Question about Moen Plumbing
I have a moen faucet,it looks like a t943. I can't get the handles off to fix a leak.trher are no set screws or access from handles
It is a 2 handle, looks like a t943 I can't get the handles off
  • 9 Answers
SOURCE: Repair cartridge in Moen Monticello single handle lavatory faucet
After some additional experimenting, contrary to information I was previously able to gather, I discovered that the white plastic retainer doesn't (in this type of Moen faucet) actually screw off but rather is held in place by a spring clip inserted from the rear of the retainer (toward the wall side of the basing). Simply sticking a small screwdriver in the opening (approx. 45 degrees downward) and tipping the screwdriver toward the front of the faucet, snaps the spring clip out through the opening.
The plastic retainer than lifts off. Note: the flat sides on the retainer suggest that a wrench will be needed but such is not the case.
Posted on Nov 28, 2008
  • 148 Answers
SOURCE: Kohler Forte Single Handle Faucet Leaks
you will have to replace the ball assembly with a repair kit
1 turn the water off under the sink (hot and cold)
remove the handle ( you may need an allen head wrench to remove a hex screw or you may have to take a channel lock pliar and unscrew achrome
nut over the ball mechanism
after the handle comes off there is usually some type of lock nut that you must remove to remove the ball mechanism
remove the ball (usually chrome or brass(ther are usually little springs and rubber washers under ball
take ball and washer to ACe or lowes and match the pieces (usually sold as a kit
follow directions and installl
turn water on and pat yo!ur self on the back !
Posted on Jan 05, 2009
  • 11 Answers
SOURCE: Moen Villeta 2 handle bathroom faucet, need to disassemble
hold the handle and twist the piece below that doesnt turn, anti-clockwise, it should unsrew and the handle should pull off.
Posted on Feb 11, 2009
1stBSP
  • 52 Answers
SOURCE: I have a Moen Single Handle kitchen faucet, it's
Replace the "O" rings that are behind the spout portion. You will have to remove the top of the faucet and pull up on the spout section. There will be a couple of "O" rings there. It is best to have Moen send the parts to you as locating the proper size "O" rings can be difficult.
Posted on Apr 06, 2010
SOURCE: handle won't stay up
I did the same thing recently, that is replaced the cartridge on my moen kitchen faucet to stop and leak, and I also have the same problem. I called moen back and they sent me another cartridge that was supposed to fit tighter, I suppose. I just put the new one in and it still wont stay up. I'm going to call moen one more time and then I guess I'll have to buy another faucet, but NOT moen!!! Good luck with yours.
Posted on Jul 22, 2010
How do I remove the cold water faucet cartridge on a Monen high arch, 2 handle w/sprayer, series 7700 Montecello
  • How to Fix Leaking Moen High Arc Kitchen Faucet -DIY blog.trebacz.com/2012/12/how-to-fix-leaking-moen-kitchen-faucet.html Video embedded · Our Moen high arc kitchen faucet started to leak around the base of the high spout. We had the Moen Monticello 7700 series single handle faucet for 8 ...
  • Frequently Asked Questions (FAQs) Regarding Moen Faucets www.moen.ca/consumer-support/faq ... a cold water filtering faucet, ... tighten the cartridge nut or replace the cartridge. If the faucet has a handle connector: ... Remove the faucet handle.
  • Monticello by Moen - Monticello www.moen.com/monticello/_/N-1z141yd Monticello. Chrome replacement handle knob insert ... As the #1 faucet brand in North America, Moen offers a diverse selection of thoughtfully designed kitchen and ...
  • Installation Help / Animated Tutorials for Moen Faucet www.moen.ca/consumer-support/installation-help Moen's animated tutorials provide installation help for many of Moen's ... How to Remove & Install the 1222 Cartridge. ... Removing a Single-Handle Kitchen Faucet ...
  • Contractor John replaces a cartridge in a Moen faucet ... www.youtube.com/watch?v=FqzpRE-MmEo
    • BY CONTRACTOR JOHN
    • 11 MIN
    • 279K VIEWS
    2011-10-26 · Contractor John replaces a cartridge in a Moen ... Repair Moen Single Handle Faucet, ... How to remove an old kitchen faucet and install a ...
