Question about Uniden DECT 6.0 Cordless Phone ID
I need to turn the ringer back on
How do i turn the ringer on
    One Above All:
    The expert with highest point at the last day of the past 12 weeks.
    Top Expert:
  • Uniden Master
  • 102,366 Answers
Since you neglected to specify the model of your Uniden DECT 6.0 phone I can't be certain, but on many models you press the up-arrow button on the handset while the phone is in standby mode to raise the ringer volume.
Select the model of your phone from the list beginning here to download a copy of the manual for the exact instructions.
Posted on Nov 08, 2012
How do I turn the ringer back on my panasonic cordless phone #kx-tga402
Go in to the settings on the handset, look for ringing or ringer and turn the tone from off to on.
Dec 13, 2014 | Panasonic Lands Phones
Ringer turned off. how do you turn it back on
Press either line 1 or line 2 on the face of the phone then slide the volume button up or down, for example, press line 1 and slide volume up to turn on ringer, and press line 2 and slide down to turn ringer off
Mar 06, 2012 | AT&T 972 Two-Line Memory phone
Can't access missed calls, lost my instruction book, need one. Also I get missed calls when I'm sitting right beside the phone. It never rang.Could I talk to someone?
If this is a Panasonic phone connected to a phone system as in an office setting, sounds like the ringer has been turned off. Get someone to call your phone and while they are calling turn the jog dial to turn the ringer back on or use the LCD intertactive keys to turn the ringer back on.
Dec 08, 2010 | Panasonic Lands Phones
The ringer is off and I don't know hoe to turn it on
I have two uniden phones 2.4 GHz and the ringer is turned off and we cannot figure out how to turn it back on again. Please help!!!
May 18, 2009 | Uniden TRU4485-2 Cordless Phone
Model GE 27951 - Unable to Turn Ringer back on
The headset volume is turned to zero. Hit the "menu" key on the headset and it should take you to "ringer setting", hit select for the ringer volume and turn the volume up. Not very intuitive but that should get you going!
Jan 28, 2009 | General Electric 27951EE1 - - Phone
Need ringer turned back on .. radio shack 5.8GHz
Hit the up or down arrow keys several times. (either key will work) and the ringer will rotate through Ringer off - Ringer low - Ringer high... one set will be a steady ring, the other set will be a warble ring. This works on the phone made for RadioShack with 5.8 GHz on the front and Cat. No. 43-155 under the battery in the battery compartment.
Dec 09, 2008 | Radio Shack 433575 Cordless Phone
Panasonic cordless phone,
press menu,scroll down to ringer settings,hit select,scroll to ringer volume and hit select then press up the round button in the middle until you hear it make a "ring" sound. adjust your preferred volume and hit save.
Oct 16, 2008 | Panasonic KX-TG5632 Phone
Ringer off
The VT-9118 can use one of 4 different ring tones, and can be turned off.
To reset your ring tone:
  1. Remove the handset from the base.
  2. Press PROG. You should hear a single short beep.
  3. Press #.  You should hear a single short beep.
  4. Press a number 1 through 4. You should hear a long "ring" tone (it might be startling!). You can try other numbers from 1 to 4 to hear them all.
  5. Press MEM to confirm your ring. You will hear a medium beep.
To turn the ringer off, follow the same instructions, but choose number 5.
Hope this helps you. If you need for information, you can download the user manual from http://www.vtechphones.com/docMgt/public/art/313/vt9118.pdf
Jan 17, 2008 | Vtech VT-9118 Cordless Phone
Ringer off, need to re-install ringer. volume control does not put ringer back on
To turn your ringer back on, you do the following. For your handset, you push Menu, scroll to ringer settings, then push select, Press select again for ringer volume, then scroll up to turn on and increase the ringer volume. Then press Save once its at the desired volume. To change your base ringer, while it is not in use, push the ringer up button until you hear the desired setting. That should fix your problems.
Dec 31, 2007 | Panasonic KX-TG2357 Cordless Phone
Phone ringer
You can download the manual for a very similar phone, the KX-TG2302 at http://service.us.panasonic.com/OperMan/findmanual.aspx?cat=TEL and you can figure out all the features of a KX-TG2303. The simple answer is: while you are not using the phone, press the up or down volume button and it should turn the ringer back on. To turn the ringer back off, press and hold the down volume button until you hear two beeps. You can adjust the volume while the phone is ringing. The manual will tell you how to change your ringer tones, etc.
May 10, 2007 | Panasonic KX-TG2303B/WH Digital Cordless...
Uniden DECT 6.0 Cordless Phone ID Logo
173 people viewed this question
Top Uniden Lands Phones Experts
k24674
Are you an Uniden Lands Phone Expert? Answer questions, earn points and help others
