Question about IBM IntelliStation Z Pro 6223-42U PC Desktop
Freezes at Setup load - IBM IntelliStation Z Pro 6223-42U PC Desktop
  • Jose Rodriguez Nov 08, 2012
    The system detects anything that is connected to it but won't boot straight from the HD. Attempting to load the F1 Setup function causes it to freeze.
  • IBM Master
  • 27,725 Answers
WARNING: Before you start troubleshooting remember that you are dealing with electricity that can KILL.
http://www.kitchentablecomputers.com/static.php - rules
Only work inside the computer case when the power has been switched off and disconnected. Never open the power source.
Some of the below steps recommend removing physical parts within the computer. While in the computer it is highly recommend that you be aware of ESD and its potential hazards
Remove the memory modules from their slots.
Take the opportunity to clean the slots on the motherboards and the memory module connectors.
Use compressed air to blow dust away and clean contacts with a soft cloth.
Do not use a metallic vacuum cleaner if it touches any component it may create a short and cause damage to the motherboard or other components.
Do not use solvent that may attract dust and never poke things like cotton buds in to slots. lightly rub an alcohol on a cloth not to hard let the alcohol do the work on the copper gold or silver tabs and r
Allow the pins to dry. They will air dry in a matter of minutes
If reseating the memory did not resolve the issue try swapping the location of the memory.
If you have only one stick of memory in the computer try moving it to another slot and then boot the computer.
Check the memory module and memory slot contacts.
They are either copper tin or gold.
The colour will tell you which they are.
Mixing tin and gold can result in corrosion that prevents proper contact.
Look for any sign of physical damage to the memory module, memory slots or the motherboard.
Reseat the memory modules.
You should hear an audible click when they are in place.
Do not use too much force to reseat the memory module in to the slot this can cause damage to the module, slot or motherboard.
The hardware that you are trying to access is damaged or failing.
The device drivers for the hardware are faulty or incompatible.
There is a connection problem such as a bad cable
for internal hard drives
Test all power and data leads that attach to your hard drive IDE,SATA
the leads from your MOTHERBOARD TO THE HARD DRIVE make sure they have a
secure dust free connections and are not faulty or just replace them they could be faulty if its a flat 40pin ide
this will be the first to fail
make sure all leads that are attached to your drives dvd\cd 3 1/2 inch floppy have secure connections and are not faulty
or just replace them they could be faulty a computer needs power and data to travel through every working device and continue its cycle and have an end so any faulty leads will end up with a computer error
Hope this helps
Posted on Nov 09, 2012
MacBook Laptop Will not boot from CD and OS freezes during setup
Since you have an Intel Mac book you can boot to DOS 6.22 and use Fdisk to remove your partition at which point you can format it and install Mac OS.
Apr 12, 2013 | Apple MacBook 13"White /2.0Ghz Intel Core2...
My laptop will not start
If this is the first time that you turn on your laptop after resetting it to the factory settings then don't do anything while setup is starting services because you will just mess up the computer. It's really gonna take time to start the services. It's still in the set up process - it's loading some files on it.
I hope this helps!
David
Feb 22, 2013 | Acer Aspire 5750Z-4879 : 2.2GHz Pentium...
AM37 & athlon 1.8 gh freezes while setting up XP
More than likely one of the drivers is bad. Hit F8 several times at startup until the boot screen comes up, select boot into "safe mode with networking" .
Use device manager and see if there are any problems. You can delete the drivers, and download & install new drivers if you find problems.
May 19, 2012 | FIC AM 37 Motherboard
Lacie setup assistant freezes on license screen
I had the same today with this HD. I decided to format using the Disk Utility on my Mac and that worked fine. Erased and renamed the disk and it works.
May 08, 2009 | Computers & Internet
Freezing in Bios Setup
change the RAM of your laptop, then check
Oct 23, 2008 | Fujitsu Siemens AMILO Pro V2000 Notebook
Game/midi port
I tried to use a Logitech Wingman Joystick...and windows would not recognize it even after loading the drivers...so I assumed the gameport would have to be enabled on my motherboard
Sep 06, 2008 | ASUS P5GD1-VM Motherboard
Aspire 5610 stuck on initial Acer loading screen!
Time to re-install your OS.
Install Windows from Bootable CD.
May 27, 2008 | Acer Aspire 5610-4648 Notebook
450sx4 freezes half way thru setup
E-mail CHID: 5736 So basically it freezes trying to intialize the setup. ... try rebooting the computer into safe mode and run the setup through safe mode.
Good Luck, Please dont for get to Vote/Thank You.
Dec 23, 2007 | Gateway 450SX4 Notebook
IBM IntelliStation Z Pro 6223-42U PC Desktop Logo
21 people viewed this question
Top IBM Computers & Internet Experts
Alun Cox
Are you an IBM Computer and Internet Expert? Answer questions, earn points and help others
