Question about Acer Aspire M1100-U1402A Refurbished AMD Desktop PC - AMD Athlon X2 4400+ 2.30GHz, 2GB DDR2, 320 SAT
Why do not restored disks work for Acer Aspire M1100?
I need to change hard drive in my Acer Aspire M1100. So I created the recovery disk with the Acer program. I place the disk in the machine at start up it goes through the copying process and says restart your computer. Well it restarts the computer but hang on the "Verifying DMI Pool Data...Success" Just a black screen with a flashing cursor. I have checked the Bios and it is set for the correct hard drive. I have attempted using the Boot menu and have selected the new drive but again the same results. I then attempted using the Boot Menu for the old drive and it worked and booted into Vista. Any ideas as to what needs doing.
    Habit-Forming:
    Scholar:
  • 111 Answers
Turn off the computer Henry then turn it back on and hold down the alt key and tap F10 and make sure you remove any disks from the CD drive.
It would appear that the hard drive is having boot sector issues.
http://www.ezsystemrepairs.com
Posted on Nov 09, 2012
eagle338
  • 4889 Answers
SOURCE: acer aspire m1610 (vista)
Looks like the bios settings are not connect. Choose your First boot device as HDD, Save changes and restart. Let me know if it worked so that we can get this resolved..
Posted on Jun 11, 2008
20YrsCompExp
  • 227 Answers
SOURCE: Acer Aspire AM3100-U3202A ''hard drive'' will not boot up
That could be a hardware failure of some sort, or because you added a new hardware device. The "DMI pool" code has nothing to do with Windows, but is part of Plug and Play. Windows has not even loaded yet. It is the System Board BIOS startup code checking the hardware configuration, and setting system board resources for Plug and Play to use. Go in to the system board BIOS (normally DEL key when first powering on) Look in the PnP or PCI Configuration section, for an entry "Reset Configuration Data. It will show Disabled. Change it to Enabled, and save the new configuration and reboot. BIOS will set it back to Disable after it clears the DMI data and rebuilds it. The first time through, it will take a long time, but after that it should not hang. Unless there is a hardware problem with one of the adapters on the system board or PCI bus.
I have seen CD-Rom drives cause this hang, if there is a CD in the drive. So make sure there are no CD's in the drives when you start up.
Posted on Apr 01, 2009
  • 88 Answers
SOURCE: No harddrive detected, verifying dmi pool data, disk boot failure
Help on making a bootable XP install CD for including storage device drivers (such as SATA drivers that's not included in older XP CDs): http://rapidshare.com/files/211421782/nLite_Instructions_XP.pdf
Follow my brief instructions to make an updated XP CD.
Posted on May 15, 2009
venexcsd
  • 1185 Answers
SOURCE: Bios update failed *flash*
You are in deep trouble
A problem with refreshing the Bios is that you can corrupt the old one and then the new one does not load leaving you stuck in limbo land
I would contact Acer support and hope that they offer a pre-programmed Bios chip to replace your corrupt one.
Posted on Jul 04, 2009
tbirdfan1
  • 3051 Answers
SOURCE: This Acer AST 160 I'm working on crashed...
Computer stops at verifying dmi pool data. Issue: Computer stops at verifying dmi pool data.
Cause: This issue can be caused by any of the below reasons.
  1. Corrupt boot files on the computer.
  2. Settings for hard disk drive are not correct.
  3. Floppy diskette or CD in computer causing issue.
  4. Boot devices not set properly.
  5. BIOS corrupt or misc. setting not set properly.
  6. Connections loose or disconnected.
  7. Bad Hard disk drive or other bad hardware.
Solution: Corrupt boot files on the computer
If the computer has no bootable files on the drive it is attempting to boot from it is possible that the computer may halt at " verifying dmi pool data..."
To resolve this issue:
  • Boot from a bootable floppy diskette. Ensure that this diskette was made on the same Microsoft Windows operating system that is installed on your computer.
