Question about Generac Guardian Electrical Supplies
I have an 07 guardian plus 12 kw generator I just bought used (standby) i just hooked it up and it will start for a second and then quits it's now hooked up on natrual gas checked oil level
So I'm sure its not the oil level removed the orfice for LP when I try to start in manual position it cranks fires then cycles pauses and cranks like its suppose to but won't even fire when leaving in that position, when I switch from the off back to manual it fires for a couple of seconds but only when i do it myself it fires it for just a couple of seconds then stops please help ASAP
  • 120 Answers
SOURCE: generator back fires
Try changing the spark plug.
Posted on Jun 20, 2009
  • 384 Answers
SOURCE: 10kw Generac Guardian not cranking, shows rpm sense loss
Sounds like Generator mode switch should be "ON".
Posted on Sep 08, 2009
  • 37 Answers
SOURCE: My Briggs and Stratton standby 7000w home
Check the battery voltage while cranking the engine if it drops below 9 VDC then you have a bad battery.
Posted on Nov 20, 2009
ftw1952
  • 10319 Answers
SOURCE: It is a Guardian-Generac Generator Model 0052410.
My cousin has one of these models and the same thing happened to his. It was the natural gas regulator valve that went out. He could hear the clicking noise which is the spark ignitor trying to ignite the gas pilot light. After replacing the gas regulator the unit work fine as ever
Posted on Nov 02, 2010
stewbison
  • 577 Answers
SOURCE: I have a guardian 15000 generator. Have not used
Hello, I tried to answer this problem you had a few days ago. You were worried the hurricane was come and your generator wouldn't start. I tried to post the answer but Quest has the slowest servers were work properly. To many customers and not updated servers. Anyway I hope this help you out.
First, replace the fuel filter. When taking out the fuel filter let the gas in the run into a can. This will help to remove any sediment in the fuel tank. Buy a couple of fuel filters. One problem is it where you live. Condensation builds up in the fuel tank and this create rust. When the hurricane is over. Remove the fuel tank, and have it cleaned out. Now, see if they can line the fuel tank inside with a plastic coating. This will stop the rust. Also, insert absorbents packs in the tank when the generator is idle. This will will help the moisture build up.
Second, change the oil and remove the oil pressure shut off sensor and clean it or replace it.
If it has a temperature sensor take it out and clean it. If it has a oil filter change it also.
Third, remove the spark and clean it or replace it. Make sure you have the right plug gap on the spark plug..
Fifth, use some carburetor cleaner and spray around the throttle place and choke plate and make sure that the governor arm to the carburetor is free to operate and everything in the carburetor is working freely.
Fourth, remove the air filter and clean it or replace it.
Sixth, remove all the fuel in the tank and filter the fuel with a couple pair of your wife's pantie hose.
Be really careful, gasoline is extremely explosive.
Seventh, remove the fitting from the tank and use compressed air to clean out the tank. You might think I'm going to far here. Once you think the tank is clean install all the brass fitting and hose and new filters and pour the filter gas back into the tank. as long as it is new gas, if it's fuel old depose of the old fuel.
Next, Never used starting fluid on gas engines. If you get to much starter fluid in the combustion camber it can explode and blow the head off or nock the top of piston off destroying the engine. You and your family be safe. GB you all....stewbison
Posted on Aug 27, 2011
Generator hard to start and sputters like its missing
About 15,000 results (0.73 seconds) Search Results
    2 - Generac : Questions, Answers, How To, FAQs, Tips ...
    answers.generac.com/answers/1506-en_us/searchquestions.htm?...
    Can I run an 8kw standby generator on a 100 lb propane tank? 2 answers ... What am I getting for the extra cost of the Guardian unit? ... The engine starts hard and runs rough. 1. Air ... On auto start, unit sputters and I smell gas. ... Does the gas and electrical feed into the unit from the back as previous air cooled units?
    2 - Generac Questions and Answers
    answers.generac.com/answers/1506.../generac.../questions.htm?...
    On auto start, unit sputters and I smell gas. .... The 20kW automatic standby generator has the option to delay start up during an ... This is for a guardian 20kw. ....has been designed to make the battery installation and removal so difficult? ... The air cooled generators are designed to allow for the smallest footprint while still ...
