Bose 3-2-1 and AT&T U-Verse can't set Dolby Digital 5.1
3 Suggested Answers
SOURCE: PCM 2.0
I had the same problem with my 321 system. The fix is in the cable box settings. You want to change the Digital Out on the cable box..my choices were HDMI....Dolby Digital..and None. Choose Dolby Digital and it will show up on your Bose 321 display. I also have my cable box connected to my bose system via optical digital cable...and a digital coaxel cable from my dvr to my bose. Change that output setting on my cable box took care of the PCM 2.0 problem for me.
Posted on Dec 11, 2008
SOURCE: bose lifestyle 38 system, sound problems
Call Bose and get the latest software for your system. This will solve the problem.
Details:
I had the exact same problem with my Lifestyle 48 system connected to a Dish Networks satellite box (Vip622). The sound would continually switch between 'Dolby Digital 2.0', 'Dolby Digital' and 'Dolby Digital 5.1'.
I called Bose Tech Support and they had me reset all of the components. This helped for a short time but it was still happening. They told me that the problem was with the Satellite box, since the Bose system just output what it was receiving and didn't do anything else. We also determined that my system software was quite old. They said that the software wouldn't make any difference, but I got them to send it out anyway.
Well, when the new software update arrived, I installed it on my Bose system and have not had any audio switching problems. So the Bose system software update seemed to fix the problem.
Posted on Aug 20, 2009
We hooked it up and have no sound
From the Console Settings screen in the System area of the Xbox Dashboard, you can configure the video output of your Xbox 360 console for a widescreen, high-definition TV, determine your audio options, and check your console's serial number and Xbox Dashboard version.
Go to correct section for ... Audio
Change your audio output settings for games from this screen. These audio settings do not affect DVD movie playback. For DVD audio settings, refer to an individual DVD movie's setup screen.
Settings consist of:
  • Analog Output Settings: choose Mono to merge the left and right audio signals so that you can hear all sound through a connection to a monaural TV or monitor; choose Dolby Pro Logic II to listen in normal stereo (no audio surround receiver required) or to listen to Dolby Pro Logic or Dolby Pro Logic II soundtracks from compatible games or other media.
    Dolby Pro Logic consists of four channels of audio: front left/center/right and a monaural surround channel that is mirrored in each of your rear left/right speakers. Dolby Pro Logic II uses digital signal processing to generate 5.0 audio (front left/center/right, rear left/right) from any stereo (left/right) programming, whether from movies, music, or games. Unlike movies and music, however, games are specially encoded with Dolby Pro Logic II decoding in mind.
    To listen in either Dolby Pro Logic or Dolby Pro Logic II surround sound, you must connect your cable's left/right (white/red) RCA connectors to a compatible surround receiver. For more information, see our connection page for the cable you're using:
  • Digital Output Settings: configure this setting only if you'll be using the Toslink optical digital-audio output from a compatible Xbox 360 AV cable (optical digital-audio cable sold separately):
    The default digital-audio setting is Dolby Digital 5.1. If this is your preference, you do not have to make a selection from this screen.
May 13, 2011 | Microsoft Xbox 360 Console
I have the following equipment and am going crazy trying to figure out how they get connected together. I also have the Carver Multi CD player and Carver Cassette Deck which I was able to connect to the...
Get a separate amp for the 901's and the rest falls into place.
1,2, 5) Place the 901 Active EQ between the pre/main front OUT of the receiver and the TFM-55X. Attach the 901's. Keep track of the jumpers you remove from the receiver. Or replace the jumpers with RCA splitter cables so you still have pre/main connection but can share the output with the TFM.
3) Pinnacle subwoofer (self-powered?) to the subwoofer out of the receiver.
4) Bose (AMS???) 5. As surrounds on the receiver. Place the sub module toward the rear so it mates sonically and directionally with them.
