Question about Bowflex Treadclimber TC5300
How to change the bushings on the tc5000 bowflex treadclimber
4 Suggested Answers
  • 41 Answers
SOURCE: bowflex treadclimber 5000
Hi ddmyatt.. They sell what is call dry lube at sports store's. for spraying under the tread's and on the wheels that the tread run's on.. Lift the tread and spray as far under it as you can on both side's. She'll be lot's quieter then before and lots easier on the motor too..
Posted on Nov 03, 2008
  • 49 Answers
SOURCE: My bowflex tc5000 will not calibrate
Check the speed sensor and make sure it is no farther than a credit card away from the drive pully. Unplug unit Located...remove left and right rear covers and back cover. 3 screws in each and 4 screws in back. Follow 2 black wires up to drive belt pulley under back of left treadle. slide sensor in with cc between it and the pully. Recalibrate
Posted on Aug 31, 2009
anupam19
  • 263 Answers
SOURCE: About 10-15 seconds after the bowflex treadclimber
Use grease
Posted on Mar 12, 2011
I'm having issues with the treadles knocking together on my Bowflex treadclimber tc5000. Is there any solutions?
If you wish to get some details about treadmill maintenance ; visit the site linked here. Pull up older posts. http://electro-medical.blogspot.com/
Jan 30, 2017 | Bowflex Exercise & Fitness
What does error code 1649uli indicate?
You have to call the Company representative who will guide you through the error code. Call :1-800-628-8458
In case you don't have the manual, here it is: http://www.searspartsdirect.com/partsdirect/user-manuals/TC5000-Bowflex-Parts-BOWFLEX+TREADCLIMBER-manual
Good Luck!
Feb 02, 2016 | Bowflex TreadClimber TC5000
Why does my Bowflex TC5000 cut out?
If you're running the machine on a dedicated circuit then your unit is drawing too much current. This can be caused by friction and drag. Solution: Lube deck/belt. If problem persists, replace deck/belt. If you ignore this fix this will blow your controller. .
Apr 29, 2014 | Bowflex Tc5000 Climber Treadclimber...
Treadles on tc5000 wobble and rub
You have to realign treadles ,take the back cover out and at the base of your unit you'll see two slides , couple of screws and yellow bushings if bushings are still in a good shape you can align treadles , if they're broken or worn out you have to replace them , I think there are 8 of them total ,they're called IGUS bushing
Good luck
Jan 05, 2014 | Bowflex Tc5000 Climber Treadclimber...
Bowflex TC5000 won't start! Lights on circuit board show power.
see the video and proceed according and fix it. God bless you
Jan 08, 2013 | Bowflex Tc5000 Climber Treadclimber...
My tc5000 keeps failing the cal can you help
Try again RUN the software calibration. and adjust the REED SWITCH, and Speed Sensor, test it, clean it, and tight the plug or connector from UPPER board vs lower board.
God bless you
Nov 16, 2012 | Bowflex Treadclimber Tc5000 Tc 5000 W In...
How do you replace the breaker on a tc5000 treadclimber
VERY EASE DISCONNECT THE POWER CORD.
Disolder the wires with Solder Gun, change the breaker and again put solder in the terminal, please do it with carefully, and very tight the terminals.
the breaker is to side from main switch.
sincerely.
Oct 09, 2011 | Bowflex Treadclimber
Where can I get this machine serviced? The gate feels uneven. The left pad almost seems to be hitting ground before the right pad completes its stride.
hello. call bowflex directly and ask Call (800) 667-1689. They probably have service centers located around the world. Joe
Mar 01, 2010 | Bowflex Treadclimber TC5300
Bowflex treadclimber 5000
Nov 03, 2008 | Bowflex Treadclimber TC5300
Bowflex Treadclimber TC5300 Logo
23 people viewed this question
Top Bowflex Sport & Outdoor - Others Experts
Jerry Greenberg
Jerry Greenberg
Tom Chichester
Are you a Bowflex Sport and Outdoor - Other Expert? Answer questions, earn points and help others
