Question about Motorola Mobility Backflip Smartphone
How do i create a new APN (access point name)?
I bought a straight talk sim card for my backflip that i got from at&t, i bought the correct sim card from straight talk and the directions tell me to enter settings in fielss i.e. name straight talk APN att.mvno and about 5 other feilds, before i can add a service card to use the phone for straight talk, its set up fo at&t and i see where to go but i can't seem to add or change anyting ??
Settings for apn are blank. what is my apn code
Hi Edward,
Here are the steps..
Internet Setup
Step 1: Enter Settings
Step 2: Select Wireless & Networks
Step 3: Select More...
Step 4: Select Mobile Networks
Step 5: Ensure Data Enabled is checked (enabled).
Step 6: Select Access Point Names
Step 7: Create a new APN (Select Menu, followed by New APN). Enter WIND Data as the name for the new APN. Under the headings APN enter internet.windmobile.ca (leave all other fields blank).
Step 8: Save the APN settings by selecting menu and then save.
Picture Messaging (MMS)
Step 7: Create a new APN (Select Menu, followed by New APN). Enter WIND MMS as the name for the new APN. Under the following information in the listed headings:
  • APN: mms.windmobile.ca
  • MMSC:http://mms.windmobile.ca
  • MMS Proxy: 74.115.197.70
  • MMS Port: 8080
  • MCC: 302
  • MNC: 490
  • APN Type: mms
  • Leave all other fields blank.
Android 2.1 to 2.3
Internet setup
Step 3: Select Mobile Networks
Step 4: Ensure Data Enabled is checked (enabled).
Step 5: Select Access Point Names
Step 6: Create a new APN (Access Point). Enter any name you would like to call your internet connection and the access point as internet.windmobile.ca (leave all other fields blank).
Picture Messaging (MMS) setup
Step 6: Create a new APN (Select Menu, followed by New APN). Enter WIND MMS as the name for the new APN. Under the following information in the listed headings:
  • MMSC: http://mms.windmobile.ca
  • MMS Port: 8080
  • MCC: 302
  • MNC: 490
  • APN Type: mms
May 10, 2016 | HTC 7 Surround T8788 Windows 7 Wm 3.8"...
Tip
Nokia X internet settings
Tap Settings > Mobile data and networks. Make sure Mobile data is On and that the correct SIM card is active.
Advanced settings > Access point names. Check that the correct
If at the step above, you have no APNs under Access point names, swipe up from the bottom of the screen and tap New access point to create a new APN
on May 23, 2014 | Cell Phones
How to use APN
The first thing you'll need to do is find the right APN settings for the network you want to use. For example below are the APN settings for Straight Talk.
Name- straight talk
APN-tfdata
Port-80
MMSC-http://mms-tf.net
MMS Proxy-mms3.tracfone.com
MMS Port-80
Once you have all this information, grab your phone. Settings>wireless/network settings. More options>mobile networks.
Once you found mobile network settings, rest will be the same on all devices. Look for "Access Point Names" then tap on it.
You should see a list with at least one APN. Add new.
This is where you will enter the settings you got from your carriers website. 2 very important things here:
    1.Not every setting in the "edit access point" screen will need filled in.
    2.Be sure to type in everything exactly as provided by your carrier. Once you have settings provided by your carrier entered, you need to save the APN. You do that by pressing the 3 dots in upper right and selecting "save" option.
    Once your APN information is saved, go back one screen to the list we saw earlier. On this screen, tap the new APN settings you just entered to make active.
What is an APN and how do change it
Oct 31, 2015 | Samsung GALAXY S4
How do I delete the current APN and add the correct one for straight talk?
OK first of all go to settings, more, mobile networks, access point names, then press menu, select new APN, type the name of your service provider followed internet e.g MTN INTERNET, type Internet at where the APN is and then press menu again and select save. you are done
Jul 18, 2014 | HTC Inspire 4G Smartphone
I am having trouble connecting to internet even when 3g available for several days
under 'settings' -'more' - 'mobile networks' - 'access point names' hit menu key on bottom right of phone then 'new apn' under name enter STRAIGHT_TALK, under apn enter tfdata, scroll down to MMSC and enter http://mms-tf.net, then in MMS proxy enter mms3.tracfone.com, and under MMS port enter the number 80. hit menu key and select save. then return to access points and click on the button to the right of STRAIGHT-TALK.
thats how to fix it i had to do it i got that from straight talk forum
Jun 19, 2014 | Straight Talk LG L40G Cell Phone
Di ako makapagfb using myphone Q19i...paano po b dapat gawin para makakonekta ako gamit ko ung cp n un? ty.
APN Settings for Globe, Smart, Sun, WeRoam Cellular
The following settings are applicable to Smart, Globe and Sun Cellular for their APN settings (Access Point Name). The settings should work with majority of smartphones in the market.
Postpaid APN: internet.globe.com.ph
Prepaid APN: http.globe.com.ph
APN Settings for Smart Bro
Postpaid APN: smartbro
Prepaid APN: smartbro
APN Settings for Smart Buddy, Smart Gold
APN: internet
APN Settings for Sun Cellular
Prepaid
APN (static): minternet
Authentication: PAP
IP address: dynamic
Postpaid
APN (static): fbband or minternet
Authentication: PAP
IP address: dynamic
APN Settings for PLDT WeRoam
Postpaid: WEROAMPLANor internet
Note: If you’re using a variety of postpaid or prepaid SIM cards in one dongle, make sure to create a Setting Profile for each SIM card so it’s easier to set the APN when switching SIM cards.
Leave all other settings blank or as is.
Mar 05, 2014 | Computers & Internet
Is there anyway to get a free unlock code
I just went to Walmart and bought a "BYOP- which means (bring your own phone" sim card package for $55.00 from Straight Talk" follow the directions then since I could not edit my APN settings for internet use I downloaded APN /RESTORE and BACKUP from Google Play Store and deleted AT&T APN settings after that download again from Play Store TWEEKER and follow those instructions just by a push of a and it will install your Straight Talk apn settings automaticly and you have full internet access.
Jun 19, 2012 | Sony Ericsson Xperia Play 4G
Unlock codes for huawei u8652 fusion
Huawei U8652 Fusion
How to make the data work when switching from ATT GoPhone to Straight Talk
(you do NOT need any unlock code!!)
1. go in to settings, wireless and network, make sure wifi is off, then go to mobile networks, make sure data is on, and open access point names.
2. click menu, reset to default, THEN click menu, and new apn like this (if not on this list, leave alone!):
APN: wap.tracfone
Port: 8080
MMSC: http://mms.tracfone.com
3. click menu save, then go back, select the straight talk apn you created.
4. turn phone off, turn phone on, and data should now work!!!!!!!!!!!!!!!!!!!!
Feb 25, 2012 | Cell Phones
Hi. Please help i cant use Globe network as my internet for my HTC Wildfre. Please help the correct settings of mobile network. thanks
1. Go to Settings->Wireless & Networks->Mobile Networks->Access Point Names
2. Click Menu->New APN and follow the setting below (leave settings as is for those not mentioned)
  • Name: Globe Internet
  • APN: http.globe.com.ph
  • APN type: default
3. After saving the settings above, select the newly created APN (green radio button appears).
Your phone is now configured to use the newly created APN.
May 04, 2011 | HTC Wildfire Cell Phone
Motorola Mobility Backflip Smartphone Logo
171 people viewed this question
Top Motorola Mobility Cell Phones Experts
Virgil Wolter
Level 1 Expert
Rami Obeid
Level 1 Expert
D. E. Hev
Are you a Motorola Mobility Cell Phone Expert? Answer questions, earn points and help others
