Question about Maytag MER5775Q Electric Kitchen Range
After cancelling auto clean I received an error code F14
    Top Expert:
  • Maytag Master
  • 9,472 Answers
"F1-4" error code means "Runaway temperature, lower oven".
The first thing I would do is check the lower oven temperature sensor. Pull the range out, remove the rear cover and locate the sensor wire harness to the control board. Measure the sensor resistance at the control board. Normally it suppose to be about 1100 Ohms at the room temperature. Also check the sensor wire harness and the sensor plug.
If the resistance reads wrong then replace the oven sensor.
If there is nothing wrong then the control board has to be replaced.Here is the sensor to order if it is bad.Here is the control board.
The part comes with a 365 day, any part, any reason return policy.
Posted on Nov 10, 2012
  • Richard Roth
    Richard Roth Nov 10, 2012
    F14 = EEPROM error
    The Central Control Unit (CCU) receives it's data from an EEPROM on board the CCU. If there is an error reading this data it will cause this error.
    Replace the CCU.Here is the part to order.
How to address F14 code? Convection oven does not start.
Hey friend, thanks for your post!
I see that your Electrolux wall oven is displaying an "F14" error code. "F14" stands for display tail missing, which means you could have an issue within your main control board or keypad. I would perform a reset on your appliance which can be done by flipping your household circuit breaker off for roughly ten minutes. If that does not correct the issue I would suggest seeking a professional to come out properly diagnose and repair your appliance. I hope this is helpful. -Matt
Aug 31, 2014 | Electrolux ICON Designer E30EW75GSS 30"...
What is error code F14
F14 = EEPROM Error
If there is an error reading this data, it will cause this error.
A power glitch may cause this error. Try unplugging the Unit for two minutes to see if that fixes the error.
Check CCU
So its likely you'll need a new CCU board. Check your owners manual, some models have up to a 5 yr. parts warranty on that CCU.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
Sep 03, 2010 | Kenmore Elite 45986 Front Load Washer
F14
Circuit Board Medics can rebuild the CCU to eliminate the F14 error. Find more details to contact them at www.CircuitBoardMedics.com.
Jun 14, 2010 | Whirlpool Duet GHW9150P Front Load Washer
Duet GHW9150P Front Load Washer: what does the F14 error code mean?...
F14 = EEPROM Error
Check CCU
May 16, 2010 | Whirlpool Duet GHW9150P Front Load Washer
F14 code on whirlpool duet
the central control unit{ccu}receives its data from an eeprom onboard the ccu.a power glitch may couse this error.unplug washer for two minutes.verify ccu operation by running a diagnostic test or any cycle.if you still have a problem you nead ta replace tnhe ccu.
Jan 15, 2010 | Whirlpool Duet GHW9150P Front Load Washer
Error code f14
Circuit Board Medics can rebuild the CCU with upgraded components to eliminate the F14 error and prevent it from happening again. Find more details and contact information at www.CircuitBoardMedics.com.
This video shows how to remove the CCU from the machine:
Oct 04, 2009 | Whirlpool Duet GHW9150P Front Load Washer
F14 error code, and says Flooding. Help please.
F/14 ERROR CAUSES DUE TO:--EEPROM ErrorThe Central Condrol Unit (CCU) receives it's data from an EEPROMonboard the CCU. If there is an error reading this data, it will cuse this error.
TO RESLVE THIS ERROR MANUALLY TRY THIS BEFORE CALLING ENGINEER :--
Check CCU
May 06, 2009 | Washing Machines
Error code f35 on my washer
The following list of codes indicates an electronics communication problem with the washer:
Duet HT® washer - F01, F03, F06, F11, F23, F24, F27, F28, F29, F30, F31, F32, F35, F42, F61, F62, F63, F64, F65, F70, F71, and F99
Duet® washer - F05, F07, F09, F10, F11, F13, F14, F15, F21, F22, and FdU
Duet SportTM washer - F01, F11, F23, F24, F27, F28, F29, F30, F31, and F33
To remove the error display, press Pause/Cancel twice.
If Pause/Cancel does not work:
  1. Unplug washer or disconnect power for one minute.
  2. Plug in washer or reconnect power.
  3. Re-select the cycle and press Start.
NOTE: If the error remains on the display, call for service.
Dec 19, 2008 | Whirlpool Duet GHW9150P Front Load Washer
Getting fault code f14?
F14 = EEPROM Error
Check CCU
Oct 15, 2008 | Kenmore Elite 45986 Front Load Washer
ERROR CODE F14 ON PANEL
Jun 07, 2008 | Whirlpool Duet GHW9150P Front Load Washer
Maytag MER5775Q Electric Kitchen Range Logo
106 people viewed this question
Top Maytag Kitchen Ranges Experts
vince
gbob59
Are you a Maytag Kitchen Range Expert? Answer questions, earn points and help others
