar 27, 2011 | Panasonic KX-TGA510 Cordless Phone
Thomas the train misty island deluxe set instructions
Starting at the wood cut tower moving clockwise. Tower is 6. 6 to 7 to 8, L2, 9, L4,10,L5,11,fits into tree trunk, 14, (12 connects to the junction) 1, 2, (joins to 13 from the log over.) L5, 3, L4, 4, L4, 5, connects to 6, the tree tower.
The logging tower rails. Connects from 4 to 18, then the tall tower, the rail, the small tower, 17, L2, 16, L4, 15, the tall tree tower, 14, L4, 13 and that connects to No. 2.
L2 is the lowest support. L4 is the middle size. L5 is the tallest.
Nov 28, 2010 | Toys
I got a new computer EMachine. I wanted to hook up my Brother MFC 420 using my CD, but no luck. Maybe I have it hooked up wrong. My last computer had a telephone line hook-up. but new one doesn't. I...
Hello s_fields75. I just read your problem and was wondering if you checked your cable connections. You stated that you may have hooked it up wrong. I would definitely make sure your cable connections, USB, etc., are correct. The printer is an all-in-one and should just automatically find the connection through your modem for the fax feature. If not, you might need to get a splicer for your phone line (you can pick one up at radio shack for less than $10). Unhook your phone line from the wall jack. Plug in the splicer into the wall jack, then plug the phone cable into one jack and your fax phone cable into the other. That should do the trick. If not, you may need to download an updated driver from emachines or brothers' websites. Hope that helps!
Sep 22, 2010 | Brother MFC 420CN All-In-One InkJet...
My Dell dimension 2400 monitor doesn't work when connected to my tower. It appears that it's off when I connect it to the Dell Dimension 2400 tower, but when I connect the same monitor to another computer,...
Hi! For dell machines when u unplug the video cable/VGA from the tower while the system is on it will show monitor self test.If you are seeing a black box moving around the screen it means that monitor is ok.Check connection between monitor and tower.Make sure cables are securely plugged in.Check if the tower is ok. There is a possibility that your monitor is ok but the tower is not.check the power button (whats the color) if amber/orange, this means there is something wrong the the tower. If its blue or white it means its ok.Also check if you are going to hear one beep, it means system is booting up properly. If tower is ok and you are using a expansion video card then try to use internal one, normally its the vga port above the usbs.If you are going to use onboard video card make sure you enable it first in bios.If all things fail, contact your manufacturer, if the system is under warranty then they will send a tech to check the machine.hope this helps...
May 28, 2010 | Dell Dimension 2400 PC Desktop
7940 cisco ip phone being powered by a power brick seems to loose power when connected to the ethernet. When ethernet is disconnected, power comes back. Ethernet works fine when phone is not connected. No...
Change out your cable from the wall drop to the phone. A Cisco phone is capable of receiving inline power (Power Over Ethernet) via the blue and brown pairs of the cable. It sounds like you may have a cable with a short in either the brown or blue, or both pairs, shorting out the power when it is connected via ethernet.
If you can, have your IT Tech check the cable, and the line through the wall to the switch.
May 26, 2010 | Cisco 7940 IP Phone
Is there a power cord that i have to connect to my soundbar to this little short wire an if i have to connect to the tower how its to short
Yes there should be an adapter that it goes into. One cable with green connector goes into the back of PC the other short connecter into the ac adapter model no 12150bs.
Feb 27, 2009 | Dell AS500 Sound Bar Computer Speakers
I have a Lexmark 5150 all in one.I recently hooked up to broadband.I cannot use the fax now. It says no communciation. How do I get my fax machine to work again? The printer and scanner work fine.Do I have...
Hi Brenda,
Your All In One wants a phone line hooked directly to it. It won't fax without a "POTS" line directly hooked to it. POTS stands for "Plain Old Telephone Service" which is the line with good old dial tone on it.
Dec 17, 2008 | Lexmark Computers & Internet
I have lines and my compter in not right
The step , you can do to check if the problem is with the computer tower or only the monitor is
1. Unplug the signal cable ie connected from the monitor to the computer tower.
If the lines are still there after disconnection of the signal cable there could be a problem with the monitor.
2. If the lines go away , try reseating the cable and check
Thanks
proton
Oct 01, 2008 | Packard Bell Computers & Internet
When i try to fax it says no phone tone someone is on the phone
Well as you have spent two hours with dell, i am sure everything would have been checked, However lets make sure that we have the connections right.
Your DSL must have 2 outlets, 1 which will be connected to the Phone and the other one which should be connected to the DSL Modem. 1 is voice and other one is Internet.
So make sure that you have plugged in the cables correctly. You may try changing the cable and the ends to check that.
Another point is that at the back of the tower you would have two ports for tel line "Line and Phone", so make sure that you have connected the phoneline to the jack which says "Line" NOT THE ONE WHICH SAYS "PHONE"
Pull out the cord from the Tower and plug it in a phone and check that you are getting a dial tone.
I hope that this should resolve the issue you are facing.
Thanks
Sammy
Nov 28, 2007 | Dell A940 All-In-One InkJet Printer
Computers & Internet Logo
51 people viewed this question
David Payne
David Payne
