Loss power power cut off reading protect warning then it cuts off
    Top Expert:
  • Televison & ... Master
  • 14,553 Answers
If its a receiver it means a problem exists--not any customer (for most people) serviceable parts---consider having a shop or tech look at the unit.
Posted on Nov 08, 2012
Dash "warning" lights all work but the speedo and tach do not lite up.
Wiring. The illumination usually has it's own power and ground wires. You'll need a pin out for the plug. Check the power and ground at the plug. Missing( most likely), Then check the power wire to any ground or the body. If you have power, then check the ground wire to any hot fuse. If you don't get a 12 volt reading, cut the wire and run a new ground. Same for the power wire. But it is best to run the power wire back to the light switch.
Mar 30, 2016 | Cars & Trucks
Intermittent power loss
have the OBD codes read as this will pinpoint the faulty sensor/switch , this will save you time and money searching for the fault blind , keep me posted if you wish
May 20, 2014 | 2006 Peugeot 206 1.4
Driving along lights dimmed, instrument panel died, loss of power then engine cut out & wouldn't start. Starts with a jump but when i turn key to heat glow plug, instrument panel goes mad
I assume there's a problem with alternator. Check the grounding to engine, check continuity of a positive wire between alternator and battery. the energizing voltage should be checked as well. Might be the bad connection between battery and vehicle body grounding. Diesel cars are sensitive even in a little loss of connection and rust in the connection points.
Feb 18, 2014 | Cars & Trucks
Volvo s40 1.6 diesel lost power and cut out no warning lights
Look for a foreign object in the fuel tank. I once had a carbon receipt plug the fuel pick up tube. You could be getting water in the fuel too.
Jan 14, 2014 | Volvo S40 Cars & Trucks
My car overheated after i change new cylinder head but now no start power loss in plug wire
It overheated because the cooling system hasn't been bled properly. When that happened it was detected by the ECM who cut off power permanently to prevent further damage.
You'll have to delete the warning from the ECM with a code reader for the power to return.
Oct 03, 2013 | 2007 Kia Sportage 4x4 V6
I had the 7in metal cuting ginding disc shater and cut cut my face from my noise to my forhead and i lost eye
posted in wrong section but if you read the warnings on the device and cutting wheel its says proper protection requirements safety glasses /face shield
Jan 20, 2013 | Cars & Trucks
My aquatek 110 power washer keeps cutting out. i have only used it three times and was carefull not to allow it to overheat. the filter is clear, as i checked this as recommended in the user guide but it...
the aquatek 110 power washer has an automatic cut-out for protection function. So its cutting out because its protecting the washer from one damage or the other.
From the look of things, the power washer is faulty, that's why it keeps cutting out.
Take care.
Jul 08, 2010 | Garden
Husqvarna 345 power loss and vibrates
Replace the bar. Your bar has gone bad and that is why you are losing power. Bars are made by the chain saws to be completely oiled at all times. When the bar does not get oil the bar will start to warp and that is what will cause you lack of power when trying to due a top cut
Feb 14, 2009 | Husqvarna Forest & Garden No.967012396 345...
Pioneer Inno
Perhaps memory is full
Jun 23, 2008 | Audio Players & Recorders
Televison & Video Logo
14 people viewed this question
Top Televison & Video Experts
Electro Med Services...
