Question about Singer Sewing Machines
Singer 9030 runs but don't sew
Machine runs, it's threaded and the bobbin is in correctly but thread doesn't seem to lock to form the stitch. Sometimes it forms the first stitch then no other. Feed dogs work so fabric moves smoothly over them.
  • Singer Master
  • 7,365 Answers
Try changing the needle--make sure the needle is the correct one
for the fabric being sewed.
also make sure the needle is turned the correct way in the needle
holder and pushed all the way up into the needle holder.
Posted on Nov 08, 2012
2 Suggested Answers
  • 233 Answers
SOURCE: singer sewing machine bobbin thread knots rather
What you have going on is a bobbin problem. The knots are referred to as birds' nests and happen when your bobbin thread gets caught on a piece of the bobbin casing. The large, loose stitches are normally caused by a problem with the bobbin case, a bobbin that is would properly, or when you're getting to the end of the bobbin's thread and the thread is loosely would on the bobbin at that point.
You're best bet is probably to buy a new bobbin casing. They're usually about $25 or so and you should be able to find one on eBay by searching for Singer (your machine name and model) under the Crafts category. The silver plate on top of the area covering where you place your bobbin into has screws you need to carefully remove (careful not to loose them!). If you need to, take pictures with your cellphone or digital camera as you remove the old bobbin casing so you can see how to put the new one in.
This should take care of the problem. If, for some reason it doesn't, you may well have a problem ALSO with your bobbin tension, and that should be looked at by a Singer Technician. You can find one in the yellow pages near you or probably by searching Yahoo Local. Happy Sewing.
Posted on Apr 04, 2011
Underthread in sewing machine keeps breaking
I am assuming your talking about the bobbin thread, so that is
the information I am sending you
Bobbin thread breaks
1. There is a right way & wrong way to insert the bobbin in the case --when you insert the bobbin in if it doesn't stitch correctly turn the bobbin over see if that helps or bobbin case is not inserted correctly
2. Lint has collected in the bobbin holder
3. The bobbin is damaged & doesn't turn smoothly
4. Lower thread tension is two tight
Nov 04, 2012 | Singer Sewing Machines
Machine jams after 4 or 5 stitches. Bobbin thread locks up.
try these suggestions
change the needle
make sure the thread doesn't come off the thread take up lever--this
can jam the machine
make sure the bobbin is turned the right way in the bobbin case--this
can cause problems if the bobbin is turned the wrong way
make sure the bobbin is not warped or damaged
make sure there are no burrs in the bobbin area or on the needle
plate
Oct 16, 2012 | Singer 8280 Mechanical Sewing Machine
ERROR 88
here are my suggestions
change the needle--make sure it's inserted correctly in the needle
holder
make sure it's the right needle for the fabric
rethread the machine top & bobbin --use every thread guide
clean under the needle plate & in the bobbin area for lint
make sure the thread has not come off the thread take up lever
make sure the correctly foot is on the machine when sewing
if the suggestions don't help then it would be a good idea to have
the machine checked
here's a free downloadable downloadable manual
http://www.singerco.com/uploads/download/1197_7444engfrespa77250.pdf
Sep 10, 2012 | Singer 7444 Mechanical Sewing Machine
I have a Singer Touch and sew 600e, the bobbin thread is all bunched up and machine jams up with thread. How can I fix this? Is there a simple setting that I am missing.
try changing the needle
make sure the bobbin is inserted correctly in the bobbin case
make sure the top thread is not coming off the thread take up lever
make sure the bobbin is wound correctly
if these suggestions don't work, I suggest that you take the machine
to a sewing machine shop to have it checked
Aug 06, 2012 | Singer Sewing Machines
Singer 7462 not picking up bobbin thread
it's very possible that the machine could be out of time & needs to
be checked by a sewing machine technican
Jul 29, 2012 | Singer 3820 Mechanical Sewing Machine
I have loaded my Singer 626 sewing machine bobbin properly, and when I try to bring the lower thread up by turning the wheel, nothing comes up. I do hold the upper thread taunt, so it can 'grab
Make sure your needle is correct for the machine and make sure it is fully inserted and undamaged.
you just hold onto the thread... you don't need to hold it taut.
Jul 28, 2012 | Singer Sewing Machines
Bottom thread bunches
clean under the needle plate & in the bobbin area for lint or thread
make sure the bobbin is inserted correctly into the bobbin case
if none of these suggestions help then it's possible that the machine is out of time & needs to be serviced
May 18, 2012 | Singer Sewing Machines
Singer 758 model and the thread is bunching up from the bobbin under the material
try changing the needle--flat side goes to the back of machine
rethread the machine top & bobbin--make sure to use every thread guide
make sure bobbin is wound correctly & inserted correctly in the bobbin case
clean under the needle plate & in the bobbin area for lint or loose threads
if you don't have a manual try singer
Go to the singer website
Click on customer support--there will be a drop down menu
Choose instruction manual
In the box type the model number(example 758)
Click search
Apr 10, 2012 | Singer Sewing Machines
I am having trouble getting my singer 6199 sewing machine to sew. The top thread will not pick up bot thread. I tried changing needle, changing bobbin, rewinding bobbin, rethreading machine & bobbin,...
did you get the needle in correctly--all the way up into the needle holder
& the flat side of the needle goes to the back of the machine
also after you check the needle & it's in correctly it's very possible that the machine is out of time & a sewing machine repair technican would have to retime the machine
Mar 01, 2012 | Singer Sewing Machines
Sewing Machines Logo
108 people viewed this question
Top Singer Sewing Machines Experts
Tally Girl
Tally Girl
mystery_soul
Are you a Singer Sewing Machine Expert? Answer questions, earn points and help others
