Question about Kenmore Side by Side Refrigerator
The rubber sealer material around the two doors has become very hard. Where can I get replacemnets for Side By Side Refrigerator Part # SR 1087
    Top Expert:
  • Kenmore Master
  • 9,472 Answers
Could you please give me the model number that is listed on your refrigerator?
Posted on Nov 08, 2012
Why does the rubber sealer on refridgerator door and freezer door get hot
Inside the frame is a warm bit of pipework, or sometimes a mullion heater, that stops the seal freezing to the frame.
Aug 21, 2014 | LG LSC26905TT Side by Side Refrigerator
Hi, my refrigerator door squeals very loud when you open it. The freezer side door does not make noise. I think it might be a washer at the bottom of the door, but I don't want to spray it with a...
You can try a silcone spray, that shouldnt damage any plastics or rubber. Also check the door seal. Make sure its clean. Sometimes, cordials, coke etc spill onto the door gasket and become all sticky which causes some wierd noises when you open the door.
Jul 26, 2011 | Admiral 26 cu. ft. Side-By-Side...
The door on my subzero refrigerator is very difficult to open and, sometimes, almost impossible to open. I think magnets keep it closed with a rubber liner sealer. We love the refrigerator, but my wife is...
Sometimes that's caused by a slight vacuum created by the cooling process(you must have very good seals). Could you attach a handle or use a pry tool?
Jun 22, 2011 | Sub-Zero Refrigerators
Panel between doors is hot
Many models of refrigerators have a heating element around where the gasket seals to the fridge. This is to prevent ice buildup around the doors that would prevent the doors from closing all the way.
If you haven't noticed any other problems with the cooling of your unit, you're refrigerator is running exactly the way it was designed.
Mar 26, 2010 | KitchenAid Superba KSRG25FK Side by Side...
Hi my Asko fridge has a freezer compartment - I
not sure why the seal is faulty but yes you can buy a rubber seal for the door go to your local hardware store you might have to look in the section that stops drafts from entering a room or rubber flex material with a adhesive tape that can be formed into any shape eg around a outlet pipe or to seal a window etc and you can always trim some rubber sealer to fit if its a little large . I used a foam roll with adhesive tape to seal my freezer door on a mini bar fridge and its still in use today
Oct 26, 2017 | Refrigerators
Loud compressor noise from lg frig...
The sound you hear is the Freezer Fan, this problem is hard to diagnose, because the fan spins but not fast enough to circulate chilled air thru the freezer and refrigerator. The minimum labor and material cost for the repair/replacement is around $300.00. But if you chose to make the repair yourself the motor alone costs around $80.00@appliancefactoryparts.com. But the repair is very labor because the electrical connection for this fan is at the rear of the unit
Jul 30, 2009 | LG LRSC26940ST 36" Side-by-Side...
Freezer door opens
its air pressure between the wo doors that cause it to open the freezer door.take some soapy water and clean the sels aroundboth doors to see itf thet dosent help use dish soap and a little water to clean the seals with it should stop it
Jan 07, 2009 | Frigidaire FRS3R5EMB Side by Side...
Shelf locators broken of the back the freezer on kelvinator impression series 500l
hi When a refrigerator gasket (usually a rubber seal around the door) becomes hard or cracked, its seal is broken, and the unit's efficiency drops sharply. Test the door gasket for leaks by placing a dollar bill between the gasket and the door jamb and closing the door. Pull the bill out. If it offers some resistance, chances are the gasket fits properly. If the bill comes right out, or falls out, the gasket is faulty and should be replaced. Test the gasket at several locations around the door. Before you replace the gasket, check the door hinges for leakage.
Oct 17, 2008 | Refrigerators
Sub-zero Refrigerator Door
song to me door gasket was not properly installed, We using electric steamers to make rubber softer and good sticking. Right after door seal was replaced. Also, it could be that: a bottom door hinge parts broken /little white plastic cams damaged/,or, fridge not leveled or too heavy load on door shelfs.
________________________________________________
http://www.subzerolosangeles.com
Jun 27, 2008 | Sub-Zero 661/F Side by Side Refrigerator
Kenmoore refridgator side by side rubber gets hot
If you have a model with an energy saver switch turn the switch on. This reduces the heat to the mullion heater built into the door frame.
The door frame heater is used to prevent moisture from condensing on the seal surface around the door and acts as a thermal break between the outside and temperature inside the refrigerator.
May 08, 2008 | Kenmore 55612 / 55614 / 5561 / 655619 Side...
Kenmore Side by Side Refrigerator Logo
20 people viewed this question
Top Kenmore Refrigerators Experts
Sal De
Jim Goldsmith
Jim Goldsmith
ka4iup
ka4iup
Are you a Kenmore Refrigerator Expert? Answer questions, earn points and help others
