Question about eMachines T5212 PC Desktop
Have emachine T5212. Won't recognize when a disc has been loaded
After loading disc in DVD drive, and going to explore option on start menu, the disc is not showing as being in the drive tray. LED flashes and I can here the disc begin to spin, then it shuts down.
  • 39 Answers
If this happens for every disc inserted (make sure that it's not just a scratched or dirty disc.), the laser lens probably needs to be cleaned. Since this is a desktop computer, you can't get to the lens very easily. Open the tray and use a can of compressed air to blow out the inside of the drive. If this fails, you can buy a lens cleaner disc and try that. (Some manufacturers don't recommend this, but I've never experienced any issues with it. Just be sure that the disc is made for cleaning CD/DVD drives.) The final option is to remove the drive from the PC case, remove the cover, and GENTLY clean the lens with a q-tip and alcohol. If all else fails, optical drives are extremely inexpensive, and very easy to replace.
**Note:Removing the case from the drive will void any applicable warranty.
Posted on Jan 05, 2009
Can't install windows
If there is a boot menu you may have to load the CD drive from there and the restore disk will load. Check the boot screen when the PC is first turned on and look for restore option and which key to press. It is usually F10 or F11. If all else fails press F8 on start before the first boot screen vanishes and select the prompt option. then load the CD from there after you ID the drive letter.
Sep 16, 2012 | E-Machines eMachines Desktop PC
Emachines W3619 won't load ntldr
Take a windows XP CD, Switch on your PC and go to "BIOS" menu and select "Boot From CD/DVD" whichever is applicable for your pc.
Now insert the Win Xp disc i drive and start PC, Boot the Pc From CD Drive and you shall get the Blue screen of windows Installation. Restart the PC by hard pressing the power button for 30 secs.
Now you will be able to login to windows.
Dec 02, 2011 | eMachines W3619 PC Desktop
I have a Emachine T5212 and im trying to reformat my hard drive but my internal dvd drive is not recognized.I brought an external dvd drive,but everytime i try to erase my hard drive it tries to load from...
First you need to have media ready to install once format is compelte.
You can not format a drive you are currently using an operating system unless you run the operating system setup disc in which case you would be booting and running from cd once you start reloading you main drive.
So if you are loading windows .
Review steps below if when you boot you do not have option to select boot device
Boot you laptop / pc and get into the BIOS
<normally f2 or f8 , f12 depending on system.>
Change the BOOT order to cdrom as primary \ you may see the device as USB CD/DVD rom with the actual name of brand there.
Save and exit
Have operating system in cd/dvd rom attached to device
Once it starts to load you will see BRIEFLY in the upper left corner PRESS ANY KEY TO LOAD FROM CD ROM or something similar... stop reading this and press a key ........
From there it should prompt you for setting up a new os, I prefer linux myself but in windows or linux in the setup process you have the option of just loading the operating systems or DELETING THE PARTITIONS and FORMATTING the drive, therefore wiping i .
NOTE: THIS IS NOT WIPING YOUR DATA, if you are trying to hide something, wipe from your drive past **** you never wanna share with anyone again..... repost under how do i wipe my hard drive clean .. its a completely different story .. not hard but different.
Jul 24, 2011 | Computers & Internet
EMachine T2778 new hard drive, restore disk aren't working, how do I format?
1st Option: Go to BIOS level and select the CD/DVD device is the first device for boot option and then insert the recovery CD/DVD to format or install OS.
2nd Option: If recovery CD/DVD got curropted and you are having the other OS CD/DVD, then try to load and format or install the OS. Also try to download the recovery image from vendor website.
Revert back for more assistance.
Jan 31, 2010 | E-Machines eMachines Desktop PC
I have a Toshiba Satellite Pro 4600. The DVD drive has stopped working, It works correctly with a lens cleaner disc. but when I try any other disc I get the following message '' windows cannot read from...
Load a CD in the drive then go to My Computer and right click on the drive letter. Now click on explore and see if it opens the folders on the CD. If it can not read the CD files then you may need to replace the drive. Check that the driver is properly loaded and windows recognized the drive properly. Control Panel-System-Hardware-Device Manager then select the CD Drive to see the status of the driver. If it has an error you may need to replace the driver. Another thing to do is go into the Bios setup when starting the computer and see if the Drive is recognized properly. While you are in the Device Manager look at the tab for "Region" which should be set for Region 1. If it is not set for 1 it would cause this problem. Good Luck
Dec 09, 2009 | Toshiba Satellite Pro 4600 Notebook
CD drive not working
Based on your indication the CD drive is clean, and you know the cables are attached to it, inside the computer. (Flat ribbon IDE interface cable, and 4-pin Molex connector power cable)
1.Go to Device Manager
Left-click on Start. Right-click on My Computer. Go down, and Left-click on Properties. Left-click on the Hardware tab. Go down, and Left-click on Device Manager.
