Question about HP Pavilion Media Center m8425f 2.66GHz Core 2 Quad Q6700 3GB 1TB DVDRW DL LS GeForce 8500GT Vista H... PC Desktop
Hp pavilion has the green light in the back on but doesnt turn on
The light isnt flashing its just solid on when i unplug the cord it takes it a minute to go out and when i plug it back in comes right back on but the computer will not start
  • HP Master
  • 5,660 Answers
I would bypass the Power On switch with a jumper wire on the 24-pin ATX main power cable's connector, and see if the problem is a $5 Power On switch, or the Power Supply.
Ready?
This diagnostic test does Not involve the Power On switch, or it's wires. There is no cutting of the insulation of ANY wires.
You need a paperclip.
Follow Anti-Static Precautions.
Anti-Static Precautions;
Your body carries Static electricity. Static WILL fry out (Short Circuit), the delicate hardware components inside a computer.
Relieve your body of Static BEFORE reaching inside your computer.
Computer on a table, computer unplugged from power, computer case open;
TOUCH an unpainted surface, of the metal frame of the open computer case.
This action will relieve your body of Static.
IF, you leave your computer in the middle of working on it, be SURE to Touch the metal frame again upon your return.
Top View of the motherboard, no power cables attached, no hardware attached,
http://h10025.www1.hp.com/ewfrf/wc/document?docname=c01324212&tmp_task=prodinfoCategory&cc=us&dlc=en&lang=en&lc=en&product=3692730
The 24-pin ATX main power cable connector for the motherboard, is on the right side of the Ram Memory slots, and next to the outside edge of the motherboard.
Whitish in color, two columns of 12 socket holes.
This is a general example of a 24-pin ATX main power cable, and it's respective connector on the motherboard,
http://www.playtool.com/pages/psuconnectors/connectors.html#atxmain24
Viewing the photo all the way to the right, note that the 24-pin ATX main power cable is plugged into the motherboard. This is the way you want it when testing.
(NOTE* Color of connectors does NOT matter)
Note the Green wire.
The Green wire is the Soft Power On wire. Abbreviated as PS_ON.
Note the Black wires. -> ALL Black wires are Ground wires.
A paperclip is used to Temporarily, touch the Green wire to ANY Black wire.
(The Power On switch is a Momentary Contact Switch)
The paperclip is bent into a U-shape. The top of the U is wrapped a few times with black plastic electrical tape.
This taped area is for your fingers, and thumb to hold onto.
Turn the U-shape over, and it is the 'legs' that you are going to use.
One 'leg' of the U-shaped jumper wire, is inserted down into the socket hole with the Green wire.
The Back of the 24-pin ATX main power cable's connector, is where the wires go in.
This is the side the jumper wire leg goes in.
Goes RIGHT NEXT TO the insulation of the Green wire, slides down into the socket hole, and touches a metal terminal at the end of the wire.
The leg of the U-shaped jumper wire, has to go down in the socket hole pretty far. (3/8ths of an Inch?)
It MUST touch that metal terminal at the end of the wire.
[ This is an example of the female metal terminal I am referring to,
http://www.molex.com/molex/products/datasheet.jsp?part=active/0002081202_CRIMP_TERMINALS.xml&channel=Products&Lang=en-US
The left side has tangs (2), that are crimped around the insulation of the wire. The Right side is the front, and you can see the front tip of them in the center photo of the Playtool link ]
The other 'leg' of the U-shaped jumper wire, goes down into ANY socket hole, that has a Black wire in it.
Bend the paperclip, attach tape, then try it in the two socket holes.
(Green wire / Black wire)
Once you have it bent to fit, and have tried using it, remove, and plug the Power Supply into power.
Now use the U-shaped jumper wire.
The contact time is no more than 2 seconds.
Concerned about getting shocked?
The Soft Power On circuit uses 5 Volts DC.
In comparison two D cell flashlight batteries produce 3 Volts DC.
NOT saying there may be a small spark!
You may wish to use a glove on the 'jumper wire hand'.
Power Supply comes on? You have a bad Power On switch,
http://www.directron.com/atxswitch.html
Power Supply does NOT come on? You have a bad Power Supply.
For additional questions please post in a Comment.
