Question about Philips 32PFL3505D 32 in LCD TV
Puppy chewed the cord. It is an internal cord and does not plug into the back of the tv. Can I replace it myself? Directions or diagram? Where is the best place to get the replacement cord?
    Top Expert:
  • Philips Master
  • 14,553 Answers
Any polarized power cord will work----cautions: the cord where it connects inside will have either a white stripe on one side or a rough surface---that is the neutral side---replacement must be soldered to correct points---you get it backwards and set will work but shock hazard will exist-------if you have enough cord left you can do a splice repair-----I cut them back and offset so not next to each other(the two sides of the cord----get some heat shrink tubing--slide it over each side and down a ways---solder the two ends for each side back together (you will lose a little of the cord) and once soldered slide the shrink tubing down over the soldered parts and heat it with a hair dryer and it will shrink air tight over the solder connection's---you do not want the splices side by side to prevent any possible short----for extra protection once done use some black electrical tape and tape the whole area.
Either replace entire cord or splice repair it. Examine cord end to end for any bare wire showing---if chewed in more than one spot replace entire cord.
Posted on Nov 08, 2012
4 Suggested Answers
  • 27 Answers
SOURCE: replacing power supply main
your best bet is to check owneres manual and keep with what they suggest however when ordering you may want to ask for tech support to see what they say but i would stick with what you had especially if it worked great that way you dont want to overpower your tv if that is what it was used to ..if it ain't broke don't fix it i hope that helps
Posted on May 14, 2009
news775
  • 699 Answers
SOURCE: I need a replacement power cord for my 50" Philips
It will have a standard figure 8 power lead connector at rear.
You should try local electronics store for spare lead.
Posted on Feb 05, 2011
ekcnoel
  • 998 Answers
SOURCE: I have a Philips 22"
Try to check this link http://www.tvrepairkits.com/ good day
Posted on Aug 13, 2011
Can I replace the jack that my puppy chewed off
The puppy probably chewed off the plug. If the plug was molded on, it may be more practical to replace the entire cord assembly.
Jan 29, 2015 | HOUSE OF MARLEY REBEL On-Ear Headphones...
How do I stop my puppy from chewing up everything?
There is no easy fix here. Your puppy is just that... A puppy. For all you know he might be teething and chewing stuff is a way to ease the pain. Now, what you want to do is make sure that those "chewables" are not within his reach. Get him a couple of toys, and make sure you play some with the puppy so it understands that these are ok to chew. Schnauzers are very territorial, so once he understands that the toys are his, he'll make sure to keep them within reach. Also it'll make him forget about all of the other stuff he normally chews on.
Jan 14, 2014 | Televison & Video
My puppy chewed the powercord to my tv, what can i do
Try a T.V. repair shop to see if they can replace the cord for you if it is no longer under warranty...and make sure puppy has plenty of rawhides or chew toys to gnaw on while teething. They can't help it. Those teeth need help breaking through.
Sep 19, 2013 | Orion Televison & Video
My puppy has just chewed the sealed plug off my Rowenta Master. Is it safe to wire up a basic new plug? Bit worried about the water/electric combo. Puppy is fine! Thanks.
The cord that comes with the DG980 is mighty handy because it is nice and long. I would just get a brand new one, You do not want loved ones to be around a "modified" cord. JMHO :o)
California Electric Service in Concord CA (it is the only Rowenta repair station in California) go to either of the following addresses:
their website is: http://www.californiaelectricservice.com/
or tech service: service@californiaelectricservice.com
Aug 16, 2011 | Rowenta DG-980 Iron
Puppy ate thru power cord. Can it be replaced?
no need to replace it. Simply cut the cord where it was chewed through (if it was not already fully separated). cut an inch off of each damaged side of the cord. Strip the wires and then "braid" them back together.
Jul 26, 2011 | Video Game Consoles & Games
Our puppy chewed through the cord on our Rainbow. we paid $45 to have the cord replaced, got it home and it still will not turn on. Any ideas? Thanks!
The service tech who replaced it didn't know what he/she was doing. That's my first guess. If it was working before the puppy chewed through the cord, then if the cord was replaced, it should work. That leads me to believe the cord wasn't installed correctly. Take it back and have them redo it, then make sure it works before leaving the shop.
Oct 15, 2010 | Rainbow E series Canister Wet/Dry Vacuum
Our puppy chewed through the cord of our bread maker. Are cords replaceable or is the machine useless for good?
Yes cords are replaceable. Just show the hardware store what is left of your cord and they should be able to get a replace ment for you.
Sep 30, 2010 | Oster Kitchen Appliances - Others
How to replace electrical cord on Dyson ball vacuum cleaner. Our puppy chewed it.
Depending on where it has been chewed, you may not need to replace the whole of your cord. Ask your local electrical supplier, or possibly somewhere like B & Q, if they have an 'inline' plug and socket to repair your existing cord.this would resemble the type of plug and socket used to connectd the power chord to a lawnmower, except you would not be buying the sealed type.Then you could simply cut out the chewed part of your ccord, and fit the two new ends, one the plug and the other the socket.It is no more difficlt than fitting a new domestic 13 amp plug on a cable.It is also a safe but much cheaper solution, so you should save money too.
Jul 10, 2010 | Dyson Ball DC24 Bagless Upright Vacuum
My puppy chewed the electric cord! Can i buy a replacement? Model GGR200RDDS
This should be an obvious one. If the cord is attached HARD, meaning you can't remove it, you have to buy a new unit. punish your puppy as you see fit. If the cord is removeable, meaning there is some sort of lock-in plug end to the cord to the cooking unit, OR a magnetic lock, you can most likely buy a new one. just call up the number for sales that should be printed on your owners manual somewhere. And if you tell me its not there, look harder. every company wants a sale. and you know the company name anyway. GEORGE FORMAN GRILL. Also you can splice the cable if its a chew in the middle. it takes some electrical know-how, but if a puppy chews in the middle, a pair of wire nuts and some electrical tape fixes it. talk to people in the know. CONTACT CONTACT CONTACT! :) The world is not at an end due to a fiesty puppy.
Jul 11, 2009 | George Foreman GGR50B Grill
George foreman grill parts
http://www.directpartsandproducts.com/george-foreman-parts-accessories-indooroutdoor-grills-c-61_171_1017_1144.html
Hope this helps! And one previous poster inverted the phone number. It's 800-738-0245. But you should be able to order online through the posted website.
Oct 11, 2007 | George Foreman GGR50B Grill
Philips 32PFL3505D 32 in LCD TV Logo
35 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
