Question about KitchenAid Dishwashers
Kitchenaid w10084551a not draining
Ran my dishwasher last night and there is approx 2 . inches of clean water at the bottom after it was done. Can't figure out what's wrong with this thing. Drain tube appears to be clean. I opened the bottom on the inside and all appears to be clean also. Any ideas of what else to check would be greatly appreciated.
  • 1019 Answers
SOURCE: dishwasher not draining
the first things to look for, are the simplist faults.
1:) Check that the Outlet Hose-Pipe Isn,t Blocked-Kinked Or Bent.
2:) Check that the Pump, is not clogged/Blocked or not-functioning.
Hope this helps you start, your fault-finding successfully.
Mike @ Compurepair.
Posted on Aug 02, 2008
  • 262 Answers
jeff you can call customer service at 1-800-626-2001 and they can help but it sounds like your timer is missing the drain cycle
Posted on Jan 08, 2009
  • 130 Answers
SOURCE: water in bottom of dishwasher, can't get it to drain
pull your water drain line out and place in a bucket on the floor. then try to drain it again. alot of time the hose get an air gap or blocked with gunk.
Posted on Feb 16, 2009
skrbin
  • 121 Answers
SOURCE: My ge quiet power 3 dishwasher will not drain
must be a pump
  • 360 Answers
SOURCE: GE Profile PDW7300, Leaves 2 - 3 inches of dirty water in bottom
check for a clogged discharge hose where it connects to the plumbing under the sink...this is the most common area for a clog. if no restriction is found, the discharge valve will need to be tested
Posted on Feb 20, 2009
DD-603 cycle and draining problems.
check your kitchen drain as it might be blocked or if you have a garbage disposal (kitchen insinkerator) make sure it is cleared before running the dishwasher.
Jul 18, 2012 | Fisher and Paykel 23 in. DD-603SS Built-in...
665-110733490 Was working fine ,last night shut it off w/water in the bottom.also pushed cancel/drain did not drain.today I ran A wash cycle but after wash still had same amount water in...
Hello & Welcome to FixYa
Dishwasher not draining completely problem usually occurs due to clogged/blocked drain hose-filter assembly or the drain pump not working. First try to clean the drain hose and drain pump filter located inside the front bottom panel for any clogs, then check drain pump operation. Take off the bottom access panel to clean the drain pump filter and hose. If the problem returns after cleaning then it is the drain pump that needs replacement. Please get back to me if you have any other questions.
Kevin
Jun 09, 2011 | Kenmore Dishwashers
Won't mty ,bottom is full of water approx.2 inches of water. filter is clean any suggestions
Here is a tip that I wrote that will help you with your dishwasher not drainingproblem...
Dishwasher Problems - Water will not drain out
heatman101
Nov 07, 2010 | Frigidaire FDB2410HIC Builtin Dishwasher
Brand new dishwasher, installed last week. When it is done there is quite a lot of water standing in the bottom of the tub. It has only been run 2 times since installed and both times several inches of...
First was a new garbage disposal also installed? There is a knockout on the garbage disposal where the drain hose connects to.
If that is not the problem make sure it has the correct high loop or also called air gap. If that is not right water can siphon back into the dishwasher. Both are common mistakes usually made by begginers. Here is a link for the correct High loop installation
Oct 26, 2010 | KitchenAid KUDC03IVWH Builtin Dishwasher
Did not drain last night
how much water? there should always be at least an inch to 1&1/2 inches in bottom to keep seal at top of motor wet if seal drys out thern washer will leak around motor.if alott more than what i wrote then check float valve if it is sticking then see if anything is under it l/e a fork or something that may be keeping the float from dropping down to the proper draln level
Dec 12, 2009 | Kenmore 24 in. 17482 / 17484 / 17489...
Ran on normal cycle when done 2 inches of water on bottom
Test by restarting the cycle and see if water drains if it does not then there is either a blockege in the pipe ,pump,or in the machine where the water passes out normally through a filter if you have checked and cleaned out filter and drain pipe and there is still no draining then listen to the pump if you can hear a humming niose then there is something in the pump itself and you need to take it out and inspect the impelar houseing remove what ever is there put back and enjoy if there is no noise and pump is clean then it is proberly fualty and nedd replaceing.
Jan 23, 2009 | Whirlpool Gold 24 in. Built-In Dishwasher...
Dishwashers Logo
154 people viewed this question
Top KitchenAid Dishwashers Experts
Mike
Are you a KitchenAid Dishwasher Expert? Answer questions, earn points and help others