What? No center speaker? I'd get something more robust with bass capabilities, like a pair Bose 301 series 1's because the tweeters face in one direction only.
Except for the amps and the cube stuff that is essentially what I have. 6.1 with full-range speakers everywhere.
Aug 31, 2010 | Onkyo TX-SR803 Receiver
I have a Bose v20 when i use my Panasonic DVD hd recorder it doesn't sort through if it Dolby or 5.1 it stay on 2.0 i have connected it with hdmi & optical cable
Hi Peter,You will need to check the input menus of both the Panasonic and Bose System and tell each of the units that they can output and accept 5.1 channel Look for wording such as PCM(2 Channel),DTS (5.1), and Dolby digital (5.1) AC3 (5.1). Sometimes inputs can be set up as auto, or analogue. I reckon that one of the two is setup to be fixed on PCM
Good Luck
Hope this helps
Jan 17, 2010 | Bose Lifestyle V20 System - black Theater...
Pretty much the same problem
I have the same system. I have a Lifestyle and a Sony TV with a Samsung Blueray player. I also have an X-box 360, plus my pc with all my CDs (I-tunes) plays through my bose. Do this:
1. Use the optical cable for the blueray player to the Bose (AUX).
2. Use a digital audio cable from the cable box (either black or orange output) to the Bose CBL-SAT digital input. (it's a single audio cable)
3. For my PC, I'm using a digital cable from the pc to the Bose. I'm using the TV output because it's empty.
4. For my x-box (which I'm not too happy about) I'm using regular red-white audio cables from Bose TV input directly to the TV audio out. (You can play all of the above through this channel, but don't).
I figured the most important high quality sound should come from the blueray player and from watching regular cable tv. For picture, you should be using all HDMI connections.
Hope this helps.
MC
Jun 26, 2009 | Bose Lifestyle 38 DVD Home Entertainment...
Bose PS 3-2-1 II speaker exspansion
Unfortunately this is impossible on the 321 series II systems. There also is no audio output on the media center to send to another amp either. As you may know, the 2 speakers are actually 4 speakers. Each small speaker array has 2 drivers. The 2 on the outside will project rear-channel audio to the sides, so placement of these speakers is important. Honestly, adding speakers would not make this sound very good. If the sound isn't too great as is, make sure you're using digital audio cables (optical or coax) from any external sources like a cable box or Blu-ray player. (if you don't see a Dolby Digital 5.1, DTS 5.1 or PCM 2.0 read-out on front of the media center, you'll know it's not digital. DVDs the exception)
Jun 18, 2009 | Bose 3·2·1 II System
Hooking up surround sound
to get the digital you have to have the digital optical line or the coax rca jack digital audio connection from device to stereo reciever to get the dolby digital surround sound to work , otherwise you can only get a virtual surround sound from the reciever( no dolby digital )
Jan 04, 2009 | Sharp CDBA3100 Remanufactured Mini-System...
Cant get all componenets to work together
Okay so you need to run a fiber optic cable to back of bose system for sound on the cablebox if it's a hd cablebox. If you don't have a fiberoptic connection on cable box then you can use a digital coax audio cable and plug it from cablebox if it has it to back of bose system where the plugs are colored all black under the red and white connections. This cable is basically a yellow video rca type cable. That cable doubles as a video cable and a digital audio cable. But anyways once you plug your cablebox up digitally you need to make sure under the settings or setup menu of cablebox that you go under audio and make sure your cablebox is set to dolby digital instead of hdmi. Especially if it's a scientific atlanta time warner cable box. The bose remote should operate eveything still unless I read your question wrong and your saying it doesn't.
Nov 09, 2008 | Bose 3 2 1 GSX System
Bose lifestyle 38 system, sound problems
Details:
Mar 01, 2008 | Bose Lifestyle 38 System
PCM 2.0
Dec 19, 2007 | Audio Players & Recorders
26 people viewed this question
 Grubhead
Grubhead