Left-click on the + sign to the left of, DVD/CD-ROM drives.
Right-click right on the name of the CD drive.
(Example: Lite On DVDRW LH-20A1P.
eMachines Support indicates the T5212 has a DVD burner drive, and a CD drive. Right-click on the CD drive name))
In the drop down list, Left-click on Properties.
Left-click on the Driver tab
Go below, and Left-click on the Update Driver 'button'. Now go below, and Left-click on OK.
Close all windows, go back to your desktop screen.
Shut your computer down normally. (Start>Turn Off Computer>Shut Down)
Do Not Restart. We need a 'Hard Shut Down'.
Wait 1 minute, turn your computer on.
Still doesn't work?
Let's play hard ball.
2.Go back to Device Manager. Left-click on the + sign to the left of DVD/CD-ROM drives. Right-click on the name of the CD drive. Left-click on Properties. Left-click on the Driver tab.
This time go down, and Left-click on the Uninstall 'button'. Go below, and Left-click on OK
There will be a Microsoft 'squawk box' that comes up. "Warning you are about to uninstall this device"
Left-click on OK. (It IS okay!)
Close all windows. Shut down your computer normally. (Again, we need a 'Hard Shut Down'. To Restart a computer is known as a 'Soft Shut Down')
Wait 1 minute. Turn your computer on.
After Windows loads all the way, and all of your Start Menu programs have loaded, you should see a pop-up out of your system tray. (Bottom of Windows desktop screen)
"Found New Hardware", and perhaps another one, "Found XYZ CD drive". (XYZ = the CD drive name)
No still?
The driver for your CD drive, is located within the Windows XP operating system on your computer.
If your CD drive does not work now, I suggest it has failed.
Drives such as Optical drives, and Harddrives, are mechanical devices. Their 'Lifespan', is rated in so many hours of usage. Your CD drive may be at the end of it's 'Lifespan'.
Oct 04, 2009 | Sony VAIO PCV-RX462DS PC Desktop
My dvd wont play any dvds emachine t5212
check to see if the little video wire is hooked up inside to the dvd player.
Apr 21, 2009 | E-Machines eMachines Desktop PC
Replacement DVD-ROM drive
Hi there.
get hold of a boot cd or a windows install disk, set the boot options to boot from the cd drive, if the cd or dvd starts to boot and you get windows loading window then chances are that the lens on the drive is dirty and need cleaning, its also a possibility that the hard drive has bad sectors on it so setup can't write to the disk, hirens boot cd is a usefull tool to check for and recover bad sectors.
Good luck and thanks for using Fixya!!!
Feb 11, 2009 | E-Machines M5305 Notebook
Dvd player refuses to read any disc I load into the machine
Hello I was looking to try and help you with your DVD player, we will start by loading a music cd store purchased, no burned cds please, if the cd loads and plays then your dvd player is either out of adjustment or going bad, most dvd players, i have worked on, will load and play a music cd, but will show loading errors when trying DVD's. If the music cd dosen't load then there could be an issue with the drive or tray. If the music cd plays just fine, then your laser is either out of adjustment or going bad. You can call the manufacuter to see if there is a process for resetting the DVD player, not all DVD players have this option, if resetting the DVD player dosen't work, but music cd's do then your laser lens is dirty or going bad. At this point you have three options 1) Take it to a repair shop, 2) Get an new one, 3) Get your hands dirty if your really handy and know what your doing to clean and replace the laser. I hope I can be of further assitance and I look forward to helping in the future, Thank You and have a nice day.
Jan 14, 2009 | Televison & Video
Toshiba HD-A3 won't load HD-DVD
It should recognise the discs. If you just bought it new, it's under warranty. Take it back and exchange it.
Geno
Mar 05, 2008 | Televison & Video
eMachines T5212  PC Desktop Logo
139 people viewed this question
Top eMachines Computers & Internet Experts
Michael Vincent Cruz
Are you an eMachines Computer and Internet Expert? Answer questions, earn points and help others
