Question about Crosley Audio Players & Recorders
Crosley 2012 "Third Man Records" edition turntable auto return engages prematurely
Model is CR6015B. Auto return engages before longer (less dry groove before label) records end. On others less "long" there is a latching sound during the last several seconds of a 45. Is there an adjustment, or can the auto return be disabled entirely?
  • sirguitarist
    sirguitarist Nov 08, 2012
    I discovered an easy way to disable the auto return. Remove the platter (c clip off spindle) and a metal lever that pivots on top of the center gear is easily removed with a small Phillips screwdriver. Removing this disables the auto return. Alternately, it appears if you file or grind off a very small amount off the lower tab on the pivot, this would allow for the auto return to engage a little "later" (when stylus is closer to the label) however the accuracy of such a fix is unknown. I simply opted to leave the pivot off as I don't really care about the auto return. I grew up with a manual turntable.
3 Suggested Answers
fire sine
  • 382 Answers
SOURCE: Easrly stop
You will have to disengage the mechanical switch off lift. Pretty nice for an automatic turntable.
Keep me posted.
Posted on Oct 28, 2007
freetek
  • 5568 Answers
SOURCE: new crosley CR249-GR "wow and flutter"
I see your message isn't new anymore but Crosley does have a website with warranty and support info:
Crosley Radio
Posted on Aug 15, 2009
Crosley Cruiser turntable vibration noise
How to Identify Damage in Your Record Player ' eBay
www.ebay.com > ... > Record Players/Home Turntables
They produce audible sound by reproducing sound vibrations from tiny grooves etched on the surface of vinyl records. Record players have three primary ...
Crosley Cruiser Turntable Review - YouTube
? 2:26
https://www.youtube.com/watch?v=w5KVANeimVU
Dec 8, 2013 - Uploaded by DTM
This is a review of the Crosley Cruiser turntable. ... cartridges (the mechanism that converts the vibrations of ...
Just getting into vinyl. Is there any way to improve a Cros
Dec 14, 2015 | Crosley CR8005A-TU Cruiser 3 Speed...
How can I stop the tone arm from returning too early on smaller records?
The adjustment for auto return position is normally at the tone arm base on the left side under a rubber grommet. Use a flat blade screw driver to move adjustment screw, then test. Keep fine tuning until arm lifts at desired position. Cheers John. Stylus City NZ
Jun 14, 2014 | Crosley 0187SST Turntable
Type Crosley Model # of your device user manual " into search engine and it will show sites to get manual. In it there might be a way to help you
Where is a Crosley repair facility?
If you registered the product with Crosley you can contact them.
Otherwise it seems you have to contact the distributer of the product for the nearest service center.
May 07, 2014 | Crosley CR248 Turntable
Crosley Turntable Repeating little bits?
Is this on all records? if yes! you need to adjust the weight slightly, if the problem is with one record, clean the record in luke warm water and dry carefully, may solve the problem.
Apr 16, 2012 | Crosley CR49 Traveler Portable Turntable...
My records stop prematurely. the record stops spinning when the arm is in the middle and as a result i cannot hear the end of the record.
The only logical cause is a weak belt, as the arm reaches the center of the platter, the load on the belt becomes to great and it slips around the motor pole. I would replace the belt! Then see if it works.
Jun 18, 2010 | Crosley Conductor CR73 Turntable
I have an older 78 record, and the arm automatically returns before the recorded track is finished playing. Anyway I can bypass the auto return?
There should be some kind of screw on the arm to adjust it. You might have to experiment, or get a service manual. When adjusting, try doing it without the platter powered, by hand movement only.
Nov 27, 2009 | Crosley CR248 Turntable
New crosley CR249-GR "wow and flutter"
Crosley Radio
Jul 14, 2009 | Crosley CR248 Turntable
Technics Turntable Auto-return problem - please help !
Great!! You're Happy, I'm Happy.
Now there's some kind of rating procedure on this screen. If you could rate my asistance, I'd appreciate it, Dan.
thanks...
Charlie
May 30, 2009 | Technics SL-BD22 Turntable
Crosley CR79 4 in 1 Entertainment Center
Wild guess but try this with the power off. Rotate the platter clockwise about 5-10 turns. You may feel internal mechanical engagement as you do it. The cueing mechanism may cycle it through its motion and return it to the rest.
Jul 08, 2008 | Crosley 0187SST Turntable
159 people viewed this question
Top Crosley Audio Players & Recorders Experts
 Grubhead
Grubhead
Electro Med Services...
Are you a Crosley Audio Player and Recorder Expert? Answer questions, earn points and help others
