Question about Dryers
How to replace door switch
Model 110.82822102
  • Alissa Nov 08, 2012
    I've unclipped the harness, and have unclipped the button/gray rubber cover. Do I need to remove the front control panel to access, or can I thread the new button/wire from front to back?
    Problem Solver:
  • 18 Answers
On the old kenmore models you have too remove the top control panel to be able to get to the door switch.it should only be about four screws in the rear of the top control panel.
Posted on Nov 09, 2012
Michael Pryor I got a dryer model number.WED7500VW, is not turning on door switch onewire Was burn....
The door switch activates when the dryer door is closed. On most dryers, the door switch makes an audible clicking sound when it activates. To determine if the door switch is working, try starting your dryer and then listen for the "click." If the door switch makes a clicking sound, it is probably not defective. If you don't hear a click, use a multimeter to use the door switch for continuity. If the switch does not have continuity, replace it.
Aug 30, 2016 | Dryers
Rotor wont spin
make this tests and fix it. God bless you
Thermal Fuse
If the dishwasher won't start the thermal fuse might have blown. The thermal fuse helps to prevent damage to the dishwasher by turning off power so that it doesn't overheat. Once blown, the thermal fuse will have to be replaced for the dishwasher to work. The thermal fuse is usually located in the control panel on the control board or mounted to the bottom of the tank behind the lower panel. The thermal fuse can be checked for continuity.
Enter your model number to see parts for your dishwasher.
Help me find my model number
Door Switch
The door switch, or switches, are sometimes called interlock switches. The door switch prevents the dishwasher from running while the door is open. If the dishwasher won't start, the switch or switches might be defective. To access the door switches, remove the control panel or inside door panel - depending on the model. They can be tested for continuity.
Door Latch
If the dishwasher does not start, the door latch assembly might be defective. These are normally made of plastic and cannot be repaired. If the door won't latch and the door latch is broken, replace it.
Main Control Board
The main control board provides power to nearly every component of the dishwasher. If the dishwasher won't start the main control board might be defective. You should first check for more common parts. Many times control boards are replaced unnecessarily because the problem was not diagnosed properly.
Touchpad and Control Panel
If the touchpad is defective, the control board might not get the signal for the selections made. If the dishwasher won't start and the display doesn't seem to change properly when the buttons are pressed, the touchpad might need to be replaced. On some models the touchpad and control panel are sold together and will need to be replaced at the same time.
Touchpad
Timer
The timer allows power to flow to the proper parts at the proper times. If the dishwasher won't start, the timer might be defective. Keep in mind that timers are often misdiagnosed as the cause of a problem. Check other components first before replacing the timer.
Jul 24, 2013 | Fisher and Paykel Dishwashers
Ariston Dish Washer LSE620A
test this steps and fix it. God bless you
Thermal Fuse
Door Switch
Door Latch
Main Control Board
Touchpad
Timer
Jul 22, 2013 | Dishwashers
No power
test this steps and fix it.God bless you
Thermal Fuse
Door Switch
Door Latch
Main Control Board
Touchpad
Timer
Jul 22, 2013 | Westinghouse Dishwashers
The message "right rear door ajar" comes on and
This is very common, the door ajar switch is no good . the switch is located inside the door and is part of the latch, but it can be replaced spreate, you will not have to replace the latch, on some models you would need to replace the latch inorder to replace switch, on this model i think you can buy the switch form dealer, you will need to remove the door panel and the latch to replace the switch, heres a diagram to help you locate the switch, hope this helps.
Oct 27, 2010 | 2005 Ford Taurus
Dryer just stopped
The dryer will not start with a broken door switch. Replace the door switch if found defective.
Most dryers have a door switch actuator lever - when you close a dryer door, it presses against the lever, which actuates the door switch. If the lever is broken, the switch would not activate and the dryer would not start. Replace the lever, if broken.
Note: Door switch actuator lever usually comes with the door switch assembly and it is recommended to get the whole assembly since there is almost no price difference between the door switch assembly and just the lever. Check your model for more details.
I would also, check the Thermal Fuse as well.
Jun 25, 2009 | Kenmore 62602 Electric Dryer
Maytag Performa Electric Dryer will not turn on
Check the following to address this issue.
1. No power to the dryer
Make sure there's power getting to the dryer. Check for a tripped circuit breaker or a blown fuse. Check the wall socket for power with a voltmeter or by plugging something else in.
2. Door switch / Door switch actuator lever
The dryer would not start with a broken door switch. Replace the door switch if found defective.
3. Thermal fuse
Most dryers have a thermal fuse, which burns out when the dryer overheats, in which case the dryer will either not run at all or stop heating. The fuse is usually located on the vent duct, inside the dryer. A blown fuse will show no continuity when measured with a meter. Before replacing the fuse, make sure the blower wheel is not broken or clogged, and there is nothing blocking the venting.
Note: It is recommended by most dryer manufacturers to replace a hi-limit thermostat when replacing a thermal fuse.
4. Timer/control
Replace if defective (note: uncommon problem).
Jun 07, 2009 | Maytag Dryers
Dryer knob sticks in one spot- won't move
 Door switch / Door switch actuator leverThe dryer would not start with a broken door switch. Replace the door switch if found defective.
Oct 25, 2008 | Maytag Clothes Dryer Almond Timer Knob...
Microwave Door Switch Problem?
That model number has too many digits after the JVM. Could it be JVM1339BW02 or JVM1339BW002?
If one is bad, it's probably the bottom switch, whose wiring goes back to the power relay, thermostat, or fuse, depending on eact model.
The switch with thin wires going to a ltitle connector on the board is the door sense switch. That's not likely your culprit.
I usually recommend you replace them all while you're at it.
It sounds like it may actually be a loose or misaligned door or door switch mount.
If you or a friend decide to look into it, we have critical safety information, info on door switch diagnosis and replacement, and
disassembly information at our site, and our link is at our listing here on FixYa: http://tinyurl.com/yzjozk
You can usually find helpful exploded view diagrams and order parts by entering your full model number here: http://tinyurl.com/gv383
GE models have a very helpful "mini-manual" hidden inside the unit behind the control panel. Handy in troubleshooting.
We're happy to help and we appreciate your thoughtful rating of our answer.
Dec 02, 2007 | GE Spacemaker JVM1640SJ Microwave Oven
Dryers Logo
50 people viewed this question
Top Dryers Experts
Dan Webster
Dan Webster