    3 - Generac Questions and Answers
    Generac's Guardian Series 17kw automatic standby generator does not come with a.... The automatic response features of our air-cooled units initiates the unit's startup,.... This week I tried the same and it tries to start but just sputters and fails until .... A C delayed start still chocks 17kw generator would a hard start kit help?
    On auto start, unit sputters and I smell gas. On manual start ...
Feb 08, 2016 | Generac Guardian Air-Cooled Standby...
Why does it crank and almost start on 1st try?
Generac Generator Troubleshooting - YouTube
? 1:39
https://www.youtube.com/watch?v=AKN2dc59cxY
Dec 20, 2013 - Uploaded by Appliance Princess
I want to learn about Generac generator troubleshooting. ... I have a 16 kW propane fueled standby air-cooled generator. ... I have a brand new generac 20K guardian Evolution and the first time my power went out my generac ...
Generac Power Systems - ConsumerAffairs.com
www.consumeraffairs.com > Homeowners > Utilities
Rating: 1.3 - ‎26 votes
Hey, Generac, make a change and start making generators that work, don't cost .....Standby generators are not supposed to be used as a primary power source ... and three months ago, I spent $4,000 to have a Guardian generator installed at ...
Generac standby generator - Propane - wont start?? - DoItYourself ...
www.doityourself.com/.../487838-generac-standby-generator-propane-w...
Feb 4, 2013 - I have a Generac 4LM41A standby generator that I need help introubleshooting and repairing. It is about 12 years old and hasn't been used ...
141 GENERAC complaints and reviews @ P'ed Consumer
Dec 12, 2015 | Generac GUARDIAN Standby Generator 10 kW/9...
Hello i just started my 8 kw hole house generater ran greatput my electric water heater on 26 amp draw andsmoke came out exhaust vent shut it down ran again great turned only heater on again took amp
8 kW has a 35 amp breaker on the unit. A typical hot water is 4500 watts at 240 volts = 18.75 amps on each leg. If you are measuring 26 on one side and 19 on the other it should be ok. If it is shutting down you may have a fuel problem or you may need to adjust voltage if it's too low. Which model of 8 kW is it?
Sep 07, 2014 | Generac Guardian Series 8 kW Air-cooled...
Battery keeps dying
charging system, alternator/coils.
Apr 09, 2014 | Generac GUARDIAN Series Liquid-Cooled...
I have a Kohler 12 RES home standby generator. Once in a while when the power goes out the generator will start and then immediately shut down with no fault codes. When I flip the control in the unit
Check the inlet fuel pressure, on exervise there is no load, when power is out it is loaded and demands more fuel. Also check for bugs blocking gas regulators vents etc
Nov 12, 2012 | Kohler Generator. 12 kW and 14 kW Home...
Generac Guardian 12 KW Model 04456-2 shuts down on overspeed in cold weather
Leigh,
See my 5/22/12 comments on my "overspeed fault" problem resolution [Generac 43903 standby Generator overspeed indicator on starting] . If it only runs for a few seconds and then quits, you may have a similar condition to the one my unit had. A good technician should be able to diagnose the problem and determine if you have a similar failure to the one I had, or one of the other causes suggested by RSG000.
Jan 20, 2012 | Generac 13,000 Watt / 13,000 Watt Home...
Generator starts up and then cuts out after 7-10 seconds. The cut out appears to be from a "shut down" switch as opposed to carburetor oriented (it's natural gas).
I don't recall, does your generator have oil monitoring, did you say you checked the oil. If it's a protection shutdown there may actually be an oil change timer as well.
Jun 24, 2010 | Briggs & Stratton Standby Generator 12 Kw...
Generac Guardian 15 kw overspeed fault
Did you remember to set the overspeed shutdown threshold on the control board?
Apr 03, 2009 | Generac 13,000 Watt / 13,000 Watt Home...
Electrical Supplies Logo
35 people viewed this question
Top Generac Guardian Electrical Supplies Experts
jdthefixer
epangan29
ken skalski
Are you a Generac Guardian Electrical Supply Expert? Answer questions, earn points and help others
