Question about Technics SU-G75 Amplifier
Technics SU-G75 overload
Display reads out "overload" when plugged in
    Habit-Forming:
    Welcome Back:
    Visited the website for 2 consecutive days.
I have the same problem..it will be required to remove the board and resolder "cold " solderings... None of above solutions have been helpful, but "you get what you paid for"..and I completely disagree...even if required, remove ALL audio power managing circuitry and replace this expensive original design with TI´s Integrated chips..using PWM technology..unless you want to go back to L6, ot Kts tubes..
Posted on Aug 16, 2017
  • allen1pow812 Oct 23, 2017
    I found a problem, one of many, described above..but found an easy way to fix this overload problem.
    1. Ensure that every output is connected per instructions.
    2. If still get this nasty "overload"..unplug your amp and remove cover.
    3. Locate the cooling fan and remove it from chasis. Measure resistance..per instructions above..maybe should measure 12 ohms or so
    4. Apply 12 Vdc to fan..ensure it works!
    5. Clean contact plates on both, chassis bend chassis flexible copper contacts and clean fan to ensure good electrical contact.
    6. Install fan to chassis and connect.
    7. Turn on amp and observe , at low level that display is clear..
    8. Turn the bass control to max, and the bass boost pushbutton on
    9. Play some music with a lot of bass passages, and turn up the volume level . Put your hand on back of the fan..notice how the fan turns on an every bass beat..If you have an Audio Frequency Gen ..set it anywhere from 40 to 300Hz. Fan should come on..and the "overload" display should be clear
    Conclusion: Very bad design , the MP does not read temp of the heatsink..it just acknowledges if fan is connected..The temp sensors are used for another purpose.
    AND ensure that contact to the fan are clean, and make GOOD contact. Best if just solder those fan contacts!
    Just another comment..regarding Technics QA.. RELIABILITY and Audio design..
    Not bad, considering age, comparison and compatibility with XX decoders up to 7 channel recordings and dynamic audio levels..it works fine.
SOURCE: Technics SU-G75
I had the same problem. The solution to me was presoldering transistor Q708. http://www.flickr.com/photos/37147023@N03/3511227679/?edited=1
Posted on May 08, 2009
smarthome2
  • 1114 Answers
SOURCE: Tecnics SU-G95 stereo overloaded
Power down,disconnect the speakers and power back up. If it still say's overload, it needs to go to service. If not, check your wires, connections, and speakers one by one to hunt down the problem and correct. Hope this helps
Posted on May 25, 2009
petraman7
  • 1175 Answers
SOURCE: Technics su-Z750 Intergrated Amplifier stays in Standby
HI...
This happens when one or more components in the power amplifier section has failed.
The protect circuit keeps large DC voltages off the speakers.
The only thing you can check for before finding a tech is that the speakers are firmly connected at both ends. If they are ok, you need a tech
PLease rate my help if this helps
Posted on Nov 09, 2009
tamcross
  • 96 Answers
SOURCE: technics amplifier su-g75 stopped working suddenly
CONECT THE SPEAKER WIRE PROPERLY
Posted on Jul 17, 2010
  • 794 Answers
SOURCE: i have a SU-G75 Technics stereo intergrated
Hi grayjt1963,
Based on the symptoms that you described this problem is caused by either of the two components. The most likely reason why you are getting no sound at all right now is the protect mode which your amp is in right now with the outputs turned off to prevent further damage. This unit have an AMP-Pac for the final stages that may be defective. The part number is RSN3306. This is the most likely part and can be purchased for about $60. Also inside is another AMP-Pac for the center and rear speakers (SVI3204B) which runs about $58. Either can cause the symptom you describe.
Hope this helps.
Thank you for using FixYa.
Posted on Jun 28, 2011
Technics SU-G75 owners manual download
http://www.manualslib.com/manual/926367/Technics-Su-G75.html?page=2#manual Technics SU G75 Service Manual Page 2
Sep 23, 2015 | Technics SU-G75 Amplifier
Want to download Technics SU-G75 service manual
Technics will not give it to you. Gotta pay the piper!
Did you try to google it - might get lucky - but don't hold your breath.
Sep 21, 2015 | Technics SU-G75 Amplifier
Technics SU-G75 has no sound
Hello
when the resistors are burned,means that the transistors are damaged, or the power module is damaged.
and in your case its the power module.
Hope this helps.
Feb 07, 2014 | Technics SU-G75 Amplifier
Technics su-g75 amp goes to loud static after a few minutes
Hi Aawpharmd,
system control error.
please go for repair shop.
regards,
nuwan
Jan 13, 2014 | Technics SU-G75 Amplifier
My technics amp SU-G75 keeps shutting off and reads OVERLOAD when played over the volume of -40 to -35. I kept playing around and it works fine when the bass dial is on half, but more bass shuts it off. I...
some amps are made more for low ohm loads (bass) and some are made for high impedence loads (mids/highs) and it seems you are asking too much from your amp.
Mar 05, 2013 | Audio Players & Recorders
Speakers for Technics SU X933?
check given link for speakers
http://www.fixya.com/myhome.aspx#Answers
Jun 05, 2012 | Technics SU-G75 Amplifier
I have a Technics stereo integrated amplifier SU G75. The cooling fan began making chirping noises then stopped. Now every time I turn the stereo on I get a overload message. Could it be the cooling fan...
It chirped because the bearings were worn out, then it froze up and isn't moving any air. Get it replaced. DO NOT run the unit if it keeps overloading or you will have a bigger problem.
Dec 27, 2009 | Technics SC-DV290 System
I have a technics amplifier SU G75
I have a technics too, and faced the same problem. The solution is very simple just ensure the +ve and -ve wires are connected correctly for each speaker to the amp. Eg. red wire to the red knob and black wire to the black on both ends. sometimes this arises because the wires are of just one color however there will be some marking on the wire to indicate which is +ve and -ve. This took care of the overload problem.
Jun 18, 2009 | Technics SA-AX530 Receiver
Technics SU-G75 Amplifier Logo
488 people viewed this question
Top Technics Audio Players & Recorders Experts
 Grubhead
Grubhead
T-Comtech Repairs
T-Comtech Repairs
Are you a Technics Audio Player and Recorder Expert? Answer questions, earn points and help others