Regards,
joecoolvette
Posted on Nov 08, 2012
  • HP Master
  • 27,725 Answers
Test your PSU power supply unit or replace it if your power supply units fan is not working your PSU is faulty
http://pcsupport.about.com/od/toolsofthetrade/f/powersupplytest.htm
One bad lead can cause a computer to continue on a cycle of restarting or to shutdown or fail to detect/ boot up a computer hard drive
Test all leads that attach to your hard drive power and data cables IDE SATA
the leads from your MOTHERBOARD TO YOUR HARD DRIVE make sure they have a secure dust free connections and are not faulty or just replace them they could be faulty
make sure all leads that are attached to your dvd\cd floppy drives have secure connections and are not faulty or just replace them they could be faulty
computers need power and data to travel through every working device to continue its cycle and have an end so any faulty leads will end up with a computer error
even something as small as a faulty electrical or fan lead can cause you problems
motherboard and a hard drive any leads between them will fail before your motherboard or your hard drive if its a flat ribbon 40 pin type IDE replace it this will be the first to fail
check all electrical power input and extensions make sure they are securely seated even the cd/dvd floppy drives need to have current go through make sure these drives are working
also check the Cmos battery and computer RAM modules make sure they are securely seated with no dust built up or in the sockets on some motherboards cmos batteries are soldered in
check you CPU central processing unit make sure its securely seated and has thermal paste it might be getting to hot the thermal paste will help disperse the heat
Thermal compound is a sticky paste that is placed directly onto the CPU.
Allowing for a more direct heat transfer between the CPU and HEAT SINK and preventing air gaps from forming between the CPU and heat sink.
hope this helps
http://www.hardwaresecrets.com/article/Thermal-Compound-Roundup-February-2012/1490
another possible reason could be a memory dump you might be running to many programs at the one time putting to much strain on the CPU central processing unit
scroll to bottom toolbar bottom of screen right click select task manager
applications you will see whats running if you see anything you dont need running select end now
also under processes see what is ticking over again if you see something you don't need to be running end now or you might uninstall that program and some unnecessary programs
not having enough computer ram can cause memory dumps
If you are not sure if a module is right for your system use the Crucial Memory Advisor tool for a list of guaranteed compatible modules.
first you will need to select the manufacturer from a drop down list then select your product line from a drop down list then select the model then click find it will take you directly to compatible ram also you will have an option to scan your system
you should always for a guarantee on any ram modules when purchasing them or buy working pairs if possible
hope this helps
Ownij
  • 67 Answers
SOURCE: pc won't power ( turn on)
The green light is most likely your lan card/port. If the cord/outlet are sparking when you plug it in, I would say try plugging something else into that socket, if you get the same spark, I'd call an electrician. Also try plugging the pc into a different outlet. As far as the computer, if its not the outlet then it is the power supply, your motherboard may be fried in the process but if this isn't an issue with that outlet, then you should take it in to a shop.
Posted on Mar 16, 2009
thegoshem
  • 61 Answers
SOURCE: Green light flashing on back of unit near power cord also green light flashing on motherboard near power supply plug in.
I would suggest trying to replace the power supply. If that does not fix the issue, i would need to hear more about the computer.
Posted on May 06, 2009
lglalight
SOURCE: computer wont turn on
i had the same problem its going to be your power supply it probably burned out. when i changed mine it worked perfectly.
Posted on Jun 01, 2009
  • 169 Answers
SOURCE: Power Issue on my HP m7470n
try this link.....it has the steps you need to follow
http://h10025.www1.hp.com/ewfrf/wc/document?docname=c01732674&cc=us&lc=en&dlc=en
Posted on Jun 24, 2009
  • 122 Answers
SOURCE: My HP Pavilion computer unit will not turn on.
If you have no activity at all, no lights, no noise at all etc. it is probably the power supply. It can be replaced with some mechanical skill and attention to where the wires plug in, but the major problem is the age. Older computers have a different power supply then currently available. If you have data you need to retrieve the physical hard drive can be removed and placed in a relatively inexpensive USB housing and accessed from a new computer. If you want to try and get it repaired find an older, small repair shop and with luck they may have or be able to locate the correct replacement. Since it is 10 or more years I would not put much money into repairing it so check in advance about minimum rates etc. so you don’t end with a money pit. Good Luck
Posted on Jul 20, 2009
Have a HP m7470n. The green power light in the back is constantly on. The power button flashes blue and orange (~3 seconds each). The computer wont turn on. When I unplug the cord and plug it back in, the...
