Question about Whirlpool 21.0 cu. ft. Top Freezer Refrigerator with IceMagic Plus Ice Maker
WHERE IS THE DRAIN IN THE FREEZER LOCATED IN A WHIRLPOOL REFRIGERATOR
  • 148 Answers
SOURCE: water dripping from freezer
a quick fix I found is to hang a peice of copper wire from the defroster bar in the freezer and let it hang into the drain tube when the defroster bar gets hot it heats the copper to prevent the freezing,but the thing you should do is check the resistance with an ohm meter across the defroster bar,if its ok its the defroster assembly located in the fridge
Posted on Jul 07, 2008
jgwhomeequip
  • 1902 Answers
SOURCE: Whirlpool GD25DF auto defrost drain problem
There is a drain hole in the back of the freezer on the bottom. Get back there with some hot water. Most of the time it is just lime build up. Unless you know what feel back there. Another way is to move the freezer out and from the back side you can see the drain line. It just pulls right off
Posted on Feb 11, 2009
  • 531 Answers
SOURCE: Water keeps gathering on top shelves of the refrigerator
for what you said what i think is the icemaker not shutoff the water valve or the the valve not working call service
Posted on Apr 01, 2009
SOURCE: whirlpool refrigerator is not getting cold but the
i have a side by side the fridge is working fine but freezer has red triangle with exclamation mark in middle but yet is still working but not showing how cold it is
Posted on Apr 14, 2011
machinetech7
  • 1344 Answers
SOURCE: Freezer won't drain
If the water is showing on the freezer side, more than likely you have a clogged drain. This occurs when the machine goes into defrost and the melted ice somehow is prevented from draining and therefor refreezing and blocking the drain for the next defrost cycle. The best way to resolve this is to unplug the machine for atleast 24-48 hours to let all ice melt. If thats not an option that you want to use the actual repair method would be to 1) unplug the machine 2) empty everything out of the freezer so you'll have room to work 3) take all the shelving and baskets out 4) locate the screws on the rear wall inside the freezer and remove them 5) take the back panel off exposing the evaporator coils ( the aluminum ) 6) directly below the coils is a trough of sorts and the drain is usually in the middle and runs out the bottom, remove the ice by carefully chipping it out or by using a hair dryer or hot water. 7) once all the ice is gone, the drain is visible and water can flow smnoothly down the drain dry the area and reassemble.
Posted on May 12, 2012
Testimonial: "Thanks - followed directions for actual repair method and it did the trick! This happened a few years ago and we paid for a sertvice call. Couldn't remember the steps the technician showed me at the time. Your info refreshed my memory and I save a $170 service call. Thanks again!!!"
My whirlpool side by side Why is my whirlpool side by side refrigerator model ED2PHEEMQ00 leaking water out the door or the freezer side.
90 percent sure drain is clogged. when unit defrosts , water from said melting ice is drained away via drain hole and tube to underneaththe fridge. locate drain hole in bottom rear of freezer and pour hot water with turkey baster into hole until it runs out freely
Aug 31, 2014 | Refrigerators
Where is whirlpool GI6FARXXF freezer drain?
It should be located behing the rear panel of the freezer compartment.
Jul 29, 2014 | Whirlpool 25.6 cu. ft. Side-by-Side...
Top freezer whirlpool refrigerator condensation water leaking/dripping
there is a drain in the freezer that sum time get Clogged the drain is located below the evaporator coil you have to remove the evaporator cover to unclog it make sure the refrigerator is unplugged before trying this you can't unclog the freezer drain without removing parts
Sep 10, 2013 | Refrigerators
Water is leaking from under the freezer compartment onto the top shelve of my whirlpool refrigerator
That water is from the melting frost of the automatic defrost cycle. Their is drain in the freezer behind the back wall under the evaperator coil that is blocked, so instead of defrost water draining it's pooling in the freezer or in some case espically on models with the freezer on the top,the water is leaking from the freezer vents into the fresh food compartment.
The way to clear the drain is remove back plate and remove all ice build up and GENTLY make a small hole in drain through then totally flush w/warm water.
The exact location of drain is under the coil behind back freezer plate in the center
Good luck,
Gene
Aug 10, 2011 | Whirlpool Refrigerators
My refrigerator has water running down from under freezer and there is no water in the drain pan.
Your drain line is clogged from the freezer to the pan. The drain line and drain pan are located behind the back freezer wall panel.
Aug 09, 2011 | Whirlpool ET1FHTXM Top Freezer...
TOP FREEZER REFRIGERATOR WITHOUT ICEMAKER LEAKS ONTO TOP SHELF AND UNDER BOTTOM DRAWER
the condensate drain hose is blocked.
remove the plastic rear cover in the freezer; locate the drain opening;
it's about 1/2 inch in diameter; it drains into a pan at the bottom of the refrigerator. using a funnel and, a small pan, pour hot water through the blocked hose until water flows into the drain pan again.
remove the condensate pan pour the water out and, reinstall the pan.
Jul 02, 2010 | Whirlpool 21.0 cu. ft. Top Freezer...
My Whirlpool 21. cu. ft top freezer drips water into the refrigerator.
Whirlpool refrigerator and freezer problem. a cup was place in the refrigerator to catch the percipitation coming from an inlet from the freezer. Which they are two inlets located in the center back of the refrigerator from the ceiling adjacent to the floor of the top freezer. the Freezer back t-shape vent goes down to these inlets where the percipitation is coming from. What is this the damper
Mar 15, 2010 | Whirlpool 21.0 cu. ft. Top Freezer...
Whirpool refrigerator ,water dips into the fridge compartment from the freezer
It is not supposed to be removed. try flushing some warm water through it.
Aug 01, 2008 | Whirlpool ET1FHTXM Top Freezer...
Water in the refrigerator portion...
the drain in the freezer is blocked with ice,unclog the drain by letting the whole thing defrost or take the back cover off inside the freezer and locate the drain hole and pour hot water over the drain and sponge up excess and repeat if it does it again after you unblock drain you need a defrost timer
Jun 13, 2008 | Whirlpool 21.0 cu. ft. Top Freezer...
Whirlpool 21.0 cu. ft. Top Freezer Refrigerator with IceMagic Plus Ice Maker Logo
123 people viewed this question
Top Whirlpool Refrigerators Experts
John Tripp
John Tripp
Dan Webster
Dan Webster
Sal DeAngelo
Are you a Whirlpool Refrigerator Expert? Answer questions, earn points and help others