  • Once at the A:> prompt type "sys c:" and press enter. This should report the message "File system transferred." Once transferred remove the diskette and reboot the computer.
If the computer continues to not boot attempt to re-create the master boot record by booting from the bootable floppy diskette again. Once at the A:> prompt type "fdisk /mbr" and press enter. This should return you to the prompt without giving you any message. Once at the prompt remove the diskette and reboot the computer.
Additional information about the "fdisk /mbr" command can be found on document CH000175.
Note: The above information only applies to Microsoft Windows users. If you are running a Linux / Unix variant or other operating system such as OS/2 and the computer is freezing at this DMI message ensure that Linux / Unix has been properly installed first and/or your boot manger is not corrupt.
The computer freezing at "Verifying dmi pool data..." may be caused when the hard disk drive settings within CMOS are not set properly. Enter CMOS and verify that the hard disk drive settings are set properly and/or that it is set to Auto Detect. Additional information about entering CMOS setup is found on document CH000192.
Verify no floppy diskette or CD is in the computer. In some cases the computer may be trying to boot from either of these drives causing issues with the boot sequence.
The computer stopping at " verifying dmi pool data..." can be caused when the boot devices on your computer are not set properly in CMOS. First, verify that no CD or diskette is in your computer. If a CD or diskette is in the computer attempt to remove this first to determine if it was attempting to boot from it.
If No CD or diskette is in the computer and your computer still halts at the DMI message enter CMOS setup (steps found on document CH000192) and verify that the boot options are set properly. We commonly recommend that the floppy be set the first boot device, hard drive as the second boot device and the CD-ROM as the third boot device.
If none of the above recommendations have resolved your issue
Posted on Sep 10, 2009
Testimonial: "good info...but it looks like you just googled my issue which i could have done myself..."
How to delete all my files and restore my acer 5336 aspire
Restoring from the Acer Aspire System Recovery partition is easy Most Aspires will have a second partition that can be used to restore if you do not have CD It is recommended that you make those CD when you first buy the laptop If you don t you run the risk of not being able to install Windows again if that second partition fails Restoring From The Acer Aspire System Recovery Partition Keep in mind that running the recovery will restore the computer to the way it was when you first brought it home Anything you added will be lost so make sure you have program disks passwords favorite websites photos, documents and anything else you need backed up before proceeding with the recovery of your Acer Aspire.Hard Disk Recovery should be enabled by default If it is not you may need to go into your system s BIOS by hitting F2 at boot and enable it under the Advanced tab Once Hard Disk Recovery is enabled, restart the system and hit ALT F10 This will begin restoring from the Aspire system recovery partition. You will be prompted to type six zeros as a security step Type 000000 to proceed You will then see a screen to select your Operating System. Do this and hit enter and the recovery process will begin You Cannot Use The Acer Aspire System Recovery Partition The process for restoring from the Acer Aspire System Recovery partition is similar with all major brand names The most important thing to remember is to always have backups of your data and take a few minutes to burn recovery DVDs using Acer s built in utility. Creating these backup DVD is vital If the hard drive fails you will not be able to perform a recovery from the Acer Aspire system recovery partition Create the media and store it in a safe place along with the rest of your software and computer documentation
Nov 04, 2011 | Acer Aspire AS5336-2524 Laptop
Hi i have an acer aspire m5100 have backed up the 500gb hard drive and needed to change hard drives but when i restored both partitions and tried to do an erecovery it doesn't work didn't clone...
Greetings,
As you can see from the figure, recovery partition can be seen in the Disk Management but it can't be accessed. unless you give or assign a lettter to that partition using Diskpart and run as an admin. you have to clone the original hard drive from your Laptop to have a recovery menu. you can create your own recovery.
Jul 08, 2011 | Acer Aspire 5610-4648 Notebook
My acer is super slow it takes almost four minutes just to get everything to boot so i can use my computer . I am trying to reset my computer or something to make it like when i received it i have already...
