Question about Dryers
Wiring diagram for w10410999
Looking for proper wiring of new style replacement motor
3 Suggested Answers
PegBox60965
  • 51 Answers
SOURCE: Looking to replace Patton fan motor, model 1010mp, style TJ74SP
If you are up to disassembling your motor, you will find a thermal cutout near the windings which frequently fails open. Replacements are readily available, or just jumper it out. If the bearings are shot or the windings burned you're out of luck. Trust me, a new motor will cost more than a whole new fan.
Posted on Jan 01, 2009
  • 248 Answers
SOURCE: Looking for a wiring diagram for a Yamaha BWS 50
The service manual has a diagram, but you need to zoom in to read the colors.
You can download a free one at
http://www.yamaha-motor-europe.com/community/service/manuals.jsp
Posted on Nov 21, 2009
Tip
Kelvinator Dryer Belt Diagrams and Replacement
Your dryer belt has broken and you have a new belt to install, but you do not know how to route the belt properly. Here are some pictures or diagrams to help you see how the belt needs to go. Of course the belt needs to go around the drum so that is not included.
The important part is the routing around the motor and the tensioner pulley.
!970- 1995 models use this diagram
Style: Flat with ribs
Installation Tips: Ribs face toward drum
1995 – present models use this diagram
Style: Flat belt
Installation Tips: Side of belt with words faces away from drum
on Mar 06, 2010 | Dryers
Wiring diagram how to replace old style GPO telephone junction box ?
This is the GPO junction using both BT (left) and old GPO (right). How far back are you going ? This setup assumes you have the British Telecom wiring at some point. Hope this helps...
Oct 03, 2016 | Cars & Trucks
Dryer wont start after installing w10410999
I had the same problem. Root cause was connecting the red wire to ground instead of pin 5.
Ground is between pins 1 and 5. Since it has no label, it is easy to miss the fact that pin 5 is not right next to 1, and connect red to ground instead.
May 07, 2013 | Maytag Dryer Drive Motor - W10410999
Tip
Gibson Dryer Belt Diagrams and Replacement
Style: Flat belt
Tip
Hotpoint Dryer Belt Diagrams and Replacement
For Hotpoint Dryers
1970- 1990 standard capacity
Installation Tips: Ribs against drum
1970- 1990 Large capacity
1990 – to present
1b9906a.gifStyle: Flat with ribs
Whirlpool gas dryer turns on drum spins exhaust is clear and blows air but it wont ignite
  1. Changing from 3 to 4 wire hookup on a electric dryer
  2. Door switch replacement help for a common door switch
  3. Dryer basics - Venting problems and power supply
  4. Dryer basics - timers and how they work
  5. Dryer basics - power cord problems
  6. Dryer basics - dead dryer
  7. Dryer *general* repair flow chart....Click here
  8. Gas dryer smell
  9. How do dryer thermostats work?
  10. How long can my dryer vent be in length?
  11. How to change a common rear drum seal
  12. How the belt is suppose to look at the motor and idler pulley
  13. Help on replacing dryer motor  and some wiring tips for the 279827 motor
  14. Help on replacing dryer motor  and some wiring tips for the 279787 motor new25.gif
  15. Help for storing an appliance
  16. Important Disclaimer
  17. I dropped something down the lint filter area....help!
  18. Inglis, Whirlpool and Kenmore most common style dryer - how to take apart ( lint filter on top )
  19. Inglis, Whirlpool and Kenmore most common style dryer - how to take apartslide show ( lint filter on top )
  20. Whirlpool or Sears dryer with heater on the floor and four rollers for drum style - take apart helps ( lint filter in the door )
  21. Inglis, Whirlpool and Kenmore electric style dryers - no heat problems
  22. Inglis, Whirlpool and Kenmore electric element changing procedures
  23. Inglis, Whirlpool and Kenmore dryers - air flow
  24. Inglis, Whirlpool and Kenmore style dryers - noise problems....drum rollers and idler pulley information....
  25. Inglis, Whirlpool and Kenmore style dryers - belt change
  26. Inglis, Whirlpool and Kenmore dryer general motor problems
  27. Inglis, Whirlpool and Kenmore gas style dryers - no heat problems
  28. Inglis, Whirlpool and Kenmore dryers - where are my thermostats
  29. If your drum belt looks like either of these....change it!!
  30. Idler pulley slide troubles with newer Whirlpool build Roper dryer
  32. Newer style Whirlpool - Inglis - ( some ) Kenmore dryer front drum support ring install help
  33. Pilot flame help
  34. Sample wiring diagrams
  35. Test for ohm meter checking on electric dryers with no heat
  36. Taking apart an Duet or HE3 dryer for a belt change
  37. Taking apart a Whirlpool Thin twin washer/dryer to replace the belt
  38. Timers and some common Auto dry troubles and solutions
  39. What is a grounded element?
  40. Whirlpool - Kenmore dryer motor problems in the dryer with Even HeatControl....info on this is here  + new25.gifExpanded repair helps for a common "Even Heat" dryer
Mar 30, 2009 | Whirlpool LGR8648L Gas Dryer
Tip
Estate Dryer Belt Diagrams and Replacement
For models with non-removable back panels use this diagram:
For models with removable back panels use this diagram:
Tip
Kitchen Aid Dryer Belt Diagrams and Replacement
Tip
Roper Dryer Belt Diagrams and Replacement
Tip
Whirlpool Dryer Belt Diagrams and Replacement
Dryers Logo
141 people viewed this question
Top Dryers Experts
