Question about Dayton Gas Furnace Heater
I have an industrial Dayton 100,000 BTU gas, forced-air heater in my shop that started acting up. It will burn a nice blue pilot light and ignite with a perfect blue flame but then the flame will shu
Dayton 100,000 BTU forced-air suspended shop heater converted to propane.
  • 4 Answers
SOURCE: heater wont work
Dayton heaters. com?
14 years old? dayton still exist?
Stop trying to blow self up--go buy new one
Posted on Jan 21, 2008
jeffk14
  • 16 Answers
SOURCE: I have a Dayton gas heater Model 3E225
Does the main blower fan kick on? Also, if the heater is vented outside via a flue pipe, there may be a small (about 3 or 4 inches in diameter) vent fan that kicks on to ensure the exhaust fumes are evacuated through the flue pipe. If there's a problem with that fan, the burner won't light either.
Posted on Nov 20, 2008
  • 2463 Answers
SOURCE: Dayton 150,000 btu that won't stay lit
see if there is a pressues switch on the heater one of the tubes could be blocked,
Posted on Dec 08, 2008
  • 252 Answers
SOURCE: I want to convert a model 3e476b propane counter
The Dayton brand belongs to WWGrainger if the parts are available that would be the only place.
Posted on Oct 03, 2009
roniecon
  • 6826 Answers
SOURCE: Can the Dayton model 3e368e be converted to use
If you know a dealer or repair company,they can order orifices to change out in the unit.
Posted on Oct 17, 2009
I have a Dayton hanging gas (propane) heater 3E838 series 1067A model z21116 when the heater ignites its like to much gas and blow out the side vents ????
sounds like the air to gas setting is wrong, not enough air intake. there should be an air adjuster near the burn box. where the gas goes into the burn box. fallow the gas line to find it. adjust it till it burns correct. there also should be a gas pressure adjuster to, it should be near the burner.
Dec 26, 2014 | Dayton Gas Furnace Heater
I have a 100,000 btu reddy heater, and every time I turn it on, it runs for about 5 minutes, then stops, then I have to push the reset button and start it again. Can you tell me where to start? thanx
If it actually ignites and burns but shuts off either the flame sensor is bad (or dirty) or the control is bad. I would verify the flame sensor is clean and had good electrical connections to the controller for starters.
Feb 10, 2010 | Reddy HEATER R115 115,000-BTU PORTABLE...
150,000 BTU propane Reddy Heater shuts off after ignition
Is there a frost line on your LP tank, if so you may need to replace the tank with a larger tank or refill your tank. This can happen if the tank your using is too low or too small (use 100 lb tank or greater). If there is no frost line it may be an issue with the thermocouple. The manufacturer offers a service manual and owner's manuals on there site. This should assist you... www.desatech.com Thank you
Jan 28, 2010 | Reddy HEATER RLP100 100,000-BTU PORTABLE...
Read the instructions on how to light the pilot but where I need to put the match I am not sure where to direct the flame to. I see the housing for the pilot but not where inside
You noted above it is a Coleman forced air Heater with a electronic ignition? You don't need a match to light the pilot, it lights automatic on a call for heat at the thermostat.If it does not light, then you have other problems. Let me know.
Good Luck,
Shastalaker7
Nov 04, 2009 | Coleman Propane Forced Air Heater...
No ignition on dayton gas furnace. how hard is it to install new gas valve on a dayton furnace
not hard but before replacing check pilot light and thermocouple for proper function and setting if pilot light not in right position thermocouple wont open gas valve if electronic ignition check for power and proper gap on igniter also check stat for proper function
Oct 31, 2009 | Dayton Gas Furnace Heater
COLEMAN FURNACE BURNER NOT LIGHTING
There is a thermocouple "wire" that is supposed to be touching the pilot flame.
The thermocouple senses a flame (hot) and allows the heater to operate. If the thermocouple does not sense that the pilot is on, then it will not allow the furnace to operate.
Bend the thermocouple wire (or the pilot tube) so that the pilot flame is touchingg the thermocouple.
That shouls work now.
The air from the fan should not be blowing through the same cxavity that the pilot is in.
If it is, then you may have a leaking furnace whereby carbon monoxide may be seeping into your living quarters.
If the fix above works and the pilot stays on after the heater starts, then there is probably no leak.
Let us know the results ... post a comment or "RATE" this or another expert's solution.
Sep 16, 2009 | Coleman Propane Forced Air Heater...
Pilot lights but goes off when releasing valve to turn on
i would suspect defective thermopile or obsruction in pilot assembly that prevents pilot flame from hitting thermopile . check pilot flame characteristics, should be blue and stiff.if it is yellowish that would indicate blockage.use multimeter to determine voltage output. you need about 100mv to maintain pilot and around 400mv to operate control valve
Jul 06, 2009 | Pentair MiniMax 100 Aboveground 100,000...
Coleman space heather,when burners goes on it blow's out
it sound like the pilot is too small which would make the pouf sound pilot could be blocked , it should light with a wow wohumph
sounds silly but it the best way to say it or the burner lights smooth
Feb 07, 2009 | Coleman Propane Forced Air Heater...
Heater wont work
Jan 21, 2008 | Dayton (3E379) Heater
Dayton Gas Furnace Heater Logo
91 people viewed this question
Top Dayton Heating & Cooling Experts
paulcarew
Mack Baxter
Dan Webster
Dan Webster
Are you a Dayton Heating and Cooling Expert? Answer questions, earn points and help others
