Question about Proscan PS56700 56" Rear Projection Television
Image one day just becam like gosthly (double) with red, greenish color, somebody told me that it was a lamp, how can I change the lamp or lamps ??
    Top Expert:
  • Proscan Master
  • 14,553 Answers
See my previous answer just posted and let me know the chassis number of the set.
Posted on Nov 08, 2012
5 Suggested Answers
  • 375 Answers
SOURCE: tv problem
what chassis is in your set,look at the rear panel for model and chasis type to help to diagnose fault
Posted on Aug 18, 2007
SOURCE: Proscan Projection screen warped
Just had mine do this same thing today. Looks like its time for a flat screen. Sucks to spend the money though :(
Posted on Dec 22, 2009
Ecollier2012
  • 3459 Answers
SOURCE: Proscan PS50700 Convergence Problem
Projection TV sets need to have all three colors - RED - BLUE - GREEN - lined up correctly on the screen in order for the video to look normal. When its out of alignment the video will look 3D, wavy, distorted, etc. Most of the time you just need to adjust your convergence in the TV menu. If you cannot adjust it in the menu - then your convergence is broken and needs to be repaired.
This is a very common failure on these projection sets and a fairly simple DIY fix. All projeciton sets including Samsung, RCA, Sony, Philip Magnavox, Panasonic, Pioneer, Akai, GE, JVC, Toshiba, and others at some point will have the same problem.
Common Symptoms include....
  • Screen looks 3D
  • Colors don't line up
  • One or more colors can't be adjusted when using the convergence menu.
  • Screen is bowed or warped.
  • TV shuts off after powering on. Power light will blink. TV may also make a chirping noise.
Here are some photos of convergence problems.
Here is a quick test....
Using your original remote go-to the settings menu then goto the convergence section.
Try to adjust the red and then the blue convergence.
You should be able to move RED and BLUE in all directions - up, down, left, and right. And you should be able to get the grid straight.
If you can't move them in all directions or cant move them far enough your convergence chips are bad and should be replaced. This is a common problem.
Note: If you TV has as flash focus or magic focus button only try pressing the button. If it fails to fix the convergence your need to fix it. See below for a fix
69189a5.pngCONVERGENCE SOLUTION
You will need to replace the convergence chips and possibly some convergence resistors and pico fuses.
This is a a fairly easy DIY job if you are handy and can follow directions. You can get complete repair kits from TvRepairKits.com or click here. They have put together DIY repair kits that include the OEM parts and step by step photo instructions for each repair. If you are not handy or can't follow directions we would suggest calling a shop.
Posted on Jul 11, 2010
  • 252 Answers
SOURCE: there is no sound on my ps50700 proscan tv
Replace the audio output chip
Posted on Aug 13, 2010
Image Color problem
Yes. and look at the color wheel for a residue build up too. Use alcohol to clean it with a cloth that will not leave lint behind.
Jan 06, 2014 | Mitsubishi LVP-X300 Multimedia Projector
Lamp Failure, Ballast, or color wheel?
The ballast board for sure. If the color doesn't come back, try cleaning all the lens elements in the box in front of the lamp. If that still doesn't restore the color correctly, then look at the color wheel.
Jul 29, 2017 | LG RU-44SZ63D Television
Sony SXRD-KDS-R50XBR1
Light Engine Call Encompass Parts Distrubtion
1-800-638-3328 and Call UED 1-800-648-6657 Just see which one has the lowest Price.
Dec 31, 2009 | Sony KDS-60A2000 60" HDTV
My tv also has a green tint..
Is the T.V old, or second hand? Or does the picture look dimmer then you think it should be? If so then it could be that the lamp in the projector is coming to the end if its life. The lamps in projector tend to make the image on screen a greenish colour along with a dimmer look once it needs changing. It dosent just pack in though, it will stay like that for a while, but wont get any better. There could be a way of seeing how many hours the lamp has got left before being replaced on the T.Vs menu screen?
Jun 12, 2009 | Zenith E44W46LCD 44" Rear Projection...
Loose hinge,no picture but sounds otherwise OK
You could have a defective screen - a defective inverter or a CCFL lamp.
To determine if you have a LCD screen or video card problem, read this and follow the instructions.
Defective CCFL backlight, it may have the following symptom:
  • Screen flashs on red/pink and off.
  • Picture stays on in red and slowly be come normal.
  • Picture flickering with dim display.
  • Picture flickering on and off.
All these symptoms indicate that the LCD backlight lamp (CCFL Lamp) has reached the end of the life and all you need to do is replacing the CCFL lamp
Connect an external monitor to your laptop and power it up, if you see the normal Windows images then the video card and laptop is OK and the problem is definitely the backlight.
Dim image and/or dark display on the laptop's LCD screen indicates a faulty LCD backlight and it could be the inverter that supplies high voltage to the CCFL lamp or it is the CCLF lamp is nearly burnt out or burnt out, most likely this is the case.
The inverter can be replaced easily but the CCLF lamp is more time consuming and requires soldering skills.
Check out www.lcdparts.net for parts, repair service and DIY info.
May 02, 2009 | Computers & Internet
Sony 60 inch KDS 60A2000
sounds like a weak red gun..... fixable sure
The colrs you describe point to the red being the issue
try to run up the red gain to see if that helps
LB
Sep 22, 2008 | Sony Grand WEGA KDF-60XBR950 60" Rear...
Panasonic PT-50DL54 50 in. Color spectrum off
Yes, I have a cable box, and I do get high def channels.
Jul 09, 2008 | Panasonic PT-50DL54 50" Rear Projection...
SD-643HD5 64 in. Rear Projection TV
I had the same problem which was caused by a bad solder connection on my Green CRT driver board. The fix isn't too difficult if you've had some soldering experience.
1) Determine which CRT is going out (Reg, Green, or Blue). Looking at your convergence adjustment screen will help.
2) Unplug TV
3) Remove the front panel
4) Locate the driver board attached to bottom of the bad CRT.
5) Locate the two large heatsinks on the driver board, each has a transistor attached to it.
6) Touch-up the three solder connections on each transistor. Adding some new solder helps.
Jun 09, 2008 | Pioneer SD-643HD5 64" Rear Projection...
Red lamp issue
the color which you see has problem i think you might be seeing white slanting lines also with this. it mainly due to 1 supply to green video supply 2 loose cuntact in g.video section 3 green tr. defective 4 ckt from ic to green input is defective 5 chroma ic defective if supply is ok. regards
Sep 14, 2007 | Pioneer SD-533HD5 53" Rear Projection HDTV
Televison & Video Logo
Top Proscan Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Jaime Hernandez
Are you a Proscan Televison and Video Expert? Answer questions, earn points and help others
