Question about Jura Capresso C3000 Espresso & Coffee Maker
Jura capresso c3000 yellow clip
Hi All, I opened my Jura capresso to fix it and there is a yellow clip with hole on one side that I can't figure out where it goes. I thought it was on the brew body lower water supply assembly but I can't figure out how it goes on. If somebody has a picture of it. I think there is only one yellow part in the whole machine. Many thanks in advance. AJ
  • 1 more comment
  • Rich Signell Feb 02, 2013
    Is this the yellow clip you are asking about? I can't figure out where it goes either. I can't see it on the brew group removal instructions at: . If you figure it out, please let us know!
    bit.ly/jura_yellow_clip
  • ajaj Feb 04, 2013
    yes - that is the part.
    New Friend:
I found out where it goes, thanks to Juergen, who pointed me toward his excellent page on Jura cleaning: see figure 7d, copied here
which shows the yellow clip helping to hold on the tea pipe. I'm guessing that if you don't use the tea pipe, you will be okay. Otherwise you can just put that clip back on next time you clean the machine.
Posted on Feb 04, 2013
Testimonial: "Thank you so much for looking into it. "
SOURCE: Jura Capresso Problem
check out this link:
http://www.kuntze.de/E/index.htm
Posted on Dec 30, 2007
atgep
SOURCE: jura capresso
If you gind too fine, it will overload the pump and result in the "open tap" a few seconds into brew. Rinse and gind coarser to clear out malfunction.
Posted on Jan 20, 2008
  • 14 Answers
SOURCE: Jura Capressa E9 Leaking
Your spout is probly cracked (a common problem). It won't hurt the machine if you want to live with making one cup at a time to catch it all.
If you want to get it repaired go to www.hotncold.com Click on Jura Repair for shipping instructions. We can turn the job around in 24 hours. The repair will also include a free software update.
Posted on Aug 03, 2008
  • 4 Answers
SOURCE: Jura Capresso Impressa S9 water won't pull into the unit
mnbkjnjk
Posted on Jun 16, 2009
  • 13 Answers
SOURCE: How do I disassemble and clean the brew unit motor
I have some good instructions I downloaded from www.kaffeestudio.com . They are in German, but with many pics. If you are technically adept, then it is really no prblem. You should put in new o'rings and lubricate with the food grade silicon grease before reassembly, otherwise it won't be long before you are doing it again. Give yourself about 3 hours to perform this task the first time. One thing to remember. The cleaning tablets tend to strip the lubrication from the brew units, subsequently binding up the brew unit, sometimes tearing the o'rings and giving the malfunction 8. Plan on this being an ongoing maintenance exercise. Plan on at least once every year or two to have to do this.
Posted on Oct 18, 2009
Is there an easier was to decalcify the capresso 3000 than taking apart the whole machine. The directions say you have to remove the auto cappuccino assembly
Yes
You should run the decalcify program with the JURA decal tablets or DURGOL. Do not use other agents.
See page 25 of user manual.
Please dont forget to vote this answer was helpful
Many thanks
Feb 14, 2011 | Jura Capresso C3000 Espresso & Coffee...
Capresso C1300 LCD stays on stating "Hot water cycle necessary"
I had one that set for 6 months that had that problem. Air had gotten into the water lines. Opened the hot water tap a few times and then removed the end of the water line that runs from the solenoid to heater block to at the solenoid end to bleed air out. It could also have been some calcium deposits that blew out with the air blocking the line. Then I replaced the end of the line, powered the machine up and it worked normally. Note: Jura Capresso and Capresso machines are complicated and it takes some mechanical know how to open them up and service them. They also have four special screws on the back that requires a special tool to open
Feb 26, 2009 | Jura Capresso C3000 Espresso & Coffee...
I have a capresso c3000 and one day it just wont turn on anymore. any suggestions?
We had the same problem. We unplugged the unit from the wall and then plugged it back in again. For us, it was as simple as that.
Jan 08, 2009 | Jura Capresso C3000 Espresso & Coffee...
Jura Capresso C3000 Espresso & Coffee Maker Logo
333 people viewed this question
Top Jura Capresso Coffee Makers & Espresso Machines Experts
Colin Stickland
Colin Stickland
Ken Macumber
Ken Macumber
Level 1 Expert
Are you a Jura Capresso Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
