Question about Whirlpool Ultimate Care II LSQ9549L Top Load Washer
Motor makes loud rattling noise during rinse cycle
My washing machine is making this loud rattling sound when it comes to the rinsing cycle... the water does drain slowly but the noise scares me so I turned it off...
I've been reading that others have similar problems, could it be the motor coupler? I tipped the machine back to see if anything has fallen off but found nothing underneath (btw, my machine is 8 year old... but it works great!!!)
Thanks for your help!
  • ttvu Jan 05, 2009
    Hi, sorry, when I say "it works fine" I meant the overall of the machine. As of now, the machine is stopped at the rinse cycle, no spinning at all, just the loud sound...
  • 530 Answers
Could be the coupler and the only way to truely check it is to take the pump, then the motor off. But it seems strange to me that you say it works fine. Is it spinning? usually when the coupler breaks it sounds horrible and usually will not spin but it will drain.I would check the coupler again.
Posted on Jan 05, 2009
  • erica graber Jan 05, 2009
    So yes definatly sounds like a bad drive coupler. Check it out let me know how it goes
I have a top load fridgidaire washer model fwsc445rfs0. During the wash cycle it makes a high pitched scraping noise.... Struggles also while it winds down before rinse. Bearing maybe?
How To Fix A Washing Machine Making Noise During The ...
removeandreplace.com/.../washing-machine-making-noise-during-the-sp...
Jul 27, 2015 - Agitator directional cogs aka "agitator dogs" (top load washers) ... If you hear a rubbing sound or the drum spins uneven, then the ... A washer making a loud noise during spin cycle can also be caused ... The clutch in a washing machine connects the inner wash tub to the ..... May 8, 2015; High Water Bill?
Dishwasher Making Loud Grinding Noise During Wash Cycle
removeandreplace.com/.../dishwasher-making-loud-grinding-noise-durin...
Apr 11, 2014 - Dishwasher Making Loud Grinding Noise During Wash Cycle ... GE, Whirlpool, Frigidaire, KitchenAid, Maytag, Kenmore, and LG) this is a .... Our Amana dishwasher is making a loud, high-pitched squealing noise throughout the wash ....Out Of A Washing Machine - Top Load & Front Load September 30, ...
All comments on Loud dishwasher Frigidaire Gallery mode ...
https://www.youtube.com/all_comments?v=v-arYb20kOk
Dec 03, 2015 | Washing Machines
Fisher & Paykel Aquasmart washing machine makes loud banging noise then stops during rinse/spin cycles
Your Aquasmart machine requires 4 new suspension damper rods & 4 top bands, these are a common problem for AquaSmart machines.
Feb 02, 2013 | Fisher and Paykel Washing Machines
Washing machine knocks and dims lights only during rinse cycle
Possible that the bearings are a suspect, if the machine seems to wobble around. Also if the load is high, does the noise go higher, if so check the suspension, check the mounting and the counter weights.
Please check this link: Wobbling machine
Jan 24, 2013 | Washing Machines
Loud banging noise during rinse
Most noises from a washing machine occur during the rinse or spin cycle. If you hear loud thumping during the spin, the load of clothes may have become unbalanced. Stop the washer and redistribute the clothes, then re-start it. Repeat these steps if necessary.This will solve your problem.
Apr 08, 2010 | Whirlpool GHW9100L Front Load Washer
Loud squealing noise during wash and rinse cycle
The dishwasher make "loud high-pitched squealing sound" during the rinse cycle that is periodic through out the cycle
Nov 24, 2009 | Frigidaire Dishwashers
Our dishwasher is making a loud noise during wash cycle.
if you have a torx 20, and torx 15 screw driver, you an remove the screws from the top plate of the wash motor, and underthere youll see another t15 screw converingthe "chopper" assy, sounds as if a seed, of chicken bone, perhaps apiece of glass hasgottne down there
Jan 25, 2009 | Whirlpool GU3600XTSY Stainless Steel...
Will not agitate or spin,makes loud noise during those cycles
Sounds like coupling gears between transmission and motor... they did away with the belt and went direct drive with coupling gears. It can pump water out but nothing else. water pump is mounted to front of motor is why it will pump water out.
Jun 19, 2006 | Whirlpool LSN2000LW Washer
Loud clicking/thumping in rinse and spin cycle
It doesn't look like a motor problem !!! It seems like an unbalanced tub issue. The machin has suspension dampers and suspension rods, and it's look like one of them was damaged or "run away" from its location during machin's movement. Goog luck !!
Jun 14, 2006 | GE Profile Prodigy WPSE4200A
Whirlpool Ultimate Care II LSQ9549L Top Load Washer Logo
307 people viewed this question
Dan Webster
Dan Webster
Sal DeAngelo
