Question about Bosch Nexxt 800 WFMC8400UC
Bosch Nexxt 800 WFMC8400UC program selector knob broke
  • 197 Answers
SOURCE: Bosch Nexxt 700 Series WFMC6401UC Front Load,wont
Get engineer to check the carbon brushes on the motor
Posted on Oct 18, 2009
  • 410 Answers
SOURCE: bosch nexxt series 500. error eo4
I am not a repair professional. I am just a 78 year old
man who has been making his own repairs for about
50 years. Therefore the washer or dryer ID doesn't
mean much to me. I came to fixya looking for a
schematic for an really old AM/FM radio and
discovered that more than 4,700 people were asking
for help with a washer repair. I recently had a washer
repair of my own and found an excellent video which
showed me how to take my machine apart. This
video made it possible for me to do my own repair. I
was so impressed with the video that when I saw all
these people needing help, I wanted to tell them
about it. If you have a top loader (washer) of the
direct drive type, this video might be a Godsend for
you. If you look at the back of your washer and the
panel is solid (no small inspection plate to remove)
chances are you have a direct drive and this video
is just what you need. You can see this video at
www.acmehowto.com You will probably need
more help in determining what the problem is and
how to fix it. If your repair problem is a washer or
dryer I suggest you go to www.applianceaid.com
where they have very good trouble shooting and
repair information on most washers and dryers.
I think you'll find what you need there. Don't worry
about the timer, they hardly ever go bad. Good
luck with it. If I have helped you, please rate my
advice on fixya.
Posted on Nov 29, 2009
rickead1
  • 1998 Answers
SOURCE: noisy pump in bosch nexxt 500 washer
no its usually not that loud at all contact bosh direct to have them send you a new one or call them if its still warrantied
Posted on May 01, 2010
  • 327 Answers
SOURCE: Bosch Nexxt 800 series. We have continued problems
Hello,let the machine rest for a while so suds can disappear then unplug the unit for 1 min then plug it back in it should drain by its self if not do not select wash cycle but a spin/drain then you should hear the pump running, if you don't hear the pump running you can get a wet/dry vac stick on the drain hose and empty the washer, that way if water does not come out you have to access the pump and pinch off the drain hose from the tub and remove the object from the pump, be careful that you don't have a mess with water leaking from the tub good luck.
Thanks
Posted on Jun 03, 2010
caroldon
  • 17129 Answers
SOURCE: Bosch Nexxt 500 series washer program cycle selector knob just spins and no longer clicks in place to select a cycle. How do I fix this?
This is a failure of the program controller timer unit and it must be replaced as the locking mechanism or the stepper motor link had failed.
Posted on Aug 04, 2012
Bosch 100 series wont start... lights stay on for wash rinse spin, but door lock doesnt light
Turn program selector to "off". Turn selector to Drain or Spin. Press the start / pause. Wait until program ends. Open door.
OR
Press "start / pause" until the start / pause light flashes.
OR
First, unplug the machine and turn off the water supply. On the lower right of the front panel is a 6" / 15mm cover. Near the bottom of this cover is a small hole. Insert a piece of wire into this hole, and push in gently. While pushing, turn the cover clockwise, it will came off.
The door release is a narrow white plastic strip hanging down on the right; Pull down on this strip while pushing in on the door, the door lock will release.
Pl click if helped
Mar 26, 2013 | Bosch Nexxt 100 Series WFMC1001UC Front...
Aug 03, 2012 | Bosch Washing Machines
Bosch nexxt 800 series wtmc8520uc not working
How do you get to the motor mount? Where is it located?
Jan 22, 2012 | Bosch Nexxt WTMC8320US Electric Dryer
E27 and e95 code
I had this problem. I tried to interupt a cycle just after it started and then couldn't start the cycle again, with the E27 code coming up.
e27 refers to a problem with the door locking mechanism which could be due to a number of causes. The problem I had was with the solenoid in the door, not a genuine problem with the door latch mechanism.
Here is how I fixed it:
(1) Set knob to off
(2) Hold down spin selector and Allergy rinse buttons and turn the knob to the LEFT (right does not work)
(3) The display then shows a number of program codes P01 to P14. (Pressing spin selector rotates through the codes).
(4) Press spin selector until you reach P02 on the display, then press the start button, the door will click and the machine will begin a cycle.
(5) Turn the knob to OFF, and then you should be able to use the machine as normal.
Jul 18, 2011 | Bosch Nexxt 300 Series WFMC2201UC
I have a vision 800 series laundry washer. I have a "check Pump" error. From what I have read I need to clean the pump filter. Also from what i have read I need to remove the bottom panel but...
Our (older) Bosch has 2 visible plastic '90 degree turning' screws holding the bottom front panel on. On some others the screws are covered by plastic caps. If yours has neither of these it could be that the cover should simply 'unclipped' by pulling at the ends.
John C
Apr 05, 2011 | Bosch Nexxt 800 WFMC8400UC
Washer keeps saying suds or blocked pump and stops
This is because you are using too much soap or the wrong kind of soap. HE soap should be used and only the measurement specified on the label. May also be due to lint and other debris in the pump filter. Open the panel and remove the filter screen from the drain line and clean it out. This has to be done often on front load machines.
Sep 08, 2009 | Bosch Nexxt 800 WFMC8400UC
My Bosch nexxt electric dryer won't turn on
Belt broke or came off. Replace or reset belt. Be sure to reset the switch that the tension arm activates when tension is lost.
Nov 04, 2008 | Bosch Nexxt WTMC3321US Electric Dryer
Bosch Nexxt 800 WFMC8400UC Logo
47 people viewed this question
Top Bosch Washing Machines Experts
Tim Whalen
Dan Webster
Dan Webster
Are you a Bosch Washing Machine Expert? Answer questions, earn points and help others
