Question about IBM 4224 Model 101 Matrix Printer
IBM 4224 CODE 51 ERROR - IBM 4224 Model 101 Matrix Printer
3 Suggested Answers
  • 13 Answers
SOURCE: IBM 4224 Shuts off after warm up
4224 were notorious for poor connections between the control cards and the motherboard. Opening the printer and reseating all the cards solves a multitude of problems. Try it.
Aido
Posted on Mar 06, 2008
SOURCE: error 01
Error 01 is End of Form, Make sure u have paper installed.
The sensor that is at the bottom left that you feed paper thru is were this error is generated. Make sure it is aligned and working.
Also clean with wet paper towel slide in and out
You can also run a Test 851. to see if the sensor is open(1) and closed(0). also check the connection on the board to see if it still connected.
I can go into level 2 support if more help is needed.
Posted on Jan 25, 2009
My printer will not power on what can I do?
If you can open it : Test the power switch and the power unit and change if one dont work If you cant open it: Change your printer
Oct 18, 2012 | IBM POWER SUPPLY 4224 Printer Part 17F4711...
What is a 19 error code on the Ibm printer 4224
Attachment Card Failed Power on Tests.
1. Switch Power off (O).
2. Wait 20 seconds and switch power on(I).
3. If the printer displays (19) again then call for service.
May 14, 2012 | IBM 4224 Model 101 Matrix Printer
Have an Error 51 on Brother MFC-210C all in one printer?
I can help you with your Brother MFC-210C error 51 problem.
Error 51 refers to a paper jam error.
Clear the paper jam to clear the error code.
If the error code will not clear after clearing the jam, resetting and powering off, the printer may require service.
I hope that helps.
Aug 30, 2010 | Brother MFC 210C All-In-One InkJet Printer
I need a schematic for IBM 17f4711 power supply made in the 1980's by Zenith.
Sorry - no manufacturer supplies that. You may be better off in using a new supply - many are backwards compatible to the early versions. The basic difference will be the connector style, but the wire colors are the same. Also, the newer supplies have a power on/off input (typically a green wire) that should be tied to ground (common) to turn the power supply on.
Feb 01, 2010 | IBM LENOVO POWER SUPPLY 4224 Printer Part...
Code 56 error
You have a Head Error-Head Drive/Emitter Failure.
Your going to need to check your head drive belt, being that the printer is so old the belts go bad and start to crack and turn into a tar sub. Also make sure to clean your rails, over time they build up dirt and oil and need to be cleaned off.
Rory
rcarndeas@mrp.to
Oct 29, 2009 | IBM 4224 Model 101 Matrix Printer
I HAVE A 4224 PRINTER FOR SALE. WHO COULD I CONTACT?
Are you looking to upgrade? I can take yours as an exchange or if you are interested i can repair the one that you have like new.
Please let me know. I carry parts and printers in stock refurbished with a 30/day warranty.
Rory Cardenas
Midrange Repair and Parts
Alsip IL 60803
708-597-4222 X240
rcardenas@mrp.to
Jun 22, 2009 | IBM 4224 Model 101 Matrix Printer
Error 01
Jan 12, 2009 | IBM 4224 Model 101 Matrix Printer
IBM 4224 Printer G111 (172.26.131.26) does not print. Possibly bad card.
What are you trying to do? Get a Manual.
I have the book I would have to scan it for ya, but what do you need the MIM or the MAP?
Is there a Error Code?
Aug 25, 2008 | IBM 4224 Model 101 Matrix Printer
I need hep for my printer
How to get a manual to show how to do this?
Jan 09, 2008 | IBM 4224 Model 101 Matrix Printer
Aido
Dec 11, 2007 | IBM 4224 Model 101 Matrix Printer
IBM 4224 Model 101 Matrix Printer Logo
105 people viewed this question
Top IBM Office Equipment & Supplies Experts
James Cagle
James Cagle
Don  Farrell
Don Farrell
Jim Keysor
Are you an IBM Office Equipment and Supply Expert? Answer questions, earn points and help others
