Question about Frigidaire 20.3 Cu. Ft. Frost-Free Upright Freezer - White
Frost at top of door inside and top of cabinet inside
    Top Expert:
  • Frigidaire Master
  • 9,472 Answers
What is the model number of the unit?
Posted on Nov 10, 2012
5 Suggested Answers
VOTIT
  • 2071 Answers
SOURCE: Ice build-up
Defected DEFROST HEATER can cause frost build up on the panel at the back of the freezer,and freezer stop cooling and ice frozen on unit so air could not flow to refrigerator side.Water will coming out caused of unbalanced freezing,and causing the flooding of water in the floor. You must change this defroster heater assembly so it will works normal again..
Hope this may help;
Regards,
VOTIT
Posted on Sep 22, 2008
  • 2187 Answers
SOURCE: Frost buildup around the inside top of the door of
This happens when your thermistor gets frozen along with the coils or there is a clogging of the freezer drain which causes Ice to build up and spread to the system. Another issue is that your thermistor may be faulty, telling the system inaccurate temperature. Incorrect freon pressure can also be a cause. I would advise first to have the ice melted by letting the unit stay unplugged and have it cleaned while at it.
Posted on Aug 11, 2009
  • 1531 Answers
SOURCE: Frost forming on top of inside door by hinge
try covering the hose in the bottom of the door with tape or remove the plugs and glue them shut.also the diffuser plate in the back of the freezer should be changed if you can not change it cover those holes with some aluminum tape.the insulation in the door panel should aslo be replaced there is a chance of ice built up in the door liner
Posted on Sep 17, 2009
  • 291 Answers
SOURCE: i am experiencing frost build up on the top part
You have an air leak. Usually right where you frost build up is, however since hot air rises, sometimes this leak can be anywhere. Make sure your door closes tightly and your gaskets are clean and making good contact. You may have to adjust the gasket, adjust the door, or replace the door gasket. If there is ice on the floor of the freezer, you have a plugged drain line. In very rare instances we have found, where the freon lines enter the freezer, in the back or under the freezer, missing or fallen refrigeration putty that seals around the lines. Good Luck, Appliance Specialists
Posted on Jan 28, 2010
How do you make a freezer frost free?
Frost free means that the evaporator coil will not accumulate a thick layer of frost. It will not prevent frost from accumulating on the walls of the freezer. To slow down the amount of frost build up inside the freezer, do not keep the freezer door open for any longer than necessary. The freezer door seal may be defective. This would allow moisture in that would freeze on the inside walls. A heater with timed intervals to come on is one way for a frost free feature. But this will not work for frost build up on the inside walls of the freezer. It would only melt the frost and then it would refreeze again.
Aug 31, 2015 | Frost Freezers
MY FREZER HAS FROST AROUND THE DOOR AND MOLD IS GROWING AROUND IT
You need to replace the door gasket. It's leaking air causing the frost.
May 04, 2011 | Whirlpool Freezers
My frost free freezer is building frost on the top part of the freezer between the door and the small divider, the seals appears ok with no gaps and it never shuts off 2006 model
there are two vent holes in the bottom of the door that need to be seal closed there has been air leaking in from these holes also the rear air diffuser should be solid and the vent holes in it coverd as well.then you nee to take one or two small washers and remove the front panel inside the freezer and put the washer between the panel so there is a small gap between the top of the freezer and the divider
Sep 26, 2010 | Frigidaire 14.1 cu. ft. Upright Freezer...
Hi My beko frost free freezer has been building up ice in the little grid thing at the top of the freezer. The temperature was also driopping ( to 8) and so I have put it on fast freeze to raise temp. What...
check the door seal on the top of the door if not sitting flat to the frame it will encourage frost to build up (inside the little grid thing)which will stop the rest of the freezer from cooling enough.
Jun 14, 2010 | Freezers
I am experiencing frost build up on the top part of the door as well as the top part of the inside of the freezer. all other areas are fine
Jan 28, 2010 | Frigidaire 20.3 cu. ft. Upright Freezer...
you probably have an air leak. if the gasket is bad it needs to be replaced. Air could also be coming in through the door flap if you have water and ice dispensor on door
Sep 17, 2009 | Frigidaire 20.3 Cu. Ft. Frost-Free Upright...
Admiral upright freezer dripping water inside on top
Hello.
I can help. Once we notice anything different from before we start becoming more aware of small variations. Regarding things on the top shelf warmer than on the bottom, this is always true because, "warm air rises and cold air falls". If you want the top shelf colder turn the thermostat to the next colder setting, always a good idea in the Summer season anyway.
Even though your gasket looks good, a ten year old gasket is not as pliable as a new one resulting in the moisture problem you describe. I would begin by applying a thin coating of vaseline to the gasket once a week for a month. This little trick of the trade will often work. If it doesn't improve the situation do replace the gasket.
Jun 25, 2009 | Kenmore Freezer 20.3 cu. ft. Frost Free...
Freezer door is accumulating frost inside it at the very top. Frost build up has been occcuring for 7to 10 days and we have been removing it periodically. Freezer purchased on 6-23-05. The gasket appears...
The gasket is not sealing correctly and is allowing warm air to meet cold air just below the seal.
Get someone with more skill to fit a new gasket , preferably one made by the original manufacturer , which should fit unlike some of the parts made by third party suppliers
Jun 11, 2009 | Frigidaire 20.3 Cu. Ft. Frost-Free Upright...
Upright freezer door inside developing ice
The door seal is at fault. Regardless of the small tear it is not sealing well.
Take a dollar bill and close it in the door. Then pull on the bill to feel resistance.
You will find it pulls easily in some place. That is where your air leak is that is causing the condensation.
Do this about every 6 inches all the way around the seal.
Mar 27, 2009 | Kenmore Freezer 20.3 cu. ft. Frost Free...
My woods upright freezer keeps frosting up at the top with several inches of frost. It is a manual defrost freezer. Any suggestions?
check your door seal, by closing the door on a strip of newspaper all round the seal. this fault is usually air getting inside the freezer, it rises to the top making thick ice or snow.
Dec 17, 2008 | Woods Upright Freezer MU07W
Frigidaire 20.3 Cu. Ft. Frost-Free Upright Freezer - White Logo
66 people viewed this question
Top Frigidaire Freezers Experts
AJMAL KHAN
Dan Webster
Dan Webster
John Tripp
John Tripp
Are you a Frigidaire Freezer Expert? Answer questions, earn points and help others
