Question about Amana ARB9059CS Bottom Freezer Refrigerator
Amana refrigerator aff2534few3 is not cooling
How do a deforst the frezzer
2 Suggested Answers
  • 2520 Answers
SOURCE: my frezzer works but refrig doesnt cool well
open the freezer door,do you hear the fan blowing,if not hold in the door switch for a few deconds and let it go,if the fan isn't blowing this is your problem.all that happens is the freezer gets cold,the evap fan blows cold air through the damper and into the fridge section so if the freezer is fine you have a bad evap fan motor or the damper isn't opening all the way
Posted on Nov 19, 2011
How do a fix a refrigerator which makes a clicking noise when light in freezer is off? If I open the freezer door it stops. If the door is open and I depress the light switch, it starts the noise aga
That's a weird one. It sounds like the switch operates a relay that cuts off power, and the relay is "chattering." If so, the only way to stop it is to replace the relay. Call a technician if you're not comfortable getting into the inner workings of your freezer yourself.
Nov 06, 2014 | Amana Refrigerators
Amana refridgerater freezer will not keep freezer frozen
this might have something to do with the defrost disk located in the frezzer behind the panel, its a small round disk attached to your coils. get a part or model number and look it up. hope this helps.
Feb 12, 2013 | Amana Refrigerators
The frezzer works, my refrig is just barly cool. when I open both doors i feel cold are going into the refrigerator
the jazz board or control board is 12868513 and it's around 100.00 dollars,the defrost thermostat is 67004757 and it's around 35 dollars and the calrod heater is 67004188 and is around 25 dollars this is on the sears site.
Nov 19, 2011 | Amana 22.6 cu. ft. Side-By-Side...
Food in freezer deforsted - we removed all food put control on 7 and put on the ice maker - overnite we got ice and ancontainer with water froze do u think it was just to low a control it is an amana...
Many times a freezer and/or refrigeratordo not work right because of a dirty condenser coil...there are also many otherthings that can go wrong. If you are hearing a clicking or buzzing thencheck out the last two tips.
If your refrigerator is running but warm, then...
Check out these tips that I wrote about that... it is a great place to starttrouble shooting your unit...and something that you can do rather then callinga repair person to do a simple thing for you...
Refrigerator Condenser Coil Cleaning Refrigerator Repair
Refrigerator Troubleshooting Refrigerator Compressor
Refrigerator Compressor Start Capacitor and Start Relay
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
Aug 27, 2011 | Amana Refrigerators
Refrigerator not cooling,freezer iceing on back wall.
u have a defrost problem.. your deforst timer needs replacing.. u also might have to replace your heaters and the terminal switch.. but if it doesnoit deforst right it wont cool. ok
Feb 11, 2011 | Refrigerators
Where is the deforst timer on my maytag
Some units are different. Some are located behind the temp control unit, others located up inside top of unit behind the panels. There is usually a diagram on the back of your fridge
Jul 09, 2009 | Maytag MZD2666K Side by Side Refrigerator
Frezzer and refrigerator work sometimes
  1. check rear wall of freezer for ice build up, if so unit is not defrosting
  2. check to see if fan is running in freezer
  3. check to see if compressor is running
Nov 23, 2008 | Kenmore 55612 / 55614 / 5561 / 655619 Side...
Maytag MSD2356AEW Side by Side Fridge not Cooling enough
Deforster not kicking in. There is a chip that is supposoed to kick in thte Auto Deforst on the frezzer side. It fails and the system freezes up and can not circulate cold air form the freezer side to the Fridge side. Simple repair, but yo will needed a service tech for this.
Jul 20, 2008 | Refrigerators
Amana ARB9059CS Bottom Freezer Refrigerator Logo
Top Amana Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Dan Webster
Dan Webster
Are you an Amana Refrigerator Expert? Answer questions, earn points and help others
