Question about Sony KV-28FX60 28" TV
SONY TV KEEPS TURNING ITSELF OFF!!
Hi I have a SONY triniton 100hz digital plus tv, its about five years old and have never had any problems, but just recently it keeps turning off, I will leave it for a while then turn it back on and its ok for a while, then it turns off again. I finally got a TV repair man out, he seems to be baffled, he said deffinately not a conector problem. but would have to take it into the workshop. Also when my tv turns off the standby flashes 5 times if this is any help Model Number: KV-28FX65U thanks Mark
  • RAILMAN Nov 05, 2007
    MY TV IS KV-36FS76U AND I HAVE EXACTLY SAME PROBLEM,TOO BIG TO TAKE TO REPAIR AND CANT FIND SOMEONE TO COME ROUND,,YET! ANYONE KNOWS WHAT THE PROBLEM WOULD BE? PLEASE.
  • De-anne Tasker
    De-anne Tasker May 12, 2008
    We have a Sony (black) triniton. It has surround sound. Not sure of the model and have had it for maybe nearly 10 years. You can turn it on at the switch and in about 10 seconds it will just switch itself off. A friend said she had the same problem and was told it was the power switch. When you do see a screen it is black with a white line horizontally across the middle. Model on booklet is... KV-XF25 & KV-XF29
Its the BULB people! You need to change it every 3 to 5 years! I have had my sony 55" for 6 years... I had Best Buy come out 3 years ago, changed the bulb... it worked fine. Just started flasshing and shut its self off and back on again. Time for another bulb.
Posted on Nov 22, 2008
  • 432 Answers
You have to take it in to get it fixed. Five blinks means AKB circuit (automatic kine bias), the timer/standby indicator blinks for about 30 seconds then goes to the self-diagnosis function. Something is wrong with the video. Check video out, Q705, 732, 761 and other components on the Cboard, also check Q218, 219, 220 on the A board. In addition, unit could be in IK blanking, try turning up screen slightly.
Posted on Jul 04, 2007
    Problem Solver:
What bulp are you talking about? Can you be a more specific please.
Posted on Nov 24, 2008
Idk
Posted on Aug 25, 2010
Tv not working the green light is on no picture.
Posted on May 12, 2010
Ok, my sony wega, 42 inch, 5 years old has been turning itself off.  The light flashes for about 32 seconds and then turns itself back on, just to turn itself off again a minute later.  I don't know what to do, not sure if it is worth taking in.
Posted on Sep 16, 2008
Thanx for the solution. About 2 weeks of not having the TV working it started working again. That was after I posted the message in May. It has now gone back to the same problem. It does 2 flashes. I will pass the info onto my technical hubby and get him to check it out or get it checked out. TV can be a pain not working when you have a small child in the house.
Posted on Jul 30, 2008
  • De-anne Tasker
    De-anne Tasker Jul 30, 2008
    Two flashes together and then a pause then another two flashes could mean the flyback is faulty
Sony triniton model kb-36xbr450 keeps turning off by itself
There is some short circuit with the main board of this TV. Contact any experienced service technician to get it repaired. It is a skilled work, that a user can't do.
Aug 10, 2012 | Sony KV-36XBR450 36" TV
Sony wega power problems
Replace lamp in TV as this is clear symptom of weak lamp and TV needsnew lamp, did you replaced lamp in 4 years? Lamp replacement procedureis written in user manual of TV, pretty easy job, make sure to buy Sonyoriginal lamp and avoid aftermarket/ cheaper/ alternative lamps for TVsafety.
Click Sony Support to download user manual copy (KDF-42WE655)if required.
Thanks.
Oct 17, 2009 | Sony Grand WEGA KDF-42WE655 42" Rear...
FD Triniton Wega XBR KV-30XBR910 TV WON'T TURN ON, LIGHT FLASHES 6 TIMES RIGHT NOW, SOMETIMES IF I KEEP TRYING USUALLY SEVERAL WEEKS AFTER TURNING OFF IT WILL TURN ON, BUT WILL EVENTUALLY TURN ITSELF OFF...
If you are handy with TV repair then replace IC6501 and IC8002 on D board of TV or ask local TV repair shop to replace it. Both ICs have same number MCZ3001D
Thanks.
Jul 12, 2009 | Sony FD Trinitron WEGA KV-32FS120 32" TV
No cable channels at all on old Sony Triniton
make it sure that the coaxial cable has its own signal! if your tv has a raster (sometimes blue) and it says that the tv is good, but if there's no channel at all then the problem is in digital converter or the connection of the coaxial cable comes from..you can also try auto programing but if the problem still occured then contak your cable subscription channel
Apr 03, 2009 | Sony KV-13M10 13" TV
I cannot make my wii to work on my Sony tv
Some newer hdtvs use the green rca in the back for both a/v and component. Usually it has green with a touch of yellow on rca input itself. Then plug in audio to red and white.
Oct 06, 2017 | Sony (ICSSP20) TV Input
Sony triniton 37 inch flat screen ( five years old)
First make the set have a hard reset. To do this, unplug the power cord for at least 4 hours to 6 hours (over night), and then try using the set. You will have to re-do the user setup. This will reset the internal programming and restore it to factory user defaults settings. Unplugging for a shorter period of time may not do the trick.
If the hard reset does not fix the problem it probably has a defective eeprom or a bad voltage regulator that feeds the controller IC-EEPROM IC's. In which case you will need a tv tech to dignose the exact fault condition and determine the failed parts. (There are about 120+ parts associated with these functions).
This can be a number of hours of work to troubleshoot. Then there will be the cost of the parts, if they are still available for this model. If the main IC/EEPROM has to changed, the complete factory alignments will have to be done.
Jerry G.
Apr 12, 2008 | Sony KV-32S26 32" TV
Reddish screen on sony wega kv-28fx68 100hz trinitron
it sounds like a b+ cap going bad and is intermittant that feeds the the video drivers on the crt pcb or the crt is shorting.
Oct 14, 2007 | Sony FD Trinitron WEGA KV-32FS120 32" TV
Post Storm Problem
Hope is last to dye. Be calm and contact the technician with best references or Authorized Sony Service. If you need more info please advice
Apr 12, 2007 | Sony FD Trinitron WEGA XBRKV-40XBR800 40"...
TV keeps turning itself on and off, onto standby
Right i had this same problem for ages! i cannot explain why but when i uplugged my DVD player (which was flashing its light at the same time as the tv for some reason) the TV has worked fine.
Aug 24, 2006 | Philips TV Tuner Video Capture PCI Card -...
Sony KV-28FX60 28" TV Logo
7,411 people viewed this question
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Steve Allison
Steve Allison
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
