Question about Dryers
I need a heating element for a Hitachi De 555 Dryer
Unit works fine but no heat
  • vin1976 Jan 08, 2009
    re- Hitachi Dryer is electric.
  • 1028 Answers
SOURCE: replacing Kenmore dryer parts
that one is old enough to vote..if filter on top remove back find small hole on right just below top may be hidden by pasted on tech sheet..through hole insert long socket 5/16 or reach up from underneath with short ratchet and socket remove screws and attached wires lift element housing up slightly and pull bottom of housing out and down..5/16 screw on backside holdes element in
Posted on Jun 19, 2008
SOURCE: Amana electric dryer model LEA30Aw will not heat
The heating element measures 10 Ohms at 68 degrees farenheit. Usually if the element is bad, it will measure infinity.
Posted on Dec 29, 2008
  • 102 Answers
SOURCE: heating element
Might I suggest this site if you are a do it your self.
You have to raise the top take off the front and the tub should come out. Wala the heating element. Hope this helped, if not let us know.
Posted on Mar 16, 2009
  • 525 Answers
SOURCE: maytag neptune (gas dryer) just stopped heating
Gas dryers utilize a gas valve, ignitor assembly, and a series of coils mounted on the gas valve to provide heat and safety. The gas valve coils are the usual suspect when it comes to a "No Heat" complaint. I have provided a checklist from, for your convenience. They also provide disassembnly diagrams and repair parts.
Firstly, ascertain that you have made an adequate "Heat" selection, then read on:
Warning! To avoid personal injury or even death, always disconnect your appliance from its power source--that is, unplug it or break the connection at the circuit breaker or fuse box--before you do any troubleshooting or repair work on your appliance. Also, because some components may have sharp edges, use caution while working on your appliance.
If your dryer doesn't heat, check these:
Gas valve coils
Thermal fuse
Igniter Modern gas dryers use an electric igniter to ignite the gas from the gas valve. When it's working properly, the igniter glows bright orange. When it burns out, the dryer tumbles but there's no heat because the gas can't ignite. When the igniter burns out, you need to replace it. If the igniter is held by a tension bracket, you very well may need to replace the bracket too.
The igniter is inside the dryer housing, near the bottom front, usually in a cone-shaped metal tube (the force cone). It's about 2 inches long. It's mounted to the far end of the burner tube, and it has two wires attached to it--or to the tension bracket, if there is one.
Gas valve coils Watch the igniter. Does it glow bright orange, then shut off without igniting the gas? (When the gas ignites there's a large blue flame.) If so, there may be defective coils on the gas valve. Mounted on the top of modern gas valves, there are black electrical coils. The coils, when energized, open the gas valve. If one or more of the coils are defective, the valve doesn't open and the gas cannot ignite. Because it's often difficult to properly test the coils, it's usually best to replace both (all) of them at the same time.
Thermal fuse On many dryers, there's a thermal fuse (a heat-sensitive fuse that blows if the dryer overheats) mounted to the exhaust duct inside the back cover panel. The fuse is about an inch long. It's usually embedded in black resin and mounted in a white plastic housing.
If the fuse has blown, it has no continuity. When this happens, your dryer either just stops heating, or it doesn't work at all. Be sure to inspect the venting/heating system before replacing the fuse to put the dryer back into operation. (You can't re-set this type of fuse.)
Posted on Jul 08, 2009
  • 1606 Answers
The thermal cut-off , which is the small t-stat looking piece located at the top of the element housing ( on vertical mount elements ) or the far front of the element housing ( on horizontal mount elements ) , is usually the cause for no heat .
Posted on Aug 02, 2010
Dryer heats briefly then heat cuts out
Sounds like a bad thermostat...There is one (some models two) disc type thermostats, about the size of a quarter that are wired into the heating element circuit. Take the back panel off and find the heating element. There should be a thermostat with two wires attached connected to the heating element. Unplug those wires and remove the thermostat and replace it. Be sure the unit is unplugged before you start.
Oct 12, 2014 | Tricity Bendix TM220W Electric Dryer
Dryer function on De Dietrich washer-dryer doesn't work
take care do not play with electric ??????????
????????????????????????? warning????
check heating element
check stats
check you have power at element
Nov 05, 2012 | De Dietrich LZ9619 Front Load Washer /...
Aug 02, 2010 | Roper REX4634KQ Electric Dryer
No heat in dryer. This is a stacked dryer/washer combo. The dryer is electric. The drum turns and timer works but there is no heat in the dryer or exiting the vent. The washing maching beneath the dryer...
The element to heat the dryer has gone out. You removed the back of the dryer to remove lint you will need to remove the back of the dryer again to access the heating element. It is in the lower left or right hand corner (depending on model) and looks like the inside of a toaster oven small thin wires. Take the assembly out (make sure the unit is unplugged always) get the model and serial # and purchase replacement from an appliance parts house.
Good Luck hope this helped you some
Jan 23, 2010 | Dryers
Dryer willnot heat
heating eliment is most likely burned out. Better off getting new dryer. But if that is not an option then call a repair person that can replace the heating element.
Nov 22, 2009 | Maytag Neptune MDE5500AY Electric Dryer
Top works fine, bottom no heat, does this unit have seperate heating elements or could it just be the internal fuse
Are you talking about the element you where looking into the element shroud and that is what you saw? If so your element is gone you can buy a complete element at your local parts depot.The element is fused on to the shroud makeing a dead short. Hope i fixya :)
May 21, 2009 | Maytag Neptune MDE5500AY Electric Dryer
Dryer not heating everything else works fine had heating element tested and it is okay
Just a general troubleshooting guide for your washer! hope this helps!! PS don't forget to give me a rating if this helped!! Thank you!!
May 07, 2009 | Kenmore 64992 Electric Dryer
Dec 24, 2008 | Amana Dryers
No heat
Check the resistance of the heating element (8 to 14 ohms). If ok, then check continuity of the overload devices attached to the heat element duct. If either one or both are open then replace ($14 for both). Dryer should heat.
If heat element is faulty, the part can be purchased at Sears/Kenmore Parts Center and swapped out ($45.00).
Provide your dryer model number and ask for the needed parts.
Unplug your dryer first before attempting any service work. Safety first and always!
Dec 19, 2008 | Whirlpool LER4634J Electric Dryer
I have a maytag washer/dryer single unit stacker that works fine except the dryer does not give off any heat at all.
Start with resetting breaker dryer tumbles with 110 but needs 220 to turn on element. If still no heat might have a bad element.
Jul 09, 2008 | Maytag Dryers
Dryers Logo
55 people viewed this question
Top Dryers Experts
