Question about Whirlpool Duet 7.0 Cu. Ft. Super Capacity Plus Electric Dryer
Does anyone know of a fix for this problem the **** thing worked fine yesterday
    Top Expert:
  • Whirlpool Master
  • 9,472 Answers
It sounds like you have a simple fix. The most likely problem is that you have a blown thermal fuse.
Remove the lower panel, remove the lint filter from its housing, then remove the housing itself. It's a diamond shaped WHITE component on the duct work behind the lint filter housing. It will Usually have two blue wires on it.
This fuse usually blows due to an exhaust problem. Lint build up, too long, kinked, pinched or otherwise compromising air flow. Check the internal duct and the external duct to be sure it is clear.
Here is the part you need to order.
The part comes with a 365 day, any part, any reason return policy.
Thank you for using FixYa!
Posted on Nov 08, 2012
SOURCE: Whirlpool duet dryer will no start...the "sensing" light comes on when you hit start; it makes the click noise in the door when you hit start, it counts down, but it does not tumble or anything
you have a blown thermal fuse. you can get one where they have parts it is about 5 dollars.
Posted on Oct 02, 2008
localwonder
  • 6784 Answers
SOURCE: dryer will not start
Check the following:
Is the power cord plugged in?
Has a fuse blown, or has circuit break er tripped?
Was a regular fuse used? Use a time-delay fuse.
Is the dryer door firmly closed?
Was the START button firmly pressed?
Is a cycle selected?
Posted on Mar 07, 2009
  • 1170 Answers
SOURCE: dryer wont start
Commonproblems...blown house fuse, broken belt ( on some models )...door switch...*thermal fuse open (venting needs attention )...broken or burnt wire....timer....motor, in order from mostcommon to least common. * If you find a blown thermal fuse, always clean, change, adjust the ventingsystem and vent hood first, then it is often a good idea to replace the operatingthermostat at the same time. This is a picture of some modernthermal fuses.
I hope this will solve your issue.
Good Luck
If my solution proves useful please accept it.
Regards
Arjun
Posted on Mar 30, 2009
SOURCE: Whirlpool Cabrio dryer won't start - the "sensing" light is on
where are the answers on those stupid site
Posted on Oct 21, 2009
SOURCE: G.E. WHIRLPOOL DUET DRYER MOD.# GEW9200LW0
for gew9200lwo the problem control locked
Posted on Jul 06, 2010
Today I used my Paypal a/c with no questions, yesterday I tried and said I need new password. Please tell me what password is on my a/c.
Firstly, this is FixYa, and if anyone here had your PayPal password, you'd have no money in your account.
Secondly, if the thing works fine today, follow the maxim: if it ain't broke, don't fix it.
Jan 23, 2015 | PayPal Computers & Internet
Hi experts, my car is optima 2003, Novis. I have a weird problem with my horn. I discovered, when I turn the steering to the right, my horn doesn't work, but when turn it left, it begins to work fine! I...
Around the steering column there is a flat metal contact ring, commonly referred to as a "clock spring", it seems you have a problem with that part.I do not recommend to try and fix it yourself, have a good mechanic look at and correct the proble; will most likely require a new part.
Oct 30, 2014 | Cars & Trucks
I got my crosley record player yesterday and I tried turning it on today and the knob doesn't click like it's supposed to. Consequently the power light doesn't turn red and the turntable doesn't spin....
Hi A Soni...word of advice...if this a new unit DO NOT attempt
to fix the problem yourself...you may void any warranty attached
to the product. Call Customer Support 1 866 Crosley.
Regards,
Dennis
Oct 05, 2014 | Audio Players & Recorders
Squeaky noise when going over bumps 2005 G6
sounds like it needs a lube job. there are grease fittings in different areas of the car that need greased every so often
Jul 19, 2012 | 2005 Pontiac G6
No video, occasional sound.
get new av jacks that might be the problem
Aug 20, 2009 | Sony Playstation 3 (PS3) Console
EM-G4753
I did a google search for the service manual and found one from Sanyo support. From that I was able to figure out how to open the unit safely, and find the fuses and safety switches to check. I found a loose wire plugged onto the main interlock switch (don't know how it worked all this time for how loose it was...). Re-attached it, and now it works fine.
WARNING! There can be very hi voltages on the inside of the uwave so you really need to be careful and know what you are doing! Also, you need a special bit to remove a couple of the cover screws.
Apr 14, 2009 | Sanyo EM-P410W Microwave Oven
Ipod Nano 8GB blank grey screen
I found this solution: Push the hold button on, then off. Then, press the Menu and Center button att he same time - hold for 6 to 8 seconds. The Apple icon should appear on your screen. You might have to repeat the steps. (I had to do it twice, but it worked.)
Jan 03, 2009 | Apple iPod nano
Platinum JBL Series Speakers
as far as I know the speakers itself don't need drivers. I use em myself for years. The problem could be 2 things, 1: is the power still plugged into the speakers (from the monitor)(check both sides). 2: if you where removing any files from your computer it might be possible that you removed some drivers that came with your mainboard or audiocard.
Dec 15, 2008 | HP JBL Platinum Computer Speakers
Whirlpool Duet 7.0 Cu. Ft. Super Capacity Plus Electric Dryer Logo
Top Whirlpool Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Sal DeAngelo
Are you a Whirlpool Dryer Expert? Answer questions, earn points and help others