HI,
You can restore the computer back to factory default from the hidden recovery sector on the hard drive. To do this,
Turn off the computer. Turn on the computer and immediately press and hold the "ALT" key while repeatedly tapping the "F10" key.
This will open the recovery console, select full factory restore and follow onscreen instructions. Please note. This will erase all the data on the hard drive so make sure you have got everything saved!!!
You can also create a set to Recovery disk from the recovery partition, to do this
Start, Menu, All Programs, Acer erecovery management and click Create Factory Default Disk, if you receive any error code or unable to burn the disk, please contact Acer Technical
support at 1 800 816 2237 and order a Recovery Disk.
I hope this helps
Steve at Olive Country Computers in Spain
Feb 15, 2011 | Acer Aspire 5520-5908 Notebook
I have a Acer aspire desktop computer m1100 and when I bought it did not come with a recovery disk and I did not make the cd because I was unaware of how to do it. Now the computer will not boot with out a...
by default the hard drive should have a recovery partition. go to the support section of the manufactures website and you should find detailed instructions of how to boot to the partition. if that option has been corrupted, you can purchase a recovery disc directly from acer. i've ordered nearly a hundred for customers in the past and have never paid more than 20.00 for a disc or disc set.
below you will find a link that will allow you to enter your product serial number and direct you to the purchase of a factory recovery cd/dvd.
https://secure.tx.acer.com/RCDB/Main.aspx?brand=acer
Jan 21, 2011 | Acer Aspire M1100-U1402A Refurbished AMD...
How do I do a full recovery with the disc
Turn your computer on.
Insert the Disk and choose to enter BIOS, should be F2 but watch the screen to see the right function key.
Change the boot device order to: CD-ROM, HDD in that order.
Save changes and restart the computer.
The Recovery Disk would boot up and a wizard will guide you through the recovery process.
Follow the instructions to recover your computer.
Apr 03, 2010 | Acer Aspire 3050-1733 Notebook
How do i put my acer computer in factory condition
From Aspire.pdf
Insert the startup disk you created during Windows setup into the floppy drive and
press Ctrl + Alt + Del to restart your computer. This will automatically diagnose your system and make necessary fixes. However, if the diagnostic utility still reports a problem, then you may have to perform the recovery process to restore your system to its original default factory settings.
Note: For more information about recovering your system, refers to the RCD instruction sheet.
In other words you need your startup disk.
Feb 16, 2010 | Acer Aspire M1100-U1402A Refurbished AMD...
System is running extremely slow, when I tried to do a factory restore I get an error code 0xf00000005. I ran hardware diagnostics on the hard drive memory cpu and mobo, tests run extremely slow. I tried...
After using Darik's boot and nuke (DBAN) your hard drive will be wiped clean with little chance of recovery. This also depends on how many passes you used for the disk wipe. More passes = less chance of recovery.
Restore from backup
You can restore backups previously created (as stated in the Create backup
section) from hard disk, CD or DVD.
1 Boot to Windows XP.
2 Press <Alt> + <F10> to open the Acer eRecovery Management utility.
3 Enter the password to proceed. The default password is six zeros.
4 In the Acer eRecovery Management window, select Recovery actions and
click Next.
5 Select the desired restore action and follow the onscreen instructions to
complete the restore process.
Jan 17, 2010 | Acer Aspire 5500 5570-2609 Laptop
I want to restore my Acer Aspire M1100 desktop computer back to factory settings. I have the disks from Acer, one is a System Disk and one is a Recovery Disk. Is there any way to restore/reinstall Vista...
If you used the restore disk on your computer it will erase all files, and all your programs. the restore Factory settings means "ALL" settings the time you created the CD for the restore.
If you have an individual Vista Installer CD with the Serial you can use it and use restore option.
Thank you for using Fixya
Hope this helps.
May 06, 2009 | Acer Computers & Internet
Acer Aspire M1100-U1402A Refurbished AMD Desktop PC - AMD Athlon X2 4400+ 2.30GHz, 2GB DDR2, 320 SAT  Logo
99 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
