Question about LG 22" FLATRON LCD Monitor
Analog out of range 74.9khz/60hz - LG 22" FLATRON LCD Monitor
3 Suggested Answers
budmrtn
  • 11361 Answers
SOURCE: I have a Flatron W2053TP
The PC video is too high for the monitor to display, need to be set to the native resolution of the monitor.
http://www.fixya.com/support/r4873371-fixing_out_range_format_not_supported
Please leave rating if it helps.
Basic LCD monitor and TV troubleshooting guide:
http://www.fixya.com/support/r5093881-lcd_flat_panel_tv_troubleshooting_guide
http://www.fixya.com/support/r6150077-basic_lcd_monitors_troubleshooting
http://www.fixya.com/support/r7406380-tv_training_manuals
Failed TV and Monitors: http://s807.photobucket.com/albums/yy352/budm
Learn about bad caps: http://en.wikipedia.org/wiki/Capacitor_plague
Parts: www.shopjimmy.com
Capacitors kit: http://lcdalternatives.auctivacommerce.com/Default.aspx he can make you a set of caps.
Or www.digikey.com, just make sure to use caps with low ESR, 105c, high ripple current and long life rating such as PANASONIC FM or FC series.
Posted on Jan 31, 2011
  • 1288 Answers
SOURCE: the screen is black and
Try to see if this works on another computer first, if it does, then it assumes the monitor is ok.
Then as the computer boots up, boot to safe mode by pressing F8 and once in that state, set the display to a mode that the graphics card will support.
If none of the full colour options work, the graphics card may be incompatible, try changing the graphics card.
Posted on Jun 13, 2011
The screen is black and a blue box in the middle that states "analog out of range. 67.0kHz/60Hz
Jun 13, 2011 | LG FLATRON W2252TQ-PF 22" LCD Monitor
Dear Sir, We have Toshiba REGZA 24PB1E LCD TV. I want to test our Gigabyte PC GA-G41M-Combo MB with VGA port (15 Pin Connector) Pls let us know how to connect & get the solution ASAP. For...
Hello
With either the PC IN or HDMI connection, you can watch
your computer's display on the TV and hear the sound from the
TV's speakers.
When connecting a PC to the PC IN terminal on the TV, use an
analog RGB (15-pin) computer cable and a PC audio cable.
To use a PC, set the monitor output resolution on the PC
before connecting it to the TV. The following signals can be
displayed:
Format Resolution V. Frequency
VGA 640 × 480 60Hz
SVGA 800 × 600 60Hz
XGA 1024 × 768 60Hz
Other formats or non-standard signals will not be displayed
correctly.
Note:
The PC audio input terminals on the TV are shared with the
HDMI-1 analog audio input terminals
Some PC models cannot be connected to this TV.
OK.
Mar 24, 2011 | Toshiba REGZA 47HL167 TV
Monitor error analog out of range
It is because your Windows monitor settings are OUT OF RANGE if you can boot into Windows normaly just rite click on the desktop, chose properties, than settings tab (if it's XP), go to advance, than monitor, look for frequency refresh rate, change to 60Hz, than save, than reboot
if you can't boot into Windows, try booting in SAFE MODE by pressing (F8) key at statup than do the above starting at -- rite click on the desktop, chose properties...
Cheers!
Jan 17, 2011 | LG Computers & Internet
Monitor says Analog RGB 1024 x 768 / 85 Hz Out of Range
install an AGP card into an AGP slot. use 8X AGP card then you can see high resolution because internal display card does not support to high resolution
Apr 02, 2010 | Xerox XR619DW Monitor
Installing new LCD monitor on Compaq. Getting error messsage :Analog Out of range 88.6 Khx, / 85Hz Please help Already tried to install any necessary drivers Mike
Your old monitor muts have been a CRT type. Reboot the PC into safe mode (hitting F8 key during boot up), then set the resolution to be 640 x 480 @60Hz. Then reboot, then readjust the resolution again to the native resolution of your new monitor (I cannot tell what that is since you do not give the make and model of the monitor), make sure to leave the refresh rate at 60Hz.
Jan 22, 2010 | Computers & Internet
Problem with my LG monitor L194WT
You will have to increase the referesh rate first and then go into the game and reset the resolution. The resolution bit is secondary. If increasing the refresh rate works, then you dont have to change the resolution :)
May 27, 2008 | Computers & Internet
Analog out of range
The TV maxes at a 60Hz refresh rate, and the game refreshes at a 120Hz refresh rate - common problem for that game and this TV - you will have to change the game resoltuion to 480i or 480p from the gaming system/pc itself (or change pc refresh rate to 60Hz, and 480 X whatever reoslution).
May 26, 2008 | Gateway FPD2275W LCD Monitor
Screen resolution problems
I just rang Samsung about this problem and they immediately said they would replace the monitor, no questions asked!
Oct 26, 2007 | Samsung SyncMaster 713BM 17" LCD Monitor
Monitor out of range
What Hz is it giving you? If it is less that 60Hz, you need to go into the monitor setup and raise the frequency up to 60Hz minimum. If it is higher than 75Hz, lower it to 60Hz.
Aug 13, 2007 | Compaq MV 9500 (Carbon, Silver) 19 in.CRT...
Analor out of range
lower refresh rate to 60hz
Oct 28, 2006 | LG L1722P 19" LCD Monitor
LG 22" FLATRON LCD Monitor Logo
242 people viewed this question
Top LG Computers & Internet Experts
Alun Cox
Are you a LG Computer and Internet Expert? Answer questions, earn points and help others
