Question about EZQuest Monsoon Hard Drive
Hard drive mounts but can not be seen
EZ Quest 180gb external USB hard drive mounts but can not be seen
  • quasi1010 Jan 08, 2009
    I have the same problemas the original poster. I have a 300GB EZQuest Monsoon B30463, and the hard drive shows up on the System Profiler but not on the desktop. Any suggestions?
  • kruegernow Jan 09, 2009
    I have a EzQuest Monsoon 500GB Hard Drive that when I connect (w/
    Firewire cable) to my computer does not show up on the desktop. The
    computer does not seem to recogize that it is connected at all. The
    hard drive is suspiciously quiet. It's only sign of life is its blue
    'on' light and a very muted clicking sound. Is it dead?
  • 6,831 Answers
Hello
Okay , so there are some steps to figure out what is wrong with your external.
Firstly , if your computer makes a sound when you plug in your external , go to Start-Control Panel-Administrative Tools-Computer Management-Disk Management , and see if your external drive is listed here with your local drives. If it is listed , right click on the drive and change the drive letter to make it appear in "my computer".
If your drive does not make a connection sound when connecting to your computer and also does not show up , please follow the next step.
Remove the hard drive from the casing if possible and install it in your computer case or another external case.If the drive works , the problem is with the casing and you can ignore the drive.
Now , if the problem is with the casing , there are still 3 possibilities.
  1. The USB cable between the drive and the computer may be damaged.
  2. The circuit board which connects your drive to the interface of the external may be blown.
  3. The power supply (if applicable) may have a blown transformer.
The latter is the easiest to diagnose , does your external light up at all when you plug in the power? If not , then this is probably your problem. On the bottom of the adapter is a label which you will be able to use to have a new adapter made at your local electronics shop and this will cost about $30 max. They will also be able to test the adapter with a clamp meter to see if this is really the problem and this should be free.
The second component you want to test is the USB cable. If you have a printer , swop out the cables and see if your printer functions normally. Most externals use the same connector so you should be able to test it in this manner. If the cable works go on to the last step. If the cable is defective , replace it with a new one which you can find for about $10 at most electronics and chain stores.
The last component to test is the circuit board. This is a bit of a grey zone as you probably won't be able to spot the blown component unless it failed really badly. With the casing already opened , locate the external's circuit board and check to see if you have any blackened components or fluids leaking from some components. If all the other components of the external worked perfectly , then this is the faulty part. It is not really economical to replace the circuit as most of the time it is out of production by the time you need to replace it and it still costs a lot even if it is available so if your drive is working perfectly when connected via sata or IDE on your computer , the best is to buy a new casing and place your old drive in the new casing.
A casing costs about $50 and you could get it at most tech shops and big chain stores like Best Buy.
I hope this solves your problem and please reply if you need more help.
Kind Regards
Andrea
Posted on Sep 29, 2010
Seen as removable
If you change the Boot Device startup order with the USB port as the first boot device then you can boot up with an USB hard drive or USB Flash device.
Aug 01, 2012 | Transcend 750 GB 2.5-Inch USB 3.0 Super...
Seen as movable
If your hard drive is the first boot device then your USB hard drive will not boot up first.
Transfered 180gb of movies from mu wd 2 another hard drive now lost my movies on mine but the memory shows there still there
I presume that you deleted those files from your 'C:' drive.
> memory shows they're still there
Copy the files from the external drive back to your 'C:' drive.
Oct 31, 2010 | Western Digital WD Passport 250GB Portable...
How to scan and rapair my maxtor ounetouch 4 Mini
sorry...my guess is ur HD is gone...
once it falls down and cannot be identified as a Hardware by the OS...most probably it's corrupt....
the HDD needs to be loaded / identified by the OS / mounted.... to be able to access it....scan will not work unless it's mounted by the OS....
take it to a tech shop a c if they can fix it...
May 04, 2010 | Maxtor 160GB OneTouch III Mini USB 2.0...
Acer aspire one doesn't see liteon ez-dub
Linux operating systems may not support Liteon EZ-Dub External DVD Drive. Check on the Linux forums.
Jul 31, 2009 | Computers & Internet
HDD upgrade to extensa 6601 Wlmi.
The BIOS determine the maximum size hard drive that can be installed in the laptop. Put a smaller hard drive in the laptop say 120Gb hard drive, you will lose approx 10% in the formatting process.
Use the 180GB in another laptop or put it into an USB hard drive adapter case and use it as a portable external hard drive.
Jul 18, 2009 | Acer Computers & Internet
My Hard drive won't work!!
It's toast. You need a new one.
May 30, 2009 | EZQuest Monsoon Hard Drive
Wd my book essential edition hard drive problems
Have you tried running a virus scan on this hard drive. Viruses can pop up in many forms and mess a lot of things up.
Mar 23, 2009 | Western Digital My Book Essential 320GB...
Failure to read USB connected storage drives
What I have seen with some computer models, is that the USB port cannot deliver enough current to run some devices.
If possible, use an external drive with its own power supply and see if it will work. Most likely it will.
Also, try a powered USB hub. I found that most of the time, a powered USB hub solved many problems with having enough power for some external USB devices.
Jerry G.
Jul 26, 2008 | Apple iBook G3 Mac Notebook
Not recognized on Mac
In my experience those enclosures are infamous for not having the most durable bridge boards. The bridge board is a chip that has a chipset on it which take the SATA or PATA connection and send it to the USB and or Firewire ports on the enclosure. If the drive is powered up, you should get a small red or orange light on the front. When connected to either mac or pc ( porsches are MS_DOS formatted out the box ), if it does not mount or does not appear in DISK UTILTY, then it is a high probability that the enclosure/bridge board has failed and the drive ( if not making grinding, buzzing, clicking or beeping sounds) will have to be extracted and placed into a more stable enclosure.
Oct 20, 2007 | Apricorn EZ Bus DTS (EZ-BUS-DTS-500e) 500...
EZQuest Monsoon Hard Drive Logo
121 people viewed this question
Top EZQuest Computers & Internet Experts
Brian Sullivan
Brian Sullivan
David Payne
David Payne
Are you an EZQuest Computer and Internet Expert? Answer questions, earn points and help others