In my case it turned out to be a weak power supply. It would work sometimes and not others. If stone cold, it would not boot. If I unplugged 1 thing, like the hard drive or the CD Roms, it would boot. Tested the old power suppy and it seemed to pass. But once I connected a new power supply, the computer has worked fine ever since.
Jan 08, 2011 | HP Pavilion m7470n (ER883AA) PC Desktop
I was removing the video card to tighten a nut. I unplugged the power cord and pushed in the power button to drain excess power, notice the solid green light went to flashing. I then removed video card to...
Open it up again. Take the video card out. Take the Ram out. Unplug the hard drive. Unplug the other drives. Unplug the network card(s). And unplug anything else that is tied to the motherboard. Now plug it all back in snugly.Finally,turn it on. It should be fixed.
Nov 23, 2010 | HP Pavilion a1330n (EL466AA) PC Desktop
When I plug in the power cord to the back of the computer the green LED light flashes but does not turn solid and the computer will not turn on, how can i get it to work?
I am providing you with the link.There you will find the tutorial of 7 pages and just by following the steps you can fix your problem.
http://www.hardwaresecrets.com/article/What-to-Do-If-Your-Computer-Doesnt-Turn-On/547/1
Please rate me if this solution works for you
Thanks......Have a great time.
Jul 16, 2010 | HP Pavilion a1430n PC Desktop
HP Pavilion a735w will not power up Green light flashing.
check the light at the rear panel of the tower ... if it is solid green then reseat the cables coming out of the smps and going to the motherboard and other device drives(Hard Drive and CD/DVD drive).... if there is no light smps might have gone bad
Jan 27, 2010 | HP Pavilion a735w (PL308AAR) PC Desktop
HP 2550 will not print. Green light flashes. I'm
If the machine is making "working noises" while it flashes, it is most likely calibrating. A good way to find out if the problem is due to connectivity issues with your computer is to turn the machine off, unplug for 1 minute, plug back in and turn on. Wait until the light is solid, indicating its ready to go, and then press and hold the green button until the lights flash. It should produce a demo print for you. If it doesnt, the problem may be with the printer, not the computer. Also, check in the "Printers and Faxes" settings in the control panel (if you are running windows) to see that the 2550 is set as the default printer.
Feb 20, 2009 | HP LaserJet 2550n Printer
Wireless printer stopped printing-wireless router light flashing
Restart your Printer so that it can Look for the Connection again, if you havent done this already.
If this doesnt assist in the problem, please give me the complete Model Number for your printer so i can find the solution
Jan 14, 2009 | NetGear WGT624 Wireless Router
Flashing Green Light on Power BESTEC Power Supply
This is an easy fix so here you go nice and simple:
Problem: Your motherboard circuit has been cut.
Causes: Power disconnected during operation. Power outage or short in the surge protector.
Symptoms: Flashing green light on both motherboard and power supply. System will not power on.
Solution:
Step 1: Ensure that both the power supply and the motherboard lights are flashing green, not solid or off.
Step 2: While the power is on, disconnect the power supply from the motherboard. This connection is the largest of the connections and should be listed as the 'P1' or 'Primary' power connection.
Step 3: Wait until the green light on the motherboard stops flashing and check to ensure that the green light on the power supply is now solid. If it is not solid, disconnect the power to the power supply and wait until the light turns off completely. Then reconnect, it should be solid now.
Step 4: While the power is on, reconnect the P1 connection to the motherboard and you should now see that the light on the motherboard is solid.
Step 5: Power on your PC. The problem should not persist.
Warnings: If the power supply light remains flashing after you have restored power to it while it is disconnected from the motherboard, it may be a system failure in the power supply itself requiring replacement. Always be careful when working with an active or live power machine.
I hope this helped! Good luck!
Jun 23, 2008 | Bestec (ATX-250-12E) 250-Watt Power Supply
Hp Pavillion a420n blinking light
Hello!
Is the pc has blinking power in it. or do your hear any beeping sounds? but anyway you can do check your PC. unplug the pc and open the system. remove and clean the memory and insert it again. and fix all connection inside the pc maybe some cable lessen. after that test the pc. and then tell me what happen i will give you more solution in it. melnavz
Mar 25, 2008 | HP Pavilion a420n PC Desktop
HP Pavilion Media Center m8425f 2.66GHz Core 2 Quad Q6700 3GB 1TB DVDRW DL LS GeForce 8500GT Vista H...  PC Desktop Logo
Top HP Computers & Internet Experts
Tony
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
