Singer Futura CE-250 Logo
Posted on Nov 08, 2012
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Presser foot won't go down - Singer Futura CE-250
Level 3:
  • Singer Master 18,429 Answers
  • Posted on Nov 08, 2012
Singer Master
Level 3:
Answers
18429
Questions
Helped
1404424
Points
62248
You need to take it apart to see wots stopping it going down,or replace with a new one, this link is the manual..
http://www.singerco.com/uploads/download/4d21c05afe30ff8016e7eadbb35790dc0bf839b4.pdf
2helpful
Trying to wind the bobbin. I have followed all instructions but when I press the presser foot the wheel turns but the bobbin does not.
Do you have the Owner's Manual? Perhaps this would help.
Singer Stylist 457 Manual Page 10
Be sure to Raise the presser foot and that the Bobbin Winder switch is turned on.
1helpful
My Futura 900 machine is locked up tighter than a drum. How can I fix it?
this should be in sewing not vacuums. Did you find the bit of needle that broke off? It might still be in causing problems. turn machine upside down to free any bits that might be hanging about.
CE-250 FUTURA FABRIC WONT FEED THROUGH
I'm confused by what you mean, but have you raised the presser foot to put the fabric in first? (There's a lever in the back) Also, if you are using it in embroidery mode, you can use your finger to lift the presser foot even farther if you've already lifted it by the lever.) I'm sorry if this doesn't answer your question, I'm just not sure what you mean...
2answers
Royal Series, Necchi, Model # 80331763 bobbin does not take up thread properly. No manual unsure if i am threading it correctly.
You can get Necchi instruction manual from Necchi website: http://www.sewusa.com/Sewing_Machine_Manuals/Necchi_Sewing_Machines.htm". Makesure the needle is in the machine correctly- all the way up into the needlebar, make sure that it is threaded correctly, etc. If this all checks out ok,take the bobbin case out of the machine. There are two ears on either side ofthe bobbin case- turn the left one to the left and the right one to the right.Remove the silver ring, and inspect the piece of metal that the ring came off of(looks like a circle with the top cut off). You have to locate the hook whichis the piece that looks like a half moon inside the big round metal piece.Locate the tip of it, turn the hand wheel toward you until the needle is in thelowest position, at this point the tip of the hook should be flush with top ofthe left side of the cut off circle. Checkwhether underneath thread is looping on the fabric. If so then you've mis-threadedthe top, probably haven't raised the presser foot when threading so you can getthe upper thread into the tension. You need to thread the upper part with thepresser foot up. (You can put it down to thread the needle.)
Not picking up thread can be several issues, like bobbin is miswound, bobbincase isn't snapped in properly, you're using the wrong type bobbin, machine isout of time, needle is bent or burred, machine is dirty and in need of dustbunny eviction and a little oil but most of the time the issue is once againmisthreading: sewing machine needles have a front and a back and they have tobe placed in the needle holder correctly. In that case your manual is needed, take all the thread offthe machine (yes, spool off the spool pin, bobbin out of the bobbin case), pullthe needle plate and clean your machine thoroughly, using brush and vacuum (notcompressed air) and oiling per the instruction manual. Put it all backtogether, putting in a 80/12 needle, correctly oriented. Hang on to theneedle thread when you fetch up the bobbin thread.
Each and every seam you start is going to be done this way:
1) Pull the tail of the top and bobbin thread behind the presser foot
2) Put the work under the needle and use the hand wheel to lower the needleinto the work
3) Drop the presser foot
4) Holding the thread tails behind the foot, take a couple of stitches.
5) Drop the thread tails and sew normally. Hope this will help you. Good Luck.
Sep 12, 2011 • Vacuums
Powerhead won't move down so it will work on carpet
Sorry to hear you're having difficulties with your DC14. You should find the cleaner reclines into the vacuuming position easily when you place one foot on the cleaner head and tilt the handle down. If it's not doing this, please get in touch with us directly so one of our experts can assist you further. If you're based in the UK, you can call free on 08002980298, or if you're based in the US, you can call free on 1866MYDYSON.
Kind regards,
Jack
Dyson Customer Service
I have a ruffler for my kenmore sewing machine and im not sure how to use it i know where to put it and everything but im not sure how to use it
Not knowing what model you have, my answer is based on sewing knowledge. The ruffler is an attachment which replaces other presser feet. so you will need to remove your everyday presser foot and put the ruffler on in it's place. You have to make upper/bobbin thread adjustments based on your machine...Do you have your manual???? Happy Sewing.
Jul 23, 2011 • Vacuums
When I plug in my power cord the light comes on but when I engage the presser foot nothing happens. This happened before so I bought a new presser foot and no problem however now it has happened with the...
I definitely can help you out here but need to know, what make / model vacuum are you referring to in your question here? It just shows "vacuum" as the item...
Please let me know, just reply to my answer here and I can help.
Thanks,
Tim
Nov 08, 2010 • Vacuums
Sewing machine needle not moving up and down
Well there are many things to check (causes) -
Upper thread has run out. Presser foot is up.
Bobbin winder shaft was left in winding position.
Buttonhole lever was not lowered when machine was placed in buttonhole mode.
Anyway you may try the steps below to correct this (Solution) -
Replace empty spool and thread machine.
Lower presser foot.
Move bobbin winder shaft back fully to left.
Lower buttonhole lever.
Good Luck!!
Thanks for using FixYa!!
Aug 28, 2010 • Vacuums
1helpful
The presser foot is stuck in the down position on my sewing machine. The lever goes up and down but the foot will not move. Help! I have an old Kenmore 22 sewing machine. Probably got it around 1990. The...
if you open the left end of the machine .. look inside above the needle and to the back .. you will see a pivot bolt that has either come loose, broken off or fallen out .. replacing that bolt should fix the problem ..
Jun 05, 2010 • Vacuums
I have pfaff 875 hobbymatic and the presser foot ...
I am having the same problem. Did you ever get an answer?
May 21, 2010 • Vacuums
Top Singer Vacuums Experts
ADMIN Andrew
ADMIN Andrew
vince
Are you a Singer Vacuum Expert? Answer questions, earn points and help others
