Question about Sharp AR-F152 Fax
Need instructions for fax features
There is no fax info in the AR-F152 operation manual
  • 3 Answers
Use the manual AR-F151 it seems to use the same functions as the AR-F152
I set up my fax machine using this manual, and all the instructions worked so far.
Good Luck,
Bob
Posted on Jan 16, 2009
Sharp FO-4470: Error message is: "check cover or drum"
I'm assuming you already replaced the drum, and are still getting this error? Sometimes the chip in the drum that resets the counter is bad. This is esp. true if you get a reman drum. You should replace the drum and try again to see if this fixes the problem. Go back to the place you bought the new drum from and tell them the chip didn't reset the counter and if it's still under warranty they should replace it.
Apr 23, 2010 | Sharp AR-F152 Fax
My photocopier AR-F152 IS NOT WORKING,the L2 flash on the lcd
an l2 code is your scanner is not moving. sometimes the little lock under the scanner section get pushed or turn. this is stop the scanner from moving in transport. it is right above where the paper comes out. you will have to look for it. it protudes uner the glass to stop the scenner.
Dec 28, 2009 | Sharp AR-F152 Fax
Sharp AR-275 copier with fax module. Need to edit sender ID
push custom or system setting button, push key operator programs on lcd, type in 00000 from number pad, hit fax settings, fax default settings, own name/number set. hit ok button at top when done then CA button to return to main menu.
Mar 04, 2009 | Sharp AR-275 Copier
HOW DO I GET MY FAX/COPIER TO WORK WITH MY COMPUTER
There is a separate expansion kit you need to buy.
Dec 25, 2008 | Sharp AR-F152 Fax
Changing a name
This model number appears to be a copier. Are you sure you have the right model?
http://safemanuals.com/zearch_634.php
Aug 25, 2008 | Sharp AR-F152 Fax
BLACK LINE DOWN THE MIDDLE OF ALL FAXES (LASER BROTHER MODEL 782ON)
clean theSCANNER LENS WITH GLASS CLEANER ON A MICROFIBER TOWEL(SCANNER lens is under large feed roller on auto document feeder
Jan 24, 2008 | Sharp AR-F152 Fax
Can't get Fax Confirmation page to print
What model brand name something!!!!!!
Nov 12, 2007 | Sharp AR-F152 Fax
Sharp AR-F152 Fax Logo
143 people viewed this question
Top Sharp Office Equipment & Supplies Experts
k24674
CheckitRight
CheckitRight
Are you a Sharp Office Equipment and Supply Expert? Answer questions, earn points and help others