  • May 05, 2016 | Plumbing
    Leaky faucet
    This is generally due to a loose or faulty cartridge. To fix:
    1. Turn off water supply valves under sink.
    2. Block the sink drain to avoid losing small parts.
    3. Remove faucet handle. It is attached by a set screw, an odd size (I actually used a T9 torx screwdriver successfully, even though the set screw is hex head, since I did not have a matching allen key). The set screw is quite far into the handle, ~3cm, through a hole in the bottom of the handle. Depending on your countertop layout, you may have to actually remove the entire faucet from the countertop in order to get access to it, in which case follow the appropriate parts of your faucet installation directions in reverse.
    4. Remove dome. It will come off with a gentle turn/pull.
    5. Check the tightness of the exposed large hex nut. This is the piece that holds the cartridge in place. If you are lucky, it is just loose, and that's your problem; otherwise you will need a new cartridge.
    6. Unscrew that nut, remove. Pull out the cartridge.
    7. Replacement cartridges may be found at your local Moen dealer, or may be ordered directly from Moen +1-800-Buy-Moen. Parts are free due to the lifetime warranty. Part #1255 includes the cartridge, cartridge nut, and set screw. The nut must be changed with the cartridge (presumably due to its wear characteristics).
    To reassemble:
    8. If you have it, place a very small amount of plumber's silicone lubricant on the back of the cartridge, on the rubber seals around the three holes.
    9. Assemble in reverse order of disassembly. The cartridge only goes in one way, due to three guiding channels on its perimeter.
    Enjoy!
    Oct 08, 2012 | Moen 87877SRS Haysfield Spot Resist One -...
    I have a moen 7637 single handle kitchen faucet that leaks around the stem. How do I take the lever off.
    1) Use a small sharp-pointed knife and pop out the little plastic Moen logo at the bottom of the front side of the handle (and don't lose it!)
    2) Lift the lever up a bit (the water may turn on) until you can see a small screw with an allen wrench socket.
    3) Unscrew the allen-head screw; the handle will lift straight up.
    Look down into the faucet; there's a philllips head screw. The leaking may simply be caused by this screw being loose.
    May 01, 2011 | Microwave Ovens
    How to tighten Moen Handle...Not leaking, just wobbles.
    Replacement parts can be found on amazon, click here and take a look: Award winning faucets and shower heads. Have a nice day
    Mar 12, 2011 | Moen 7840 Camerist Single-Handle Kitchen...
    Need to change washer faucet
    Probably what you need to do is change the cartridge. You will need a Moen cartridge puller to help with removal and reinstallation. You can get these and the cartridges at most hardware stores. Shut Off Water first, remove set screw that secures handle and carefully remove handle. You may have to tap lightly on rim of handle to free it. There is a retaining clip that holds cartridge in place, it will have a small round hole on top. Carefully remove clip using neddle nose pliers or perhaps ice pick inserted in hole to remove clip.Install puller as per instructions and tighten nut to remove cartridge. Install new cartridge andclip. put handle back on and install screw. I need to back up here and say that screw is normally located under moen insignia in middle of handle. Pry cover off with screw driver or knife blade to access screw. After you have cartridge, retaing clip and handle reinstalled turn water back on and check for leaks. Hope this helps. Thanks.
    Nov 11, 2010 | Moen Bathroom Sink Faucet - Single Handle...
    I have a loose handle on my Moen two hanlde lavatory faucet and i can't find any set screw to tighten it . How to tighten the handle to the faucet stem?
    Take handle off and check out the inside to make sure it not striped out and on the top of the handle it may have a plastic cap to pop of to access the screw holding in in place you amy have to use a knive to get it off .
    If you can't see a set screw it may have a screw in handle on top.
    May 03, 2010 | Moen & Villeta Two Handle Lavatory Faucet
    Leaky moen 2 handle faucet
    if memory serve's me,you will need to remove a stem extension,screw in center,and you may need a tool #103462 to remove cartridge.1'st stem ex't is red,(hot) blue (cold), remove, look down,white piece w/ 2 notch'es, this hold's cartridge down, ya might try needle nose plier's to remove,a little lube help's upon re assembly, carefull w/plastic thread's
    Apr 26, 2010 | Moen Monticello Single-Handle Kitchen...
    Moen 87135c - cant take apart
    On handle of faucet you will see a red/blue plug button, under that is a set screw. loosen and this will allow you to remove handle.
    Oct 03, 2009 | Moen 7065 Vestige Single-Handle Kitchen...
    Plumbing Logo
    Top Moen Plumbing Experts
    john h
    Donni Steen
    Don Numinen
    Don Numinen
    Are you a Moen Plumbing Expert? Answer questions, earn points and help others
