When I try to put in a ram card in it won't go in
  • 2,878 Answers
Wrong RAM if it does not fit. Don't force it!
Posted on Nov 08, 2012
Packardbell imedia
Hi paul,
1. check signal cable from pc into monitor and try to use other signal cable also do try into other monitor if prob cant solve.
2. your imedia include with graphic card? If has a graphic card try use other good graphic card to test the display run or not. If cannot.
3. Try make some cleaning into your ram, Test your ram one by one because sometime no display appear because of broken ram.
Try check this 2 site to other solutions..
Thanks..
1. How To Test Computer Monitor That Won Display Or Is Not Working
2. Fix Your Computer Monitor When the light is yellow or amber not green (try this one)
Good Luck.
Jan 19, 2014 | AMD Computers & Internet
I put a 2gb ddr2-667 memory chip in the single (only) memory slot in my gateway nx100x notebook pc. The pc will not boot up with the 2gb memory card. Is there a compatibility problem or do I have a ba
yes, there may be compatibility problem. your 2GB ram may be dead. try your 2gb ram on other notebooks. if it is working on other notebooks, then your ram is ok. your notebook will support maximum 2GB ddr2 memory per slot. your notebook may not be booting due to unsupported frequency of your ram. maximum supported frequency for your notebook may me 400Mhz, and you are putting a 667MHz ram into it. try to put a 400MHz 2GB ddr2 ram in your notebook.
Apr 10, 2013 | Gateway Computers & Internet
Computer wont boot all the way up
There are several reason why a computer won't boot up. First you need to figure out if your Power Supply is working, if your not a computer expert, you can try another PSU to test. Or you can use a PSU tester to test if your PSU is still working. If not, clean and reseat your RAM, if you have 2 RAMs, remove each RAM then try 1 RAM at a time, and try to seat the RAM to different slot. If not luck, clean and reseat your graphics card. If you have a built-in video port, remove your graphics card. Still won't boot? try resetting the CMOS. This might fix the problem.
Sep 07, 2012 | Acer Aspire X3200 PC Desktop
I have a server ML370 that won't display i have tried another VGA card but still no disply what could be the problem. HELP
Ifthe replacement video card is new or a functioning one then the monitor could be faulty. Try a different monitor.
Aug 17, 2011 | Compaq ProLiant ML370 G4 (374490421)...
My fujitsu scaleo p tower won't display anything on the monitor! The monitor works fine with other devices.... everything spins and all LEDs light up just no output to the monitor :/ any...
Have you tried putting the Graphics card in a Different slot? If you have and it is still not working most-likely it means that your video card has gone bad and needs replacing.
Jul 11, 2011 | Fujitsu Siemens SCALEO 600 (FSP:83C005617)...
I have a desktop computer with xp installed in it. It is not showing display and giving two beeps during booting Plz help me out
Hi!
This is the problem of RAM. Just insert ur RAM in the slot correctly. It will resolve the problem.
Thanks
Apr 22, 2010 | Microsoft Windows XP Professional SP2 for...
Problem about ram
if the manual says that the board can support max of 1gb ram then each slot should support max of 512mb each. hope this helps
Aug 24, 2009 | AOpen MX36LE-UN (91.89Q10.101) Motherboard
The screen goes black after the window loads
it may be your graphics card problem,connect the monitor cable to vga port in motherboard and check. If the problem is not clear check your board(bios may be corrupt) and ram.
Aug 11, 2009 | Palit Microsystems GeForce FX5500, (256...
Gateway E-3200 no video signal
hi! there,
there are common factors why no video on your screen.,right one factor is ram,the other are video card,processor and monitor
you can't trouble shoot with out other computer available,tester cann't detected all this,it make easy to parts to parts.disconnect cd room,hardisk and floopy also disconnect your video card and memory card put video card and ram one by one (if youhave nultiple ran) to other computer ,be sure other computer is run good and observed, if no video take the previous video card and put back if there video,possible your video card is busted,or try to put other video card and ram to your pc be sure this are good,if ok select your own part that you think is busted since you said your ram is good,put back to your pc observed.....replace aby busted parts,
take all precaution avoid electric shock wear safety shoes.regards and have a nice day
Apr 03, 2009 | Gateway Computers & Internet
Computers & Internet Logo
13 people viewed this question
David Payne
David Payne
